Question about Watches
Instructions needed to change time - Watches
Instructions for setting alarm and time on armitron 45/7012blk
To change from Military time to AM/PM just hit the reset button in the top left corner on the 45/7012. You will see a little am or pm pop up.
Feb 06, 2013 | Watches
I need instruction for a lifemax ladies watch
For Lifemax watch instructions, go to http://www.rnib.org.uk/shop/Pages/Category.aspx?Category=talking_watches
and select the model of Lifemax watch for which you require instructions.
When that product page opens, scroll down to find 'product instructions'. Click on that to open the instructions in a Word document (you will need to have MS Word or the free OpenOffice suite to read it)
Jun 02, 2012 | Watches
I need to change the hand time on my casio fishing gear watch and have lost the instructions.I have already changed the digital time
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Apr 08, 2010 | Casio Fishing Gear Watch
I have a timex 1440 sports watch with only 4 buttons. I cannot change the time. I have tried many combo's of pushing them and I can't change the time. What do I do?
I assume that you do not have the instructions, so you need to download them from the Timex web site.
Go to "timex.com", at the bottom of the screen is a tab "Product instruction ...." select this and choose from the selection given.
Jan 06, 2010 | Timex 1440 watch
I purchased a Nat. Geo. Dakota watch in past fall..It was impossible to set. Paid a watch shop to set it....now it won't change to daylight savings time...nor will it change time zones when I travel....
When changing time zones, your watch must be manually set for the new time zone you will be entering. This watch is not designed to adjust for new time zones automatically. Instructions for changing time zones can be changed using the directions found on pages 2-4 in your instruction manual. When changing to and from DST, your watch should automatically adjust for this difference with the next 24 hours after the change. If your watch has not adjusted, you may be in an area that is not receiving signal. Check if your watch has received signal by using the directions found on page 1 of your instruction manual. If your watch has received signal in the past and no longer is receiving signal, your watch may need to be serviced or exchanged. Please contact Dakota Watch Company Customer Service by email at customerservice@dakotawatch.com, or by phone at 1-888-459-0404.
Mar 08, 2009 | Dakota 2786-6 Wristwatch
Need instructions for Timex 1440 Sport watch
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to sesume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Nov 22, 2008 | Timex 1440 Nylon watch
Daylight savings time change without auto change in watch
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
Mar 10, 2008 | Casio G7500G-9V G-Shock Vibration Watch
Setting Time and Date on a Timex WR30M
1) Press and hold mode for about 2 seconds and then release. You will now be in the alarm edit mode.
2) Press mode once more and now you are in time edit mode.
3) Use the stop button to select what to edit, i.e. hour minute, etc.
4) Use the reset button to make the changes once you have selected the hour/minute, etc. that you want to change.
5) Press
Mar 07, 2008 | Watches
Watches Logo
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
