Question about Samsung SGH-D600 Cellular Phone
Turns on but nothing comes on screen
I just had to replace my screen cable after fitting a new housing. The phone switches on making the usual sound but nothing comes on screen. Could it be that I have not fitted the cable right. Followed a video on line but it was not very clear. Thanks very much
    Brigadier General:
  • 7,752 Answers
Take the phone and have them checked the phone for you to determined what is happening
Posted on Oct 26, 2008
I have Vizio I changed cable from Dish Network to a Local Co. now I can't get cable or sound, although the cable box is all lit up. I get a blue screen with no signal running across it and I have
check with whoever is your current signal provider---paying for service they will usually come out and make sure it is working either via the coax fitting or via the audio/video jacks
May 17, 2012 | Vizio Televison & Video
Light switch turns on when cable plugged in; however, the treadmill is not starting. Please help. Nothing is coming on the console.
You need to be on the console for it to start. (I presume you are on it). Make sure the screen and console are properly connected.
if this is a new device, call the service technicians, they would know best. This device has a known problem with the console.
May 22, 2011 | Life Fitness F3 Folding Treadmill
My running lights work but by break light wont
Check the bulb first. There are two filaments in the bulb, one for the brake light and one for the tail light. If the bulb is good, there are two switches that turn the brake light on. One is on the front brake lever and the other is a pressure switch in the metal brake line from the rear master cylinder. Work with the rear brake light switch first.
Find and follow the metal brake line coming from the rear brake master cylinder running back towards the rear brake. Underneath the bike's transmission, you'll find a tee fitting with a pressure switch in it. With the ignition switch turned on, one of the wires that are plugged onto the switch should have battery voltage on it. When you depress the rear brake pedal, both wires should have voltage on them. If not, replace the switch.
Once you get the rear brake light switch working, if the front brake light switch does not work, it must be replaced. To replace that switch, remove the two bolts that hold the right handlebar switch housing halves together. Loosen the throttle cable and idle cable adjustments. Lift the top switch housing half and remove the throttle sleeve. The front brake light switch is the small switch right in the front of the housing half. You must desolder the wires, replace the switch with a new one, and resolder the original wires to the new switch. Reassemble the throttle sleeve and switch housing halves. Adjust the throttle cable and idle cable. Check throttle for proper operation.
Good Luck
Steve
Mar 24, 2011 | Harley Davidson FXDWG Dyna Wide Glide...
My friend has a blackberry, he dropped it last night and he said it worked for a hour then it turned white, i took the battery out, no red light popped up no white screen or anything, i plug it into the...
There are several online stores that sell replacement screens and some even supply the tiny screwdriver necessary to open the phone. Just search blackberry replacement screens. You may be lucky and find a youtube video showing you how to do the job
Jul 28, 2017 | Valor Fits Blackberry Curve 8300 8310 8320...
I have a 2008 HD sportster, how do you replace the RH turn signal button? Thanks! Rob
To replace the right hand turn signal button, you have to take the right hand switch housing apart which includes the throttle. Start by loosening both throttle cables at their adjustments. Loosen them all the way. Take mirrors and other stuff off the handlbar that might be in the way. Remove the two bolts that hold the switch housing halves together and carefully lift the top. Disconnect the throttle and idle cable from the throttle sleeve. Remove the throttle sleeve leaving both halves of the switch housing free.
Now, there is a screw that holds the switches in the housing. I think those swiches come as a pair. You may have to replace the right turn signal switch and the start switch. Here's the tricky part. I haven't done a model as late as yours but the ones I have done required that I unsolder the old wires and resolder them to the new switches in order to make the repair look like new. The new switches may or may not come with new wires but I never figured out how to get the new wires in the wire sleeve and into the headlight. It was just simplier and easier to solder the original wires to the new switches. Once the wires are securely connected, install the switches and the screw that holds them in.
Now, apply a good coating of white lithium grease to the handlebar, the inside of the throttle sleeve, and the nylon ring that the throttle cables connect into. Slide the sleeve on the handlebar and put the lower half of the switch housing in place. Connect the throttle and idle cables into the throttle sleeve. Make sure you have the little barrels on the cable ends. Carefully put the top half back on and get the bolts started. When you do this, make sure that you are not going to pinch a wire inside the housing when you tighten it up. Now, slide the housing and the throttle sleeve towards the center of the handlebar until it stops and then back it back off about 1/4 inch or so. Tighten the bolts that hold the switch housing together. Readjust the throttle cable and the idle cable. You want just a bit of slack in each cable.
Once finished. With the engine OFF, turn the throttle wide open and let go of the throttle grip. It should snap shut. If not, you may have the cables adjusted too tightly or the throttle sleeve is up against the end of the handlebar on the inside of the sleeve. The throttle must snap shut in order for the vehicle to be safe. Make sure your throttle works correctly. Failure to do so my result in serios injury or death.
Good Luck
Steve
Aug 19, 2010 | Harley Davidson XL 1200 C Sportster Custom...
Nokia n95 8gb lcd is blank but i hear it's turning on
if its blank you have to replace the lcd screen with a new one.
sometimes it maybe a flex cable problem which occurs in some slide phones.
at mobile phone repair stores, the cost of an original lcd screen replacement is usually $150-$200, though sometimes an original lcd screen may not be fitted into your device but rather a hong-kong made one which is similar to the original but is less brighter and a little less sharper.
if you take it to a nokia care centre to replace the lcd screen you may have to pay over $250.
you can just buy an lcd screen off ebay, replacing the lcd screen yourself isnt hard with the tools provided. you just have to take the ribbon cable from the old lcd screen and insert the new lcd screen and plug in the ribbon cable for it.
the reason for original Nokia n95 8Gb lcd screens being so expensive to repair/replace is that it is also the same lcd screen used for the Nokia N96.
cheers.
May 30, 2009 | Nokia N95 Cellular Phone
Display not coming
it sounds like your cable ribbon has got a hairline crack in it just replace that and it should be fine m8.
the usual symtoms are the screen just goes white if not no display at all !
Nov 19, 2008 | Samsung SGH-D900 Cellular Phone
Motorola pebl u6 fitting new housing instructions
There ares 4 screws (#6 torq) on the back side where you replace the battery. take those out and the phone come apart. Be carefull because the main board, key board and all will come apart with careful prying. Also watch out for the ribbon cable that connects the LCD screen to the main board
Apr 05, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Samsung SGH-D600 Cellular Phone Logo
32 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
