Question about Kitchen Appliances - Others
Barcrest LCD meter location - Kitchen Appliances - Others
Mpu5 error codes barcrest
I have a cash beast machine, whenthe unit is powerd up, nothing happens, the mpu5 had got the -12v and the 34v leds on but nothign else, i have looked over the board to check the various status leds and as far as i cansee all of them are on, could this be a power supply problem, or is the card dead, does anyone know what/where i could look to see if i can find the fault, i do have 2 power supplies,. and both leave in the same state, i am tempted to say its not the PSU.
Read More.. HP Printer Support
Thanks,
Aug 18, 2014 | Office Equipment & Supplies
V3 change meters to yards
MODE and UNIT OF MEASURE OPTIONS
The TOUR V3 can be used to measure distances in yards or meters. The unit of measure indicators are located in the lower
right portion of the LCD. To select between yards and meters, press and hold the POWER/FIRE button. The display will
begin to cycle through the setup options: Yards w/JOLT, Yards, Meters w/JOLT, Meters (for details on the JOLT feature,
see "About JOLT"). When the units and JOLT mode you want to use are displayed, release the POWER/FIRE button to
select it. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the
M for meter indicator while the Y for Yard indicator is turned off. If you are changing from meters to yards, the opposite
will occur. The TOUR V3 will return to the last unit of measure setting used each time the unit is turned on.
Aug 03, 2014 | Bushnell Tour v3 Rangefinder With Slope
V3 not jolting
The TOUR V3 can be used to measure distances in yards or meters. The unit of measure indicators are located in the lower right portion of the LCD. To select between yards and meters, press and hold the POWER/FIRE button. The display will begin to cycle through the setup options: Yards w/JOLT, Yards, Meters w/JOLT, Meters (for details on the JOLT feature, see "About JOLT"). When the units and JOLT mode you want to use are displayed, release the POWER/FIRE button to select it. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the M for meter indicator while the Y for Yard indicator is turned off. If you are changing from meters to yards, the opposite will occur. The TOUR V3 will return to the last unit of measure setting used each time the unit is turned on.
Feb 12, 2014 | Optics
Alarm says 17-83 opto blocked tamper
Hi did you every solve this problem? i have the same problem currently
Jul 19, 2009 | Kitchen Appliances - Others
No espresso
I had the same problem and found out that the flow meter was not working. The control unit was not getting flow information and after about 5-10 seconds it will just stop and blink all the lights. I replaced the flow meter and solved the problem. The flow meter is located between the water tank and the pump.
Aug 24, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Fruit machine manual
Hi i have a barcrest vivid gaming machine, rock around the clock and i need a service manual can anyone help.
Aug 08, 2008 | Video Game Consoles & Games
Spot metering on the Epson 3000z
The spot meter area is small because I have photographed 2 people side by side many times, focused on ones chest then found that the "spot" had slipped into the little space between them, the bad focus not really showing up when I checked the LCD. (My eyes are old and so are my glasses.) Got home and found useless pictures. Sometimes I was outdoors in the sun and couldnt check the LCD. Some of the threads say the focus spot is "off center" with no acccurate way of finding it when using the viewfinder. I take some beautiful, wonderful pictures but these errors really tear me up. I've got to get the LCD box viewer with the 2x lens viewer I guess. All those years as a 35mm Canon F1 user I would long for a spot meter almost daily. Now I see that a matrix meter AND a spot is the real choice. I hope eventually to learn to outwit my 3000Z because it does give me such excellent pictures. Sometimes there is noise on a face, sometimes it is the focus and at functions it is so embarassing to ask a principal subject to wait because the *** or ***H procedures take so long. A wedding, other than the reception, would be near impossible in *** or higher. Good Luck, Dav.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Kitchen Appliances - Others Logo
24 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
