How to tune bush lcd15tv006 to sky box
Trying to tune bush lcd15tv006 to work from sky box ? now tv is stuck on a screen with what seems to be a 0 with a diagonal line through it on the top left corner where channel number is normaly displayed
bluenadas
  • 203 Answers
SOURCE: Ratio
Does the sky box have a setting for output ratio? If so try adjusting it and see what the TV does.
Posted on Jun 10, 2007
chrispurs1
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Posted on Jan 31, 2008
  • 33 Answers
SOURCE: The channel information/display won't stop popping up every few seconds.
What you all need to do is get away from a coax cable connection. If you have a cable box, or satellite box, take the coax cable off and use red, white, n yellow rca composite cables to connect your recievers to the tv. if you dont have a cable box, either get one, or get a converter box and use a tuner outside of the tuner within the unit. The tuners in those tv's are built to show you when you experience signal fluctation(which is normal with a coax cable) and thats why the box keeps popping up on its own. good louck to you all with this problem
Posted on Feb 19, 2009
  • 325 Answers
SOURCE: have lost the link from sky+ to a second tv which
Hello K Agate,
In the main room where the Sky + is locate. With the sky remote press the following.
Services.
0,1,select
4 (rf)
Ensure that the RF power to set to on, and take a mental note of the channel number the RF is set to. I normally set this to 38 it is upto you.
Now check that the coax lead that links the sky+ box to the 2nd room is plugged into RF out 2 on the back of the sky+ box.
Now go into the other room and make sure that there is a red LED light on your magic eye. If there is then great. If not there may be a fault with you eye. A good way to check this would be to connect it straight into the back of you Sky+ RF OUT 2 port. This would also check to see if there is any fault with the coax cable feeding the other room.
Assuming that there is a Red LED light on the eye when its plugged into the back of the TV in the other room (not the one with the sky box in), This means that there is power getting to it from the Sky + box.
Put your sky box on the TV GUIDE screen. This will make tuning it in a lot easier.
in the other room with your tv remote press the following
Channel 6 or which ever number you want it on.(analogue)
then MENU on the remote.
Go to MANUAL STORE
Then if you go down to where it give you a C ** number just type in what you retrieved from the sky RF menu.
That should bring your sky up then all you need to do now is STORE.
That should be you all sorted out now.
Hope all goes well. If so then please leave a Thumbs up
Cheers Little Dish Fitter.
Posted on Oct 21, 2009
housejess
  • 317 Answers
SOURCE: i have a black box in the top left hand corner of
go to menu on tv...turn off pip or picture in picture....thanks and have a great day
Posted on Nov 08, 2009
How do I tune my TV in the kitchen to my Sky box in another room.
Sky box stuck in Stand By on red light Sky Box Guides faq
Sky Troubleshooting faq
either you have it hooked up wrong or skybox doesnt allow 2 screen use,you may need another skybox
May 14, 2015 | Televison & Video
Tuning bush tv
Because you haven't programmed the Sky remote correctly.
Put the TV and Sky box on, and put the telly on the Sky channel. Press Interactive on the Sky remote. Choose "Program my remote" from the menu list. Follow the onscreen guide. The pages take a bit to update so be pationent
Sep 07, 2014 | Televison & Video
Tune in bush television to skyview
First of all what do you mean by "tuning onto Sky"? There is only one way to watch Sky on any TV and that is via a scart lead
Apr 06, 2014 | Bush Televison & Video
I need a code for a bush bpdp 42 hd 2 tv for my sky hd box
2577 worked for me for the Bpdp 42 hd bush tv
Jan 07, 2012 | Televison & Video
Code for RUC/Sky
The following code: 253 will work on Sky remotes for the following tv:
Bush LT42M1CFA
Feb 01, 2009 | Televison & Video
RECENTY PURCHASED SECOND HAND TV WITHOUT REMOTE OR HANDBOOK CANNOT SEEM TO SET UP MY SKY BOX TO IT ANY SUGGESTIONS?
Does the S/H TV have AV1 & AV2 settings and a scart socket? If so just connect the a scart lead from Sky box to TV and select AV1.
If you have no scart socket on the TV you need to connect a coaxial (aerial) cable from the sky box to TV and tune in to a channel. It is possible to tune in your sky remote if you have the TV code.
Please remember to rate this solution.
Oct 22, 2008 | Televison & Video
Sky+ DVD Recorder Tuning
You need to connect up the Sky+ to your recorder via scart. This will eliminate poor picture quality. The Sky box will be on ext1 on your recorder or something like that
Oct 12, 2008 | Televison & Video
Amstrad digibox
if you have had new software downloaded on the box and it still dont work then you will need a new box. have you tried a system download if not then take your viewing card out the sky box then take the power lead out count to ten. then wilst pushing the backup button on the front of the sky box plug the sky box back in keeping the backup button pressed , wait till the on screen message says sytstem download do not disconnect from mains blaa blaa take your finger off the backup button and wait till the tv screen goes blank. give it about 60 seconds then try turning the sky box back on this should work.
Sep 13, 2008 | Audio Players & Recorders
Hi.
3)
Chris.
Jan 30, 2008 | Televison & Video
Ratio
Jun 08, 2007 | Polaroid FLM-2632 Television
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
