Question about Frigidaire Refrigerators
Model FFHS2611LW1 code 4 problem
Freezer not freezing
Model#FFHS2611LW1 the user control panel will not let me adjust the temp it remains on the #1
Have you tried unplugging the refrigerator 5 minutes? If this don't clear the problem with the controller then the controller needs to be replaced.
User Control and Display Board 5303918341
Appliance 911 Sea Breeze
Oct 01, 2015 | Refrigerators
My Whirlpool Refrigerator/Freezer Model #GR2FHTXVQ00 or GR2FHTXVO00 is not keeping food cold. Food is spoiling. Freezer is cold but Refrigerator is warm.
With signs of freezing up in freezer area that would indicate a problem with the defrost components. The most likely reason would be a defrost control board. 2304093 Defrost Control Board
Here is a link to a parts manual for your model=> GR2FHTXVQ00.pdf(1101.27 KB) Look on page 3 and part location 4 That is the=> 2304093 Defrost Control BoardThe next possible parts are the 2314157 Defrost Heater Assembly found as item location 4 on page 9 of the PDF. It may be a good idea to change the defrost thermostat=> 2321800 Defrost Thermostat found on page 3 with item location 28. If you have questions please let me know, Thanks John TrippAppliance 911
Contact Me Here
Sep 23, 2014 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer is not freezing
Good Morning Friend,
I understand that your Frigidaire freezer is not getting cold enough to freeze your food. I suggest cleaning the compressor, underneath your appliance, by using an attachment on your vacuum. I also suggest lowering the temperature and giving your freezer 4-24 hours to stabilize at that temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dishwasher status has changed successfully. If further troubleshooting is needed, please leave me the model number of your freezer. Hope this is helpful.
-Best Regards-
WP
Jun 11, 2014 | Frigidaire Freezers
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
Service code e9
If is is still freezing, just have it looked at. I think this code on this model is a freon leak. I. Am not sure though.
Feb 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer is freezing up after 3 or 4 days. Fridge
the freezer fan should be running not pulsating, I would have to say thats your problem since most systems can run 3-4 days with out proper air flow, most wont survive much longer
go to www.appliancepartspros.com
type in your model number
look in the freezer section
order anew fan motor
the picture should show you haow to break it down to get it out
Oct 22, 2009 | Refrigerators
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
Refrigerators Logo
59 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
