Question about Whirlpool Cabrio Washing Machines
My washer is saying F-51
IT WILL NOT COMPLETE THE CYCLE IS SAYING F...I DONT KNOW WHAT THAT MEANS
  • demetrice minter Feb 12, 2012
    i will not complete the cycle is saying F 51 i dont know what that means
  • 37 Answers
This seems to be a common problem. If you hit stop/start each time the washer stops, the washer will continue further, allowing you to get through a load, but that is a temporary work-around.
You will need to contact the service department, and they will replace parts to fix it. One person had success with opening the control panel and reseating the connectors.
See this thread for more information.
Posted on Feb 12, 2012
blueextc3221
  • 15935 Answers
SOURCE: at the end of the
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 18, 2010
ap1960
SOURCE: HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN SPEED.
I read that someone has a problem with F-03 on the display. I have seen this for the first time on my hotpoint wf860 1600 spin. I read the manual the only thing I can think of maybe an unbalanced load in the machine. Albeit the manual is not clear about this. P21 automatic features unbalanced load warning.
Posted on Jul 08, 2007
  • 18 Answers
SOURCE: code 51
If your unit has a serial number of CU13----- or less, you will need to have part # W10130544 installed by a servicer.
Posted on May 10, 2008
Nic61
  • 1073 Answers
SOURCE: error F10
There is a topic alryde about the F10 error
You will get your answer here
http://www.fixya.com/support/t1461650-wf840_f10_error_code_get_worse
Good luck to you!
Please take a moment and rate my answer
Nic
Posted on Feb 06, 2009
  • 6277 Answers
SOURCE: i have a maytag neptune washer and dryer and my
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 08, 2011
Keeps saying PAU
The PAU, or pause, error usually means that the washing machine cycle was interrupted and was not restarted properly. If you try to modify the cycle or start a new one before the first cycle is complete, the PAU error will appear on the display. If the washer was stopped midcycle and not restarted, the cycle must be canceled or completed before a new selection can be made. Push "Start/Pause" to allow the current cycle to finish before making a new selection, or push "Cancel" to stop the current cycle
Oct 15, 2012 | Frigidaire Washing Machines
My washer keeps saying ''Ld'' It will not finish the cycle and drain. I Have tried turning it off and even unplugged it for 30 seconds. I dont know what to do!
"ld" is a service code meaning long drainage time
the most likely problem is some lint build up in pump or in the sump restricting water flow into the drain pump
Jul 18, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
At the end of the cycle when the machine goes to spin the machine stops saying DL. I looked it up in my manuel and that means door won't lock. But it was locked the whole cycle until the end. I emptied...
Aug 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does SUD mean?
SUD means a detection of suds in the machine. These machines are very sensitive to over sudsing. Try adding just plain water or bleach to break down the suds level. They say to use 1/4 of the detergent you would use in an older machine.
If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle finish
If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My calypso is saying ''LD'' I dont know what to do for it.
Ld means long drain. Theres a problem with your pump. The pump for these washers are around 100 bucks. This is a very common with the calypso washers.
Jun 30, 2009 | Kenmore Washing Machines
Error Code LD flashes
Today (4/3/09) I got a letter from Sears. They will replace the electronic control board (you know, the F-51 business) for FREE, in warranty or not. Serial #s for the Bad Board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083. The voices of all of us have finally been heard!
Feb 06, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Wont spin
By saying it makes slight movements when it comes to the spin sycle tells me only one thing. GEARBOX.
Yes your matjien got a gearbox,clutch the works,
mostly the gearbox give a problem,but if you dont know how to check this rather go to someone that does,just get it tested...
Hope this helps.
Sep 10, 2008 | Fisher and Paykel IWL12 Top Load Washer
Code 51
Saw this in other area of blog (see below). I had same problem and Whirlpool service replaced RPS control board...fixed problem. Best Solution posted on Oct 20, 2007 2%20stars.png
446a518.jpg By wizard_s.gif eagle338
Rank: Wiz
Rating: 75%, 482 votes
there is a motor rotor position sensor(RPS) failure.
Refer page 10 of the manual below
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567036.pdf
If you still cant fix it come back here..and ask i will help you out..
And please dont forget to rate if its solved..
Aug 19, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Hoover 1300 spin 5+5 washer dryer
you don't say which cycle it will start on. however, could be cold valve open circuit which also means no rinse or cold inlet hose kinked etc. can you give more info?
Apr 09, 2007 | Hoover H120M Front Load Washer / Dryer
Sep 04, 2006 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
