Question about Refrigerators
GE TBX-18k freezer works fine, refridgerator does not stay cool
  • 103 Answers
SOURCE: freezer works refrigerator doesn't ge tbx-25zle
Hi: Your defrost heater or defrost timer is bad. There is an off chance your freezer or fresh food compartment are so full they block the airflow. If not full, Remove the food from the freezer, unplug the ref. and hit the back wall of the freezer with a hair dryer. Avoid plastic components as they will melt. When your defrost mechanism fails frost will form where it shouldnt and block the airway to the fresh food compartment. That's why the freezer still works. That will get you a week or two of fresh food getting cold. If your'e handy remove the back panel of the freezer at the bottom will be a glass tube with a metal coil in it. If the coil is broken buy the new defrost heater and install it. If not look for a defrost timer. Use the model number of the refrigerator to find the part. www.searspartsdirect.com will have a parts schematic to help you find out where the timer is located. There shipping is high so try to buy it locally. I hopes this helps, Jeff
Posted on Jun 25, 2009
  • 19 Answers
SOURCE: refridgerator cooling problems
check the refrigerant level or efficiency of the compressor.if it is a frost free fridge,check that the fan is working ...oh and could also bee a blockage in the system.change drier properly vacuum and regass system.
Posted on Nov 05, 2007
  • 1122 Answers
SOURCE: fridge was in storage 4months fan work but not freezing.
is there ice building up in back of freezer?mike
Posted on Nov 11, 2008
SOURCE: Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Posted on May 17, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Refridgerator & freezer not cooling much, ice crystals on inside of freezer
Need you to unplug and remove the back panel in freezer to examine the evaporator coil. Check the defrost element and the defrost thermostat. On the back of the refrigerator is a main control board located behind a panel screwed to the refrigerator back. With the power off through all of this I need you to inspect the control board for burn marks on both sides. Click on link below and enter your model or 1 of 34 models like yours. Place model GSH25JFR in model parts search this will lead you to the many similar models like yours. On diagrams on left of your screen count eight down that shows the circuit board. If no burn marks I will tell you how to test the other parts I mentioned,
Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 21, 2009
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Freezer working but the refridgerator not cooling and the light is not working
If the freezer side is working fine and there is no cooling or lights on the refrigerator side, you will need to replace the control board. Here is the part to order.
Oct 28, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Freezer works fine but top refridgerator won't cool
HI.TRY DEFROSTING IT ALL FIRST.IT MIGHT WORK.GOOD LUCK.ALI
Jun 25, 2012 | Maytag Refrigerators
I have an older side by side GE refridgerator model number TFXC222J. The freezer section is working but the fridge side is not cooling. light works.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | GE Refrigerators
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
GE Side by Side Not Cooling
Hi , the refrigerator having problem with enfeller fan stuck it needed to defrost manually to drain all ice buildup inlet of refridgerator hole after 3 hour try start refrigerator.
Feb 05, 2008 | GE GSS25JEMWW Side by Side
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
