Question about AT&T 1722 Digital Answering Machine
When someone is recording, the machine will pick up thier voice, but after 15 seconds there is a static noise that makes it impossible to here the rest of the messsage. HELP!!!!
    New Friend:
Get static on the machine
Posted on Jan 12, 2013
2 Suggested Answers
  • 68 Answers
SOURCE: static in the recorded message. AT&T model 1738
The microphone (located inside the unit and faces downward towards the surface below the answering machine) might be defective. One option would be to call into the answering machine and try recording your message that way.
Other than that, there really isn't much you can do for this problem other than replace the unit.
Posted on Sep 14, 2009
I used a voice recorder and when I tried to listen back to it, it had the tv and other background noise. What can I do to pull the voices out to understand it better without the other noise?
If it has a switch labeled conf/dict , put this switch in the dict mode. This switch is a record sensitivity control, in the conference position it will pick up almost any noise in the room. In the dict,position which is short for dictate, it will have less record sensitivity and will only pick up sounds very close to the microphone and eliminate background noises
Nov 08, 2014 | Audio Players & Recorders
How do I remove hum from my recording
Its Pretty simple
All you've to do is Download AUDACITY its a freeware Program
Then load the Sound file
And THERE Should be an option at top "EFFECTS"
Click that and Find
Noise Removal
Click Noise REMOVAL and there should be a button saying
"OBTAIN PROFILE"
Click that and Choose a fine starting of recording which Includes Noise
NOTICE
WHEN YOU'LL RECORD , LEAVE THE RECORDING ON SOMETIME SO IT CAN OBTAIN A NOISE PROFILE
Okay
So choose that part and then click
Obtain Profile Button
And then Choose the Whole song
and Go again to noise removal and BAM!
that's it
Sep 21, 2014 | Audio Players & Recorders
Static Noise
Is it a hissing noise or a distorted crackling noise? If it's a hissing noise then it's due to a bug in Windows that adds 30 dB of gain. It's easy to work around, though: Go into Recording devices, Properties button, Levels tab, right click on the level number so that it shows in decibels, and then adjust the level to 0 dB. It's supposed to be at 0 dB but Windows 7 defaults it to 30 dB for no reason. This isn't a problem on Windows XP or OS X.
Jan 04, 2012 | Samson G-TRACK USB RECORDING MICROPHONE...
Static noise when playing back recording, sounds like the wind
This camera has a single Mic - make sure your finger isn't over it though -- try making a recording in a closed room - no wind noise - is there still static ??
Go through settings and see what choices there are -- like outdoor , indoor . close to subject etc.
My CAM had a close up and background button - which was a sensitivity setting - and the background setting picked up EVERY sound from miles around and filled the tape with noise. The close up setting only picked up sound from bout 2 - 3 meters.
Do you also have an external plug for a Mic ? this would also check whether it's the camera mic or recording that is at fault ??
Ray
Mar 07, 2011 | Samsung SC-X105L Memory Card Camcorder
How can I clean up a recording that is full of noise & static?
I Don't know of any Olympus proprietory program to remove noise but if you can export it to a .wav format, it can then be edited and cleaned up digitally buy any semi pro sound editing software.such as sony's Sound Forge or cubase? cakewalk. software used for edit old records for conversion to cd may also help here. From there you can then save to cd for playback. If sound editing is beyond you, contact a recording studio or media house that produces commercials, they may be able to help.
Hope this is helpful
Jan 15, 2010 | Olympus VN-4100PC Digital Voice Recorder
I can fax out but I can't receive faxes.
What happens if you dial your fax number the way you make a normal voice call? Does the fax machine pick the line up? Can you hear it making electronic noises? Do you hear any static or line noise?
Try also putting a regular phone on the fax line and attempt to make voice calls to test the lin quality. Listen for static, noise, volume issues. Report problems to your telecom company if you have trouble in voice calls.
May 06, 2009 | Office Equipment & Supplies
Sanyo Transcribing Machine - model unknow
The motor has gone and would need replacement. Unfortunately, this part was recently discontinued so you will have trouble finding someone who has one.
Nov 07, 2008 | Sanyo TRC-8080 Desktop Cassette Voice...
Telephone recording
Yeah, um connect it to a phone in a room that is normally isolated from traffic. Not an ideal solution but as it is a machine and has only an external mic (it doesn't have an internal mic does it?) this is the only solution really, remove all noise except phone conversations.
Sep 25, 2007 | Denpa USB-24 Digital Voice Recorder
AT&T 1722 Digital Answering Machine Logo
118 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
