Question about Exercise & Fitness
I have an athletech performance treadmill it won't turn on on button doesn't click as does the off button
Performance athletech treadmill wont turn on off button clicks on doesn't
  • William T nelson Feb 12, 2012
    safety switch works, tried reset on panel and bottom of treadmill nothing works
    Top Expert:
  • 12,223 Answers
Dear Sir:
1) Try to reset the c. breaker in your treadmill.
2) Inspect if your see some loose wires.
3) Open the keypanel and tight the flexible cord or ribbon cables.
4) Tight the connector coming from display planer to lower boar or main motor board.
5)Test the Transformer for there are voltage in primary and secondary winding.
6) Measure the input to the power board
7)See there are +5VDC to the main motor board and display board?
8) Run the calibration Software read your user manual or see under the Hood the motor the instruction for more easy diagnose and troubleshooting . Attached is my block diagram that I did design for purpose of diagnose. sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a.
I have an athletech performance treadmill it won&# - 2_16_2012_11_55_47_pm.gif
Posted on Feb 16, 2012
  • 1196 Answers
SOURCE: when switching on my York
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful." Contact the business where you purchased your treadmill if repeating the calibration process does not result in a successful calibration.
Posted on Jul 17, 2011
SOURCE: Need replacement key
I ordered a key from the treadmill doctor site. It cost me 9.99 free shipping. I ordered the 1" Safety key for Proform & Weslo Treadmills 119038. It was a little thick so I sanded the rails on the bottom with a soft Kiss lady's nail sander. I only left a small smidgen of the rails on the key. Now it works just fine. The clothing clip is not as nice as the orginal, but is sufficient.
Posted on Nov 27, 2010
ercupa190
  • 12223 Answers
SOURCE: Trying to fix a 20+ yr.old treadmill (Precor USA
Dear Sir:
I hope you are very well, in union with your family.
Thank you by your request, and I will help you inmediately.
Please follow the next step with very carefully:
    • 1
Makesure that the surge protector being used is properly grounded(Very Important) and turned on.Check that the treadmill power cord is properly plugged into the surgeprotector.
    • 2
Checkto see that the key is inserted in the console.
    • 3
Checkthe circuit breaker on the frame near the power cord. If the reset/off circuitbreaker has tripped, wait 5 minutes and then reset the breaker by pressing theswitch in.
4)Check the circuit braker panel house, and reset.
Static Shock Problems:
Many people face a conundrum when using a treadmill. The problem is that a treadmill has you walk or run in a motion that causes you to build up an electrical charge on your body while you are exercising.
The problem if you are swinging your arms, you are totally isolated from any common ground so the charge just builds and builds and many discharges have been measured above 30,000 volts.
You may say, how in a frost-covered hell can I build up 30,000 volts on my body without killing myself? Good question and it has a good
answer...there is very little amperage. It will pop you good when you do ground and sting but it won't hurt you.
The problem is that it can damage the treadmill's electronics if it is not properly designed and we still see poor designs in this respect
If you don't like getting popped or if your treadmill is shutting down or going crazy, there is a fix. You can ground yourself to keep the electricity from building up on your body.
We now have wrist grounding straps that can be reused and attach to the frame of the treadmill without causing any markings and do not require any permanent modification to your treadmill. You can find them in any online catalog by electronic sales by searching for Grounding Strap.
Thank in advance, sincerely. God bless you.
If you need further assistance, please contact us.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Sep 28, 2011
ercupa190
  • 12223 Answers
SOURCE: treadmill won't turn on, I get a slight shock
Dear Sir:
Thank you by you request, I will help you inmediately.
Please do this with very Carefully!!
The shock is a build upof static electricity on your body called Electrostatic Discharge (ESD).Friction between the walking board and belt can generate static electricity.
If experienced, the shock is not harmful ordangerous.
Thank you in advance, sincerely. God bless you.
IF YOU NEED FURTHER ASSISTANCE, PLEASE CONTACT ME
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Sep 29, 2011
ercupa190
  • 12223 Answers
SOURCE: Treadmill speed up button doesn't work.
RPM SENSOR:
indicates input signal from the RPM sensor to the MCB.If the LED, is not flashing, please review the following:
1) Sensor disconnected from the MCB.
2)RPM SENSOR misaligned.
3)RPM sensor faulty.
e.cuadra
Posted on Nov 03, 2011
It doesn't turn on
follow this steps and fix it. God bless you
Mar 24, 2013 | Sportsart Fitness TR32 Treadmill
Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Nov 17, 2011 | Exercise & Fitness
I have a vision T9500 treadmill. My husband was recalibrating and it got stuck in the highest position and is displaying E5 in the window. Any ideas how to get it down?
hi,
Try AUTO-CALIBRATION first. For that do the following.
With the safety key in place, turn the treadmill ON . Press and hold SELECT. Now you can perform auto-calibration by pressing START.
(The treadmill will run through minimum and maximum speed and elevation. This will take 3 to 5 minutes. Let the treadmill perform this complete function. "END" will appear when auto-calibration is complete. When auto-calibration is complete, it will take about 30 seconds for the treadmill to reboot and return to the start-up screen)
If it doesn't help then the motor control module is faulty. You have to replace or repair the motor control module.
OK
Aug 27, 2011 | Dmm Vision Fitness T9500 Treadmill
"ON" button doesn't work; calculator won't
In most cases this cannot be economically repaired... the cost to repair would be more then the calculator is worth...
heatman101
Jun 18, 2011 | HP 48gx Calculator
Jul 15, 2009 | Proform Crosswalk 500 Treadmill
Exercise & Fitness Logo
212 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
