Question about Motorola Walkie Talkies 2-Way Radio
Where can i get battery charger for motorola walkie talkie mdl sk 700
msmichalko
  • 17 Answers
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
Posted on Jan 09, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
eradiostore
  • 1654 Answers
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
Posted on Jan 07, 2009
eradiostore
  • 1654 Answers
SOURCE: problem charging
If you are referring to a flashing yellow light on the charging base, this is an error code. Either the 1) battery is bad, 2) not making good contact in the charger, or 3) very very low on charge. The solution for this set of problems is as follows: 1) have the company you purchased them from replace them, 2) clean your contacts with a pencil eraser, 3) leave the battery on the charger with the yellow light flashing for an hour or two. If the battery is just very low on a charge, it will come back to life and the light will change to be constant. If the battery is bad or shorted out, the light will continue to flash and you will need to get with the vendor you purchased the batteries from.
Other things which come to mind are compatibility issues such as you are using a different battery chemistry than you had before. NiCd batteries can charge on either of the two chargers available for the P110 (slow rate or fast rate). However, NiMH and Li-Ion batteries require a fast rate charger.
If you are referring to a yellow blinking light on the radio while it is in the charger. You need to shut your radio off. Radios should always be turned off when charging. If the radio is left on you will never have a full charge. Also, if you inadvertently press the PTT while the radio is turned on, while on a charger, you can cause damage to the radio.
FYI: There is no light to show "out of range" on the radio, unless you are possibly using a trunking or repeater system. A blinking light on your radio indicates the radio is turned on and/or there is traffic on your frequency. Your charger base light can be red, yellow or green. This indicates the charge cycle status. Flashing most always means some type of error.
Best regards
Posted on May 20, 2009
eradiostore
  • 1654 Answers
SOURCE: I'm searching for a User Manual Walkie Talkie T8550R Camo
I think you'll think this is fantastic: http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Best regards.
Posted on Nov 14, 2009
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Sep 28, 2014 | Motorola Walkie Talkies 2-Way Radio
Motorola t8510 walkie talkies- need manual
http://shop.giantintl.com/Manuals.asp?offset=30
Sep 11, 2013 | Motorola Walkie Talkies 2-Way Radio
Ok i baought 2 Motorola MJ270R walkie talkies, Then i found 1 more with no charger or anything at my moms house, And there all the exact same walkie talkies there all MJ270R Walkie talkies, And was w
Hello Ty,
Tis a problem you have there, however I would advise you take one of your radios to radioshack or similar store, and the folk there should be able to assist in finding the apropriate chargers for you.
I hope this helps you in your quest.
Cheers,
Peter
Mar 08, 2013 | Motorola Walkie Talkie 2-Way Radio
What will happen if i overcharge walkie talkie for 3 days?
You will age your batteries some, by them being left on the charge. However, for a weekend or 3 days on occasion, you will cause no serious damage. However, if you were to leave them on an extended time, say 10-30 days, you could conceivably "cook" the battery and cause it to fail.
Many modern chargers have a safety feature where they will go to trickle charge after a battery is full.
Best regards.
Feb 10, 2012 | Motorola Walkie Talkie 2-Way Radio
When I place the walkie talkie in the charger base, the light indicator does not come on. I've put new batteries in the walkie talkies. Also, on another walkie talkie, it constantly shuts off when I...
Generally when a radio shuts off when you press the PTT button it is a sign of a bad or poorly charged battery. It takes more energy to transmit than to receive. The fact you have a charge which the light does not come on indicates you have a bad charger or bad connection between the radio and/or battery and the charger. Clean your battery contacts (on both radio and charger) with a pencil eraser and see if it clears up the problem. If not, you have either a battery or charger problem.
Best regards.
May 25, 2011 | Motorola Walkie Talkie 2-Way Radio
The battery is fully charged on the walkie talkies and all are on the same channel, however out of 12 walkie talkies only 2 will work. When ever you push the push to talk button the walkie talkie shuts...
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
Nov 09, 2010 | Motorola Walkie Talkie 2-Way Radio
Walkie talkie batteries don't last
The Batteries that Motorola uses will die after a while mainly because people leave them on the charger all of the time. But there is a way to refresh them. You let the battery die completely, then you charge it up for about 12 hours. Then you let the battery die completely. Do this a couple of times and the batteries will last long.
Also, Motorola use to make a battery refresher (or did when I worked there.) It will charge and drain the battery automatically. It will even give you a fault if the battery is completely dead. For the HT1000 (for example) it would be the WPPN4065BR.
For future reference, don't constantly charge a battery. Only have it on the charger when the battery is actually dead or very low. This will increase battery life.
Mar 25, 2010 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Motorola Walkie Talkies 2-Way Radio Logo
85 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
