Question about Maytag MER5765RAW / MER5765RAQ / MER5765RAB Electric Kitchen Range
I have a Maytag stove Model # MER5765RAW. How do I remove the inside or outside oven door panel to clean some grease that spilled and is in between the 2 glass see thru windows?
SOURCE: how to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Posted on Jul 21, 2007
  • 2920 Answers
SOURCE: burner on glass stove top has turned black
replace the glass top with a new one
Posted on Dec 06, 2008
  • 3 Answers
SOURCE: MAYTAG Model ME5770AAW Ceran Top Stove
I had the same problem, but a plastic top burned on my range top causing a black spot. I used oven cleaner. Let it sit a while on the spot(hour or two), then use a razor to scrape. It looks good as new. I had used everything recommended by the manufacture before I tried this.
Posted on Mar 06, 2009
philbran
  • 242 Answers
SOURCE: change time on stove held clock button and got a 5Ab & can't chng
Loof for the tech. sheet in the unit , either in the control panel [top] or the bottom under the drawer. It should tell you how to enter different modes on your range.
Phil
Posted on Apr 10, 2009
SOURCE: Maytag Gemini oven glass door panels impossible to clean
We had an ugly spill of hot grease/water from a roast, and lots of it ran right into the vent holes on our oven door, covering various layers of glass and other parts inside the door. Yuck. Thankfully we found this site!
"fixetheoven" was certainly on the right track, but missed a key step that makes this job much, much easier. (Maybe they had a few too many sips of wine during the process?! :-)
Anyway, the key to make the job easy, and do-able by one person, is to pull the door off the hinges before starting to remove any screws! Here's how we did it:
1. Open the door about four inches or so, it will stay in place. Hold the door at the sides and lift it up, sliding it right off of the hinges! Now lay it carefully face up on a table so you have easy access to the screws, and no danger of the glass dropping out of the bottom of the door (as apparently happened to "fixedtheoven".)
2. Remove the two screws that hold the panel on one side of the door. (One screw is halfway up the side panel, the other is on the bottom edge of the door.)
3. Slide the panel off, paying close attention to how it fits into place so you can return it to its original position later!
4. Remove the two screws that hold the panel on the other side of the door, and slide that panel out as well.
5. Remove the three screws that hold the panel across the bottom edge of the door, and remove that panel.
6. Now you can slide the front glass out from under the top edge of the door.
7. Clean the front glass, the side panels, and the bottom panel, as needed.
8. There will be another layer of glass inside the door. If it needs cleaning on the underside, remove the screws from one of the metal brackets that hold the glass in place. You can then slide this piece of glass out from the metal bracket at the other side.
9. After cleaning everything, reassemble the door by reversing the above steps.
10. Lift the door by the sides and carefully slide it back into place on the hinges. Be sure it is properly in place and being held there before you let go!!
11. Now go pour that glass of wine and sip to your heart's content, while admiring how clean your oven door is!
Posted on Jul 29, 2009
How do i clean the inside the glass on my oven door
The door usually has about 4 to 8 screws on the inside. Remove the door first by opening it to 45' and lift it off its hinges. Sit it on top of the stove carefully after putting an old towel and a garbage bag on top of it. Remove the screws in the door and the inside will lift off the outside skin. Clean the glass with oven cleaner and reassemble. Ours needs doing too!
Feb 11, 2016 | Ovens
C970 555821 Kenmore oven
Look for the model number inside the oven door area. The number you posted is incorrect.
Dec 22, 2013 | Kenmore Kitchen Ranges
Maytag MER5765RA oven door won't unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 11, 2010 | Maytag MER5765RAW / MER5765RAQ /...
How do I clean the inside glass on the door - GE Profile JVM1870
I have a Kenmore with similar issues.
Model 665.61639100
Anyway, good luck with this. Hope someone has an answer for you (and me).
Mine has a open slot on the top front of the door. Kinda like a double plate window execpt for the opening in front. Why is this there? I don't know. Weird design. But it leaves for the possibilty of liquid to splash in there leaving it hard to clean (like impossible).
I'm thinking I have to completely remove and disect the door.
Jan 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Self cleaning
You can go to the Maytag web site and download the manual.  www.maytag.com, or go to http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
and download the manual CAUTION
• It is normal for parts of the ovens to become hot during a self-clean cycle.
• To prevent damage to oven doors, do not attempt to open the doors when LOCK is displayed.
• Avoid touching doors, windows or oven vent area during
a clean cycle.
Do not use commercial oven cleaners on the oven finish or around any part of the ovens.  They will damage the finish or parts.
Do not leave baking/pizza stone in the oven during self-clean.
The self-clean cycle uses above-normal cooking temperatures
to automatically clean the oven interior.
The oven should be cleaned regularly by wiping up spillovers
to prevent excessive smoke and flare-ups.  Do not allow a
heavy build-up of soil to accumulate in the oven.
During the cleaning process, the kitchen should be well
ventilated to get rid of normal odors associated with cleaning.
Before Self-Cleaning
1. Turn off the oven light before cleaning as the light may burn out during the clean cycle.
2. Remove broiler pan, all pans, and oven racks from the oven.  The oven racks will discolor and may not slide easily after a self-clean cycle if they are not removed.
3. Clean oven frame, door frame (area outside of gasket, and around the opening in the door gasket) with a nonabrasive
cleaner such as Bon Ami* or detergent and water.  The self-cleaning process does not clean these areas.  They should be cleaned to prevent soil from baking on during the clean
cycle.  (The gasket is the seal around the oven door and window.)
4. To prevent damage, do not clean or rub the gasket around the oven door.  The gasket is designed to seal in heat during the clean cycle.
5. Wipe up excess grease or spillovers from the oven bottom. This prevents excessive smoking, flare-ups or flaming during the clean cycle.
6. Wipe up sugary and acidic spillovers such as sweet potatoes, tomato, or milk-based sauces. Porcelain enamel is acid-resistant, not acid-proof.  The porcelain finish may discolor if acidic or sugary spills are not wiped up before a self-clean cycle.
Important:
• Oven temperature must be below 400° F to program a clean cycle.
Only one oven can be cleaned at a time.
• Both oven doors lock when either oven is being cleaned.
To set Self-Clean:
1. Close the oven door.
2. Press the Clean pad.
    • CLEAN flashes.
    • SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
    • “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning settings.
     “HVy” (Heavy Soil, 4 hours)
     “MEd” (Medium soil, 3 hours)
     “LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs the self-cleaning time.
5. After four seconds, the oven will start cleaning.
    • If the door is not closed, beeps will sound and ‘door’ will display.         If the door is not closed within 30 seconds, the self-cleaning       operation will be canceled and the display will return to the time of day.
    • CLEAN will appear in the display.
    • LOCK will flash in the display.  Once the door locks, LOCK will
      remain steady.
    • The cleaning time will start counting down in the display.
Nov 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
How to take apart oven door
Jun 18, 2007 | Maytag MER5775Q Electric Kitchen Range
Spill into oven vents
The best way to clean the inner glass is to remove the door from the oven. With the door in the broil open position (first stop) pull up for about 2 inches until the hinge brackets are released from their stops. Close the door all you can and lift the door off the hinges. Lay the door on a padded surface and remove the 4 screws on the bottom. The outside glass will now slide out of its rail and you can clean the inside. To install just reverse the process. If you take your time and observe, it's not that bad of a job...Catriver..post back.
Nov 26, 2006 | KitchenAid KESC307 Electric Kitchen Range
Maytag MER5765RAW / MER5765RAQ / MER5765RAB Electric Kitchen Range Logo
117 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
