Question about Gateway FPD1975W 19" LCD Monitor
FPD1975W 19" screen went out.
Like the other link (http://www.fixya.com/support/t153963-19_lcd_gateway_monitor_will_not_power)
Can you get power supply that goes inside of the screen anywhere?
  • Ryan127 Oct 30, 2008
    All of a sudden my monitor just wont turn on. I've changed the outlet it was plugged into but it still didn't work.
    Problem Solver:
  • 16 Answers
I HAD THE SAME PROBLEM. BLUE POWER BUTTON WOULD TURN ON-OFF-ON-OFF WHILE THE SCREEN FLASHED. THEN AFTER UNPLUGGING IT THE SCREEN WOULD FLICKER. THEN JUST WOULDN'T COME ON. GO ON EBAY FIND SELLER BAMMBAMMFRAN OR SEARCH FOR YOUR MONITOR. HE SELLS A PRODUCT REPAIR FOR $30(NOT INCLUDING SHIPPING). I SENT MY BOARD TO HIM. YOU CAN TAKE YOUR MONITOR APART AND SEND HIM THE INVERTER BOARD OR THE WHOLE MONITOR, ONLY DIFFERENCE IS THE SHIPPING COST. HE WILL LET YOU KNOW IF IT IS FIXABLE(THE INVERTER BOARD). IF I REMEMBER CORRECTLY HE ONLY CHARGES IF IT IS FIXABLE. I TOOK MINE APART AND SHIPPED THE BOARD TO HIM. HE FIXED IT AND SENT IT BACK TO ME. MY MONITOR WORKS GREAT.
Posted on Nov 18, 2008
FPD1975W TFT LCD monitor my monitor blinks a blue power light and flsahis a white screen but it does not turn on ?
A flashing power light indicates a failure of the power supply, this will also cause the white screen. Here is a link to a page showing what parts need to be replaced to repair the power supply board and get your monitor back running again.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution,
BuddyMc
Oct 09, 2011 | Gateway FPD1975W 19" LCD Monitor
My moitor fpd1975w blinks blue power button and a white screen but does not turn on ?
The blinking power light is a good indication of a failed power supply board and the white screen backs that diagnosis up. Here is a link to information show what to look for and replace on the power supply board to get the monitor back up and running again. The repair involves replacing parts called capacitors on the power supply board and can be done in less than 20 minutes once you have the parts needed.
I hope this helps,
BuddyMc
This is the strangest thing I've ever seen. I have a Gateway FPD1975W TFT Monitor and its always worked great. The other day it went into a sleep mode via windows, and now it wont boot up the input...
Your monitor problem is causes by the power supply. What is happening is the power supply voltages are not stable, just enough to power the unit up. When you connect it to a video signal the power demands slightly increase and the power supply can't handle it. This is a very common problem with LCD after a few years of use. The issue with the power supply is the capacitors have started to fail. These parts are used to filter the output voltage and when they start to fail the outputs start rippling hence the problem you are having. Here is a link to a repair article that shows how to repair the Gateway FPD1975W monitor.
I hope this helps you get back going.
BuddyMc
Sep 20, 2011 | Gateway FPD1975W 19" LCD Monitor
Hello, i just bough the gateway monitor FPD1975W but i can not to connect because it asking for passcode. what i culd do? thanks
This is bad news, you will need to get it fromt he original owner and you alos need to contact GATEWAY, please see below:
http://www.fixya.com/support/r4558549-gateway_lcd_monitor_eztune_theft
Please leave rating if it helps.
Feb 16, 2011 | Gateway FPD1975W 19" LCD Monitor
I havew a gateway FPD1975W monitor and I can not get it to fit the screen correctly. It stretches outside of the screen.
You need to set your PC video resolution to the native resolution of this monitor: 1440 × 900 @60Hz.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Feb 15, 2011 | Gateway FPD1975W 19" LCD Monitor
The monitor is a Gateway FPD1975W TFT LCD Monitor. I do not know the age of the unit. As of late it will not turn on. When the power button is pushed it will just blink like it it in standby mode even...
It was released about 2006.
I do hope you do have the PIN to unlock it, otherwise you will have to contact Gateway.
Please read this:
http://www.gateway.com/retail/fpd1975w.php
GatewayShield™ Security Available
Protect your hardware using the EzTune™ Anti-Theft Software and reinforced lock slots. The slots, paired with a cable lock, physically anchor your display to a secure fixture. The software keeps the monitor secure using a unique PIN code. In the event the display is removed from the PC without the code, its full functionality is disabled.
It may have hardware problem inside due to bad caps.
Dec 24, 2010 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W black 19 inch LCD
most likely is the power supply in the monitor.
gateway LCD has a building power supply in the monitor. it supplies 38W to the lamp.
since there is no display, it tells me that there is no power to the monitor.
if try another monitor and it works fine. then the problem is the monitor. (dispaly lamp is good for 17 Years- according to the tech spec.) but the power supply is pushing too much power.
other vendors max power is apporximately 30W.
make sure there is nothing behind the monitor and has good air flow. Since there is no fan in the unit. it need to vent the hot air natually.
Oct 18, 2008 | Gateway FPD1975W 19" LCD Monitor
Power supply for Gateway FPD1975W 19 inch LCD
try replacing the crystal on the power supply 8 out of 10 times it is the problem
Apr 02, 2008 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
190 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
