Question about Kenmore Elite 45986 Front Load Washer
We have a new washer. It is flashing F29 and won't drain.
The washer is 2/3 full of water. We tried the rinse and spin/drain but it just puts a bit more water in. Sears says they'll send somebody Tuesday. Anything we can do be fore that - washer has clothes in it too.
  • Has you problem been fixed yet?
    sounds like blocked pump.
  • 63 Answers
Communication between ccu board and mcu board check and push on all wires. to and from motor controller board[mcu] &[ccu] board top in rear usally this code i found loose wire at mcu
Posted on Nov 14, 2008
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Please help me with my washer
Hello browneyez070
Welcome,
You said, your Hotpoint top loader washing machine won't spin water out. Model VBXR1O6OVOWW?
Common causes before considering repairs.
Water won’t drain
Drain hose is kinked or
Improperly connected on it.
Solutions
• Top of drain outlet should be less than 8 ft. above floor.
• Straighten drain hose and make sure washer is not sitting
Let me know if these measures help.
Huuum
Oct 15, 2008 | Hotpoint VBXR1090B Top Load Washer
Not spinning
I found my Classixx 1200 express with a flashing spin light, the water wasn't up in the drum, so I moved the selector to rinse, and pressed start, pump was noisy but worked, I could hear water going into the drain, thinking I'd got a blockage in thye pump, I drained machine using small hose and inspected the pump orifice at the front of the machine (towel handy to catch spillage.
No obvious blockage and the pump could be turned by hand, tried rinse again with water feed turned off, (otherwise it pumps for a while and then lets water in to rinse - which comes out the open pump housing!) I could see the pump impeller spinning but also sticking, its was also noisy.
Solution - new pump, according to my local spares shop, the pump is available as either motor & impeller (back half), or complete with black housing that the pipes fit to, to get the front cover off, and to remove the pump, you need a "star" screwdriver or key, and a pair of pliers to undo the hose clips - have a bowl ready to catch the water, and make sure the machine's unplugged before you start!
Jul 12, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washer won't spin or drain
whats the make of your washer, if its the older models it might be the lid switch, switch might be defective, but i still need the make/brand of the unit to be more specific.
Apr 14, 2008 | Fisher Paykel Eco IWL16
Spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
Apr 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
