Question about Welding Tools
How do I make the flame on my mag-torch bigger
3 Suggested Answers
japace751
  • 227 Answers
SOURCE: I have a bernzo torch tip that clogged so I poked one single whole in the tip very small. Now instead of a regular torch flame it has a standard lighter flame why and how do I get my Torch flame back
YOU CAN BUY A NEW HEAD ONLY AT THE HARDWARE STORE.
Posted on Jan 24, 2016
  • 191 Answers
SOURCE: Pencil Torch flame is not powerful welding torch, its a lighter flames and flames come out the sides through the air holes. How can i fix this? Thank you
Try turning the valve down or towards the off position. It may take some fine adjusting to get it just right.
Posted on May 02, 2016
May 02, 2016 | Welding Tools
My question is in bbq grills w/pic.The flame on this torch is now like a lighter flame, i want a torch w/ power and the flame is coming out the air holes. Can this be fixed?
check burner is not blocked check all holes in burner are not blocked . make sure burner is not split , what you have is light back to the injector .
May 02, 2016 | Grilling
I have a small pencil torch its not flaming right.not torching just a flame
Too much gas! Turn it down and check that nothing is blocking the airways.
Mar 23, 2015 | Blazer Pencil Micro Torch PT 4000
I have to replace the CV joint on my 1993 ford probe 5 speed Manuel and can't get the outer nut off. I broke a ratchet and the extension. I believe the threading is NOT reversed.
rust penatrant and lots of heat, as in a flame from a torch. get it real hot then lefty loosie no reverse threads here. get a stronger ratchet and bigger cheater pipe. does it have a cotter pin in it?
May 06, 2011 | Ford Probe Cars & Trucks
Hi there, despite brand new torch, brand new regulators and gas tanks, I cannot get a decent hot flame on my oxyacetylene torch, and what flame I can get, goes out within seconds of heating a...
Hi:
If your flame goes out check the following:a) check your acetylene and oxygen pressure, for this kind of job acetylene should be at 4 psi and oxygen at 10.b) Check you're using the right type of nozzle for the job and this nozzle is clean.
Apr 04, 2011 | Smith 23-1001C OXY/ACETYLENE LITTLE TORCH...
I have a R-100-A. It starts and runs but it pops a flame out the exhaust frequently (like it is burning raw fuel)_would it need a new spark plug or filters?
hi, it sounds like the jet or nozzle is dirty. try cleaning it out with a bit of carb cleaner and a torch nozzle pick set or sewing needle if needed, and becareful not make the hole bigger than the origional size, also be sure to unplug it. good luck
Feb 10, 2011 | Reddy R155D Utility Heater
Got a a six cell Mag Lite D and the batteries have corroded and jammed inside.Got 1 out, 5 stuck fast. How do I get the damn things out!
The bad news is, the torch will likely not work even if you could remove them which is unlikely. The acid will have rotted the business end of the torch terminals. Time to throw it in the bin my friend.
Dec 19, 2010 | MagLite Mag-Lite& Largehead Flashlight
How do you change the bulb in a mini maglite?
Carefully.....
Check in the base of the torch and you will see the spare bulb. you need to pull the spring out to get at it.
Next unscrew the top off the torch to expose the bulb.
The bulb is easily removed by gently pulling straight out. Replace the new bulb in the same way, lining the two pins up with the holes (doesn't matter which way round) and wipe the bulb clean of any finger grease etc.
Screw the top back on and replace the spring in the base before screwing the base back on..
Replacement bulbs, and all other parts for that matter, are easily sourced at any good outdoor store that stocks MAG.
Hope this helps..
Jul 05, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
