Velodyne FS12 Subwoofer Problem
My Velodyne sub has worked perfectly for several years. I just moved to a new home and set up my home theater system. When I turn on the sub there is a loud hiss coming from the speaker. I already have a Mondial Magic on the incoming cable line so that is not the problem. I have disconnected the rca cables from the sub and the hiss is still there with only the sub plugged into the wall. Additionally the sub thumps when I turn it off. It is already set to the auto position. Is the subwoofer bad??? Am I missing something??? Please help if possible....
  • ame21703 Dec 29, 2008
    I've got a Velodyne FS10 Subwoofer that is exhibiting the same problems, and NOT for the First time!!! I Recently(within 7-9 mos) had to HAGGLE w/Meyer-Emco And Velodyne reps regarding the cost to replace the circuit board, which evidently Fried the last time this problem surfaced. Velodyne did Not offer Me anything, but offered to reduce the cost to repair the board by a couple Hundred bucks! My initial cost for this back in early 2000 was about $1k, but the cost to replace the board was about HALF(~$500), which I told Both Both Meyer-Emco And Velodyne rep's was RIDICULOUS, considering I Always took Very good care of the unit and NEVER powered it higher than about 1/3 of the way! I let them BOTH know that a HIGH Priced unit such as this one SHOULD Last at Least 20 yrs w/out a problem, as I STILL have 2 Pioneer HPM spekears that have endured 2 diff. receivers w/diff watt. outputs and are OVER Thirty Years od and Still pumping out good sound!!
    Neither one accepted my thinking and BOTH were of the mindset, "you want it fixed, you have to pay the price". I was VERY Disappointed in BOTH Meyer-Emco's AND Velodyne's attitudes and just this past weekend had the EXACT SAME Problem occur after powering off a circuit the Velodyne Sub was connected to(after numerous other times) & then powered it back on only to find it Humming Loudly, even with the Monster cable to the Marantz receiver unplugged!
    I am LIVID that a company such as Velodyne can produce(WHEN it WORKS!!!!) such a High quality product, but REFUSES to back it up w/Any kind of Legitimate Warranty!!!
    Subsequently, I am in the market for a new Sub for this audiophile, as I've HAD IT w/Both Velodyne AND Meyer-Emco!
    Problem Solver:
  • 10 Answers
I regret to inform you that it sounds like the velodyne's internal amp has a problem and will likely require servicing.
Posted on Oct 24, 2008
Soundbar doesn't pair with wireless subwoofer
It occurs to me that if the sub is no longer sending signals back to the unit then it won't find it. I am certain that it should be easy to have the sub repaired so that it does send out the signals.
Nov 14, 2015 | Audio Players & Recorders
Tip
Tip for your home theater system: tweak your subwoofer level and crossover...
An important tip regarding your home theater system is to Tweak subwoofer-level and crossover controls:
Test tones and meters aren't the final arbiters in the bass department. If your sub's bass is boomy, thick, or uneven, first try lowering its volume --most people complain that their sub louder than necessary. Next, if your satellites are very small, the crossover control should also be set to its midpoint or higher. Bigger speakers produce more bass on their own, so they sound best with the sub's crossover knob set at or near the bottom of its range. Finally, moving the sub out of the corner and closer to one of the front speakers may produce smoother, flatter bass.
on Aug 23, 2010 | Audio Players & Recorders
Hookup instrutions for a velodyne sub/amp serial number 63311523
manual is here:
http://www.velodyne.fr/index_htm_files/cht-8_cht-12_manual.pdf
Mar 19, 2015 | Velodyne CHT-8 Subwoofer
My subwoofer doesn't seem loud enough. I have it set to 80%. Is there other settings that might solve this problem?
Bas response is highly dependent on room boundaries, speaker placement and relative listening position.
Page 13
"Place the subwoofer at the corner of the
room. Otherwise, keep it at least one
meter away from the TV."
http://www.retrevo.com/support/Philips-HTS3555-Home-Theater-Systems-manual/id/2869dj188/t/2/
You might experiment with moving the sub around.
Jan 16, 2011 | Philips HTS-3555 System
I have connected the subwoofer to the pre-amp out
One of two things may be going on.
The amp has a fuse mounted on the PC board. The fuse may be blown.
The speaker may be bad. that may have blown the fuse.
You can test the speaker with a "D" battery.
Take the amp section out of the back, disconnect the speaker leads.
Touch the speaker leads to the poles of the battery. it should make a little thump and the cone should move freely.
Contact Velodyne for service.
Dec 21, 2009 | Velodyne CT-80 Subwoofer
Velodyne sub woofer: Series S Model: VA08BVX10
The volume control pot can be replaced.
Any good quality audio shop or electronics repair shop should be able to fix this.
Nov 17, 2009 | Velodyne SPL-1000 Subwoofer
Can't figure out how to connect a subwoofer to my RCA RTD315W
HI,the rca system should have a sub pre out socket,plug a phono cable into this then to input on your sub and set volume to half way,also make sure the sub is set to on in the setup menu on the system.
Hope this helps.
CABLE GUY.
Apr 18, 2009 | RCA RT2500 System
The subwoofer lites but no sound
Have you gone into the menu settings and adjusted the sub woofer volume, some factory settings are set @ zero.
Sep 09, 2008 | JVC TH-M55 System
How to connect pioneer reviever to velodyne subwoofer
Look for the sub pre out on the back of your amp and connect a sub cable to this and next to the LFE or phono type input on the back of the sub ,if it has two inputs left and right pick the left side ,set the cross over to suit your system and speakers,if you are not sure set the cross over to 80 hertz,this is a thx standard.
hope this helps.
CABLE GUY.
Dec 27, 2007 | Velodyne DPS-12 Subwoofer
Kenwood Home Theater
Please update your post with any Model Numbers that you can retrieve, especially the subwoofer. Off hand, and with the limited amount of information that you have provided, I would GUESS that your subwoofer is simply overheating, and is being shutdown internally, hence protecting the fuse because no short is detected. If you haven't moved and or vaccuumed/cleaned around or near your system regularly, dust, pollution, pollen...you name it, builds up and can easily prevent electronics from breeathing/venting properly.
Jul 31, 2007 | Kenwood HTB755DV System
436 people viewed this question
 Grubhead
Grubhead
