Question about Cameras
Deleted bonjour by mistake - Cameras
Need to delete itunes and reinstall but control panel will not delete itunes how to delete?
According to Apple Use the Control Panel to uninstall iTunes in the following order and restart your computer :
iTunes,Apple Software Update,Apple Mobile Device Support,Bonjour,
Apple Application Support.
if your have faced any issue then follow https://discussions.apple.com/message/21392445 and
Apple and Mac Technical Support for more help.
Jul 28, 2014 | Apple iTunes
My sx515w has found router but is permanentley offline how do i get it on line ?
I had the same problem. I read all the help on the internet and tried disabling the firewall on the mac laptop. Infact it was not that. I then read about manually loading 'Rosetta' off of the OS discs supplied with my Mac. The solution is to install Rosetta. Rosetta is the background software which converts PowerPC code to Intel Mac code. While Snow Leopard won't install on a PowerPC Mac, it will allow installation of many PowerPC applications, including Appleworks. Some drivers which are PowerPC only, and plugins for software such as Adobe Photoshop may not work with Snow Leopard.
Put the Snow Leopard disk in the drive and double click the Optional Installs folder, then the Optional Installs.mpkg. Install just Rosetta.
I then saw a blog that said there was a known bug with Mac and Epson - he talked about using Bonjour driver as the default printer - I didn't know how to do it so .....
It still did not work so I got onto Epson WebChat help which was very effective. See the chat below that fixed the problem:
11:45:29 : Steven Wood: Hello Geoff. Have you tried deleting the printer from PRINT and FAX then re-adding the printer making sure that you select either the BONJOUR or STANDARD TCP/IP port?
11:47:03 : geoff: No and although I think I can delete the printer and readd it I am not aware how to select bonjour or standard TCP?IP port - what are these?
11:48:19 : Steven Wood: when you go to add the printer again, bonjour or standard tcp/ip should appear under the KIND heading
11:50:25 : geoff: done that and both came up - added the EPSONOA&F95 (idle, last used) -
11:50:54 : Steven Wood: okay Geoff. Once this has been done can you then restart the MAC and try a print
11:54:34 : geoff: Thats it - done - thanks
Hope this all helps
Geoff
May 11, 2010 | Epson Stylus Multifunction Inkjet Printer/...
'messages sent' deleted by mistake
  1. Log into your Yahoo Mail account - http://mail.yahoo.com
    When you delete messages in Yahoo! Mail, they go to your Trash folder. If you delete a message by mistake, for a little while you'll be able to find it in Trash and move it back to your Inbox or another folder. Just remember that messages in your Trash folder can be deleted at any time, without warning.
  2. To permanently remove the contents of Trash yourself, just click Empty next to Trash on the left side of the page. When messages are emptied from the trash folder, they are permanently deleted from the Yahoo! Mail server and cannot be recovered.
Mar 18, 2010 | Yahoo Mail
Connect macbook to cannon pixma mp620 printer
You need to delete and readd the printer with a bonjour connection.
Click on the apple in the top left and go to system preferences and then print and fax.
Click on the printer name (just one click to highlight) on the left and then on the minus sign. It will ask if you are sure you want to delete - you can click yes or delete.
Click on the plus sign and you should see the printer with a bonjour (macspeak for network) printer
Click on it to highlight it and then it will look for drivers and you can then click add to add to your list.
Close print and fax window and open a document and print away!!
Jan 14, 2009 | HP PSC 1315 All-In-One InkJet Printer
Bonjour problem
Bonjour is not needed:
To remove Bonjour:
  1. Open a Windows command prompt and type the following command:
    "C:Program FilesBonjourmDNSResponder.exe" -remove
  2. Navigate to the following folder in Windows Explorer: C:Program FilesBonjour
  3. Rename the mdnsNSP.dll file in that folder to mdnsNSP.old
  4. Restart your computer
  5. Delete the the Program FilesBonjour folder
Note: Removing Bonjour prevents Version Cue clients (Photoshop, Illustrator, InDesign, Flash, Bridge) from automatically discovering Version Cue Servers and Version Cue projects in your local network. You will need to connect manually using Connect to Server and the URL or IP address of the machine running Version Cue Server instead.
http://kb.adobe.com/selfservice/viewContent.do?externalId=kb400982
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 25, 2008 | Apple iPhone 3G
Nokia 8800
Do you want to delete mistakes that you type or the mistakes in the incoming messages ....
Oct 16, 2008 | Nokia 8800 Cellular Phone
Philips gogear sa6185
I just fixed the problem I was having (after 2 days of trouble shooting and on the phone with Norton anti-virus). Somehow, the Bonjour program got deleted from my computer. I think it happened when Norton was upgraded and renewed on my computer because I'd done nothing different up until that time. Here's how I fixed it JUST NOW. I went to:
http://www.apple.com/downloads/macosx/apple/windows/bonjourforwindows.html
and downloaded Bonjour. My gogear is now working just fine. Hope this helps you, too.
Sep 29, 2008 | Philips GoGear SA6185/37 Digital Media...
HL-5250dn ona Bonjour network will not work with Leopard
Brother is totally fucked up under Leopard, found so far no chance to fix it.  Brother's own printer drivers are 10.4 only -- lame
Feb 24, 2008 | Brother HL 5250DN Laser Printer
Cameras Logo
70 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
