Question about Maytag Washing Machines
How to remove the agitator from a Bravo top load washer
I noticed a quarter had slipped under the agitator. how do I remove it to retreive the quarter and clean beneath it?
var-pun
  • 331 Answers
SOURCE: Frigidaire Top Load Washer Won't Agitate FWS645GFS1
i guess you may be right
or maybe the motor
is not rotating with the ussuall speed pls inspect it..............
and ask for a technician .......
Posted on Sep 15, 2008
reg501
  • 413 Answers
SOURCE: Remove the agitator
The agitator is actually pressed on without mechanical fasteners . Grab the bottom of the agitator firmly on each side. Pull up with a quick, hard **** (careful not to hit your face). If this does not work, wrap a belt under the agitator. Grab the belt firmly and pull up with a quick, hard ****.
Posted on Dec 25, 2008
  • 1214 Answers
SOURCE: Agitator is slipping- GE model WJRR4170G top load washer
Starting at the center agitator stem, there should be a cover cap or something that is removed to allow access to the bolt or nut that hold the agitator on.
Reply back what you find and I'll help further.
Posted on Jan 30, 2009
SOURCE: no agitation
I have a Whirlpool Utlimate Care II LSQ8520JQ0. For those having a problem separating the upper and lower agitator halves, here's how I solved it after about 2 hrs of aggravation.
Called Sears and Whirlpool with no help (didn't have tech manual...go figure).
I saw the same post with the problem with melted hooks (I called them tabs) ontop of the dog housing being melted. You can differentiate the melted tabs from the dog housing as the dog housing is usually clear plastic (after wiping all the crud off) and the tabs are white as they are part of the agitator. There will be four white tabs on top of the dog housing. They look both smashed and melted. I took a flat head screw driver and and hammer and chipped off the white melted tabs visible on top. I inevitably also chipped some of the dog housing but only marginally. Once chipped off you'll see the tabs are actually rectangular in shape. At this point I EASILY pulled the top and lower halves apart. Those retangular tabs are the molded part of the agitator housing extending down past the dog housing. You're home free at this point.
It's the melted tabs on top of the dog housing that keeps you from separating the halves. What a pain but finally figured it out.
Posted on Feb 16, 2009
SOURCE: HOW TO REMOVE AGITATOR ON A HOT POINT WASHER
if anyone is still doing this.. i had a hotpoint model type vbxr1060. It had just a cap on agitator no extra bolts and used two hammers to get underneath the base creating leverage..
Work both hammers in (using the nail puller side) as far as possible towards the center of the agitator on opposing sides and use them to pull up and slightly outwards towards the sides of the basin. When you get it off you will see why this works as the agitator's base has mini clips that grasp the base of the air bell housing. hope this tip helps someone.
Posted on Apr 07, 2009
Agitator ratchet not catching on model lxr924eq1
USING A SOCKET WRENCH THE SCREW IN THE AGITATOR IS 7/16 REMOVE IT THEN U CAN LIFT UP THE TOP AGITATOR, UNDER IT U WILL FIND THE TRUST WASHER AND THE CAM DOGS THAT NEED REPLACING
Jul 25, 2014 | Whirlpool Washing Machines
F1 off balance how do I balance my bravo washer, to get it back on balance?
Their could be objects between the tubs, remove the inner tub nut under the agitation device and lift out the tub. look for objects in there. Also the inner basket has a balance ring in it.
Service manual and failure codes
Jun 20, 2011 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravo washers is staining my cloths.......any thoughts on what may be causing this?
the upper transmission seals bad its under the tub agitator and letting oil into the water called "wash back" you need to replace this seal and stains will disappear
Apr 06, 2011 | Maytag Bravos MTW6600T Top Load Washer
AGITATOR SEEM TO BE SLIPPING, NOT ENGAGING COMPLETELY THROUGHOUT THE ENTIRE WASH CYCLE.
The agitator has under the cap what are called agitator dogs. They wear out causing agitator to slip. They sell a kit at appliancepartspros.com cost $10. Easy to replace comes with instructions.
Aug 18, 2010 | Whirlpool LSN1000LW Top Load Washer
How do you remove the cabinet?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=461f98783d12332dded6ab62e3faca9d
Some Kenmore washers do not use removable end caps on the console. If yours is one of these, slip a thin putty knife under the front edge of the console to release a spring clip.
Jul 07, 2010 | Kenmore 24032\24036 Top Load Washer
Agitator loose does not swish clothes around .... can't figure out how to remove the agitator in order to see what may have come loosened or if splines are stripped .... how do you remove the agitator ?
Hello, on the style GE washer there is an agitator coupling under the agitator that will sometimes strip out. To repair this remove the agitator by pulling it straight up and out.
TIP: If you can't get your fingers under the agitator, you can slip a belt under the agitator and then pull by that, once the agitator is off you should see a yellow coupling held on by a 7/16 bolt, remove that bolt and pull the coupling up and off the transmission shaft. Sometimes it will be hard to remove and you might need to knock it up with a hammer. Once it is off you should be able to slide the new one back on, bolt it down and push the agitator back on.
Thanks
Jun 14, 2010 | GE WBSR3140DW Top Load Washer
Washer doesnt agitate but spins and drains. how
Agitator pulls straight up and off. (you may have to slip a belt under it to pull it..... a hard yank) Drive coupler is nylon part you will now see, held on by one bolt. Remove bolt and pull off. If it won't come off, just break it apart with a chisel, as you need to replace that part anyway.
Jul 19, 2009 | GE WBSR3140DW Top Load Washer
Adgitator removal
Just follow these steps:
1. Remove the center dispenser from the top of the agitator. It should just pop off.
2. Locate the white plastic cap underneath and pull straight up to remove.
3. Locate the agitator bolt underneath and remove using a socket and ratchet (can't remember the size). Hold the agitator still with one hand in order to loosen the bolt.
4. With the bolt removed, grasp the agitator by the bottom flanges and pull straight up. It should lift off the center post.
NOTE: Sometimes these agitators will stick due to years of detergent accumulation. You may have to wobble it back and forth to get it loose.
If you have questions, please let me know. I hope this helps you.
May 03, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Agitator slipping
is it a top load washer?if so there are 4 dog ears under the agitator cap that turn it ,you need to replace them($2 at your local appliance parts store-mike
Mar 19, 2009 | Kenmore Washing Machines
IF the agitator is like the ones in the older models, it will just pull straight up and off of the transmission shaft.
Inside the agitator there is a rubber splined insert with an aluminum center. The soft aluminum strips out causing the grinding sound. Very common to happen.
We used to use a special puller to remove that part and then press a new one back in.
Voila! Repaired agitator!!
Most any appliance parts store should be able to look up your model # and tell you if that agitator can be resplined.
Jan 30, 2009 | GE WJRR4170E Top Load Washer
Washing Machines Logo
351 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
