Question about Watches
DKNY watch battery
I need to change the battery in a DKNY wrist watch. There is a number on the back:340140
then NY 1206 5 ATM/50 Meters CE
  • 29 Answers
SOURCE: Dkny watch- repair, need extra links
I suggest calling DKNY customer service @ 1-800-231-0884 This is their return or repair department they should be able to help with links for your watch.
Posted on Mar 12, 2008
  • 51 Answers
SOURCE: Watch band sizing
OK, I make an attempt:
I saw on other pictures on the web that the links have small holes at the side. There should be some links with arrows r another marking. These are usually the links that can be removed to shorten the strap.
If there is a small arrow on the link, it means that you can push out the pin inside the hole in the direction of the arrow. Then the link can be detached.
You can push it out with a blunt sewing needle (break off the tip).
Remove links on both sides of the watch when resizing it.
Hope that helps.
Critter
Posted on Dec 27, 2008
dmbgo
  • 58 Answers
SOURCE: Need screw for watch Style#NY-4285
Hi, you should be able to get one from a watchmaker
Posted on Jun 22, 2009
disap1
  • 98 Answers
SOURCE: resize DKNY 1035 Wrist Watch band
Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
Posted on Jan 10, 2010
SOURCE: cant set time on watch
Timer Setting
1. In timer mode press and hold "reset" to enter setting mode; hour will begin flashing
2.Press "st/stop" to increase hours;
3. press "mode" to advance to next setting value
cheers
Posted on Mar 05, 2010
I have a DKNY NY-1251 but i need the instruction to work it because it not working with new batteries. it was working but keeps on stopping
If it is an analog watch and the second hand moves a few time then stops and sort of twitches then the watch battery (even though new) may be bad. If not the the watch is dead and needs repair.
Jul 04, 2016 | DKNY Watches
What battery is in the DKNY Ny Twist watch?
I had to look into this for my wife's DKNY watch and this particular model has a Ronda 751 quartz movement, which takes a 379 battery. You can verify this by entering the movement name 'Ronda 751' and you'll see pictures of the movement with a 379 battery inserted.
Jan 07, 2014 | DKNY Ny4634 Twist Watch
Hi. Can You replace a Crystal for DKNY ladys watch model NY-4609 Thank You.
It is probably replaceable. Try to locate a watch repair shop or and jeweler who repairs watches. If they don't have one, then contact DKNY directly.
Jan 13, 2011 | DKNY 1035 Wrist Watch
My dkny ladies watch stops when I take it off. After resetting and putting back on, it works again. Why does it do this?
mcdevito75 here, It"s possible the battery could be so ever slightly loose, or the battery could be weak and need changeing. Also possible, the quartz mechanism could be going bad and movement of the watch while wearing it keeps it going, with the watch off your wrist and at rest, it's just to weak to keep moving on it"s own. Best Bet is to look for a small watch repair shop in your area and have them check out your watch.
Aug 22, 2010 | DKNY Modern Edge Lady Watch # NY3901
How water resistent is watch??? Anyone with experience?? How about after battery replacement?
mcdevito 75 here, Usually 50--100 meters of water resistance on brand new watches. However after a battery change, unless you also change the gasket (rubber ring) on the cover, you could loose all water resistance capability.
May 28, 2010 | Casio AWS90D-2AV Wrist Watch
Dkny 1350 how to change day
Hello. Contact DKNY customer service and request an instruction manual http://www.dkny.com/contact/index.php
May 25, 2010 | DKNY 1009 Wrist Watch
Jun 16, 2009 | DKNY NY5045 Watch for Men
Watches Logo
368 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
