Question about Neff B1421 Electric Single Oven
Oven tripping rcd
When the oven is plugged into it's designated 13a outlet,(fed with 6mm) it throws the RCD when about 190-220 degrees, but doesn't blow the plug fuse or the MCB. However when plugged into a socket on the 2.5mm Ring main, it doesn't trip the RCD. The 13amp plug is fine and I've changed the socket outlet but still tripping the RCD.
3 Suggested Answers
SOURCE: Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Posted on Nov 02, 2009
  • 106 Answers
SOURCE: keeps tripping out rcd 63 amps when warming up
If your oven is rated above 14kw then change the RCD to 80A. But if its rated less than this then please check shorted element and change them
Posted on Jun 19, 2010
Advice on RCD tripping
yes
an accredited electrician can test the circuits for insulation failure , vermin shorting across active / neutral/ earth points and the rcd itself
it is not a diy job
May 12, 2017 | Ovens
I have a eurolec double built under oven. When I turn the bottom oven on the rcd at the house consumer unit pops. The top oven works fine...
The elements in ovens consist of an outer earthed metal tube and an inner resistive element that is insulated from the outer tube by what is effectively a compressed ceramic insulating powder. If the element is not used for a while, enough atmospheric moisture, (or from spills, etc), can penetrate the insulation to cause enough earth leakage to trip the RCD. If the RCD is tripping at the correct level, (They can get too sensitive - see this article here:
Diagnosing RCD earth leakage breaker nuisance trips), then the only long term solution is to replace the element, although they can sometimes be dried out by heating them.
Aug 11, 2014 | Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Oven not producing any heat
just the oven? then more than likely the element. if the stove eyes are not working as well, then your looking more at a sensor, thermostat, fuse, breaker, etc. almost always an element though
Mar 20, 2012 | Electrolux Ovens
Keeps tripping out rcd 63 amps when warming up after about 10 minutes
Jun 18, 2010 | Neff U1721 Double circotherm Electric Oven
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
May 02, 2009 | Siemens Ovens
Neff B1421 Electric Single Oven Logo
50 people viewed this question
Top Neff Ovens Experts
ashburton
paulcarew
bobby1964
Level 1 Expert
Are you a Neff Oven Expert? Answer questions, earn points and help others
