Question about Kenmore Refrigerators
Wiring diagram to kenmore to IMBD03-011 icemaker
4 Suggested Answers
  • 979 Answers
SOURCE: GE refrigerator wiring diagram
Icemaker must be at 28 degrees to make ice. The harness supplying the power should have 120 volts there at all times, and the icemaker itself is the device that switches the power off and on once all requirements are met. Your diagram for the fridge is on the rear service panel, or in a packet on the insisde rear..accordianman
Posted on Apr 03, 2008
SOURCE: kenmore icemaker does not work
Hand drawn of the GE # WR30X1009 found in 10-12 yr old Kenmore/sears/GE side by side refers. Couldn't find one ANYWHERE so forgive the hand drawn. Mine would not eject ice, intermintant. Bad microswitch on the on/off/vacation mode between the normally open side.
Posted on Apr 30, 2009
  • 1218 Answers
SOURCE: I have a Kenmore refri/freezer model 106.7687460.
Good day,
the defrosting control is a part of the ice maker. If you don't care about appearances, you can wire around it.
First, you have to buy a 8 hour 20 minute Whirlpool defrost timer.
Any sharp appliance parts house counter guy will know what you need. It comes with one of the clock wires un-attached.
As well, you will need 4 insulated 1/4" female spade connectors.
Buy spares to be safe.
Cut the cord from the old ice maker at the ice maker.
There will be 5 main wires and a green ground wire.
Strip about 1" of the green wire's insulation.
There will be 5 wires left. red-orange-black-pink-brown.
Tape the brown wire back it will not be used.
strip back approx. 1/4" of the remaining wires. crimp a spade connector to each of the 4 remaining wires.
The terminals will look like this.... | | | | on the timer.
Notice the space between the first terminal and the second, compared to the rest.
We will call the terminals on the timer from left to right, 1,2,3,and 4 even though the timer will say differently.
Connect the loose wire on the timer to terminal 4.
Plug the red to #1, Orange to #2, black to #3, and pink to #4.
Plug into machine, and run to test. If O.K. then........
Using high quality electrical tape, tape everything exposed well.
Mount the timer to the wall using one of the left over holes from removing ice maker.
Drill a tiny hole, close to that area, and using a good self tapping screw, attach the green grounding wire. Detail your work as necessary.
It's ugly, but it works. Actually, I install the timer inside the case after gutting the works. If you want to try that, DO NOT cut the cord, as explained at the beginning.
Note: Some supply houses may still sell the adapter, already made up. You can check. In either case, you must have a timer in the circuit for defrosting.
Posted on Dec 03, 2009
Testimonial: "Thanks for the help"
Where is the on-off power switch to the ice maker 0n the elite kenmore bottom freezer refrigerator?
On the side of the icemaker, there is a thick stainless steel wire or "bale" that is pushed up by the ice so the bucket doesn't overfill. Gently raise this wire while grasping the bottom of it and lift up until the wire stays in the upright position. This shuts the icemaker off.
Feb 05, 2015 | Kenmore Refrigerators
Kenmore elite model 50592000 ice maker problems
Note that the temperature in the freezer must be below 10 degrees F for the icemaker to cycle. The icemaker line is the smaller line (1/4") located in the back of the machine that runs from the valve to the filll tube. To test the valve and icemaker you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked "M" and the other in the cicle marked "N". Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Before doing any of the above though check the fill tube to be sure the no ice is blocking water from coming in.
Jun 02, 2012 | Kenmore 55603 Side by Side Refrigerator
Kenmore side by side is not making ice
May 30, 2012 | Kenmore Side by Side Refrigerator
Replace icmaker on kenmore
Unplug refrigerator. Take a moment to examine how the icemaker is positioned in the freezer compartment prior to proceeding (e.g.: water inlet tubing coming into the icemaker, etc.). Remove or loosen (where applicalble) screws holding icemaker. Unplug icemaker's wire harness connection. install new icemaker by reversing the screws harness, etc. Make certain that the new icemaker is in the "on" position. Plug the refrigerator in. Allow approximately 6 to 8 hours (some models take fewer or longer timeframe) for ice production.
Feb 10, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
How to install Kenmore icemaker
2 screws on top of icemaker into wall (loosen almost all way) 1 screw bottom remove. pull IM up and off of 2 screws and disconnect wiring plug from IM (depress tab). reinstall in reverse.
Jun 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icemaker not getting water
have you checked the fill tube on top of the ice maker for a ice clog? If so that usually indicates that the water solinioids in the back side are leaking thru the seal and are constantly letting water past the valve.
Apr 05, 2009 | Kenmore 55212 / 55214 / 55216 / 55219 Side...
Kenmore icemaker does not work
Apr 03, 2009 | Kenmore Refrigerators
No water coming down tube in kenmore ice maker
Hi!!! make sure your icemaker filling tube is not blocked with ice.its where the water comes into the icemaker .it can freez on you.put a hair dryer on to the filling tube and icemaker for 30 minutes. Also you can jump start the icemaker by putting a jumper wire show in this picture .If no ice then go to the back your frig and change your water valve ..
Jan 04, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore icemaker won't work
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Oct 26, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Feb 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
474 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
