Question about Canon PIXMA Office Equipment & Supplies
Mx 360 incomplete transmission result ng #059
Incoming fax ok, but while faxing after dial tone error message incomplete transmission
SOURCE: MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Posted on Apr 25, 2008
kram26
  • 544 Answers
SOURCE: connot send fax
thank you for using Fixya.com.
please try to log it off and check carefully the plug if it is connected properly. like the connection to line and unit.
try to switch on again..
thanks,
Posted on Feb 18, 2009
FixinFax
  • 3085 Answers
SOURCE: Incompleter transmission causes? Result NG?
It means No Good. 5 possibilities:
Receiving machine unplugged
Not a fax number
Wrong fax number
Busy signal
Digital Phone Line
Posted on Jul 17, 2009
SOURCE: Canon MP530 - Fax - ERROR TX Report - NG
Hi flyme.. I have the same problem but on an MF5770 all in one MFP. If anyone can solve this then wow.. I've been trying to find a solution for over 18 months now...
Posted on Jul 30, 2009
doron_c21
  • 387 Answers
SOURCE: canon pixma mx 860, I
its a message from the modem in the fax
make sure the line is ok and he cable connected to the right place
if not helping than its better to send to service
Posted on Aug 23, 2010
What does transmission report cdoe NG290000 mean on a Sharp MXM363n MFP When trying to send a fax?
My recommendation would be to hit the speaker button when sending a fax to hear why your fax wont go through.
When you hit speaker you should have a clean dial tone, then when you start dialing and the tone stops make sure you don't have any static or noise on the line.
There are several reasons you might get a NG error. One is the fax line you're trying to send to is busy. Maybe it's a phone line not a fax you're trying to send to. Maybe you need to dial a 1 or 0 for long distance, maybe your fax line has noise on it.
Using the speaker can help troubleshoot what the problem is.
Jun 12, 2014 | Sharp Mx-M363n Copier, Printer & Scanner...
Ng error
The first step is to make sure the fax line that the copier is plugged into is good. Plug a handset into the outlet and make sure you have good dial tone. Make sure you don't have to dial any prefix to get an outside line, such as 7 or 9. If those checkout, check all the connectors going into the fax board, make sure all the connections are correct and seated properly. If those all check good then it will probably be a bad fax board and it will have to be changed.
Mar 28, 2013 | Cannon Office Equipment & Supplies
Can't send fax. Getting transmission verification report stating NG: poor line condition/ out of memory. HELP!!
There are two possible reasons why your printer display the error message.
1. Poor Line Condition
- electrical interference on the line -Make sure electrical or electronic appliances do not interfere with the printer's phone line
- poor line connection - If you have a phone try connecting it directly to line outlet. Listen to the dial tone, if you hear noisy and static, then you will need to call your local telephone company cause there is a problem in your phone line. If dial tone is clear and stable then try checking the telephone line cord that you use to connect your printer from the line outlet, replace if broken.
- alarm system or another device on same line, these interferes with transmission / reception of the fax machine. Try connecting the printer all alone and then try sending a fax.
2. Memory Full
- There is no space to store incoming fax messages. Delete all stored fax messages.
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
Canon pixma mx 860, I try to fax and get msge NG #059 TX Canceled: RX Fax info mismatch What do I do?? Canon faxing has been one problem after another for me.
Aug 23, 2010 | Office Equipment & Supplies
No fax transmission
Plug the phone line into the plug marked L on the back, make sure you are dialing the full number, The fax won't work in an office with digital phone service, you need an analog phone line like at home. In fax setup you need the type of dialing set properly, tone or pulse dialing, check also with Canon support, 1-800-828-4040
Feb 01, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Not a fax number
Wrong fax number
Busy signal
Digital Phone Line
Jul 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Jun 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Brother IntelliFAX 4100
First plug in a normal tone tellefone into the wall jack that your fax is using.Make sure you get the fax signal from the faxnumbers you struggling with.If you can hear any line noises on the line it may be the problem why you cant get a fax trough.Make sure your fax is set on the correct county code-tone or pulse.
Oct 29, 2008 | Brother IntelliFAX 4100 Laser Fax
Error 401 & 634
error 634 is an indication that the line was either busy, or there was no answer on the receiving end.
Jul 23, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Fax busy, no response yet fax is sent ok
NG or poor line condition on the transmission report means that there is interference on the phone line.you need to double check the quality of the dial tone-if it static or clear.now,other interferences could be caused by other devices on the same line as your fax such as DSL modems.make sure first that you connect the brother machine directly to the walljack and try resending a fax.modem settings can be changed.e-mail me if you need that info
Mar 18, 2008 | Brother IntelliFax-2820 Laser Fax
165 people viewed this question
old marine
old marine
