Question about Kyocera Copystar CS-1820 Black and White Copier
Kyocera km-2820 averia c7990 - Kyocera Copystar CS-1820 Black and White Copier
  • 43 Answers
SOURCE: error code C-6 for kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
Posted on Mar 02, 2008
KyoDoc
  • 38 Answers
SOURCE: KYOCERA CS-1820 ERROR CODE C7990
Apologies for the late reply. This is a waste toner full problem. Pull out the process unit (in case you don't know, it's the big black unit where you fit your toner into, also the one that you need to remove to check for paper jams. Turn it around so that the side where the toner fits is furthest away from you. Now on the side closest to you, on both the left and right hand side are two small covers, each fastened with 1 screw, hidden in deep holes. Remove these screws and covers, and empty the toner inside.
Be advised that this is a very messy job. Also, after you've removed these covers and you turn the unit on its side, the toner may not fall out. in this case stick a screwdriver or something in there to loosen the toner.
When done, refit the covers, place the unit back into the machine, restart the machine, and thats it. If the code still appears, you've got toner on the waste toner full sensor, which sits just above where the waste toner part of the process unit is, inside the machine. you can take a cloth and wipe this. although this is highly unlikely, nothing in this industry surprises me anymore.
if this still fails, you could have a faulty sensor or circuit board, but again, highly unlikely
have fun (nothin like gettin your hands dirty) ;)
Posted on Sep 18, 2008
  • 143 Answers
SOURCE: Kyocera KM-2050 scanner
You normally enter this information using your web browser and typing in the IP address of the scanner.
Hope this helps.
Posted on Jul 07, 2009
SOURCE: my kyocera has an error
Remove the drum unit and reinsert it back in the machine again
Posted on Dec 02, 2010
rodrigomp
  • 9 Answers
SOURCE: BUENAS TARDES MIRA TENGO UN
simple, clean the waste toner simples, limpe o reservatorio de toner usado.
http://www.youtube.com/watch?v=oMysn3Jnpts
Posted on Oct 11, 2011
How to receive fax from my kyocera km-2820
First perform a U906 to re-enable a disabled cassette, if this does not work replace the lift motor, if this does not work, replace the engine board. On the KM/CS-3050,4050 and 5050 chances are if the lift motor is bad you will have a shorted transistor and an open load resistor bad on the engine board caused by the lift motor going south.
Jun 29, 2015 | Kyocera Office Equipment & Supplies
Repair kyocera fs-1028 mfp machine failure call service c7990
developer unit fitted correctly or failure of developer unit .
May 21, 2014 | Kyocera Mita Kyocera FS-1028 MFP Laser...
Km 2820
What error code are you getting? It could be a lot of reason for paper to get stuck, there is always a error code associated with each jam
Nov 23, 2013 | Kyocera Mita Office Equipment & Supplies
KYOCERA MACHINE FS1124 CALL SERVICE C7990 PROBLEM
This means that the waste toner container is full.This is located in the drum unit and is designed that the drum should be replaced with a new unit
Aug 01, 2013 | Kyocera Mita Office Equipment & Supplies
Error occured call service person C7990
What to do if the current display is "Machine Failure Call Service C7990" but few days ago it displays "Toner Waste Box is Full".?
May 23, 2012 | Kyocera Copystar CS-1820 Black and White...
My photocopier has been displaying this error code message C-7990 a photocopier kyocera KM-1500
C7990 is
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
Mar 05, 2011 | Kyocera Copystar CS-1820 Black and White...
Kyocera Copystar CS-1820 Black and White Copier Logo
219 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
