it has lost 2 of one things fuel or spark first get some starting fluid you can pull out the mass air flow sensor if it comes out and spray it in there if not just spray it directly to your throttle body then see if it start if it does and then dies you lost fuel if it doesnt then you lost spark and 95 percent of the times its a bad distributor but in the case of how new your vehicle is you proabbly have coil on coil packs
You must set the clock first. I think that is done by pressing the memory button a few times. It doesn't matter what time you set, as long as the clock is set. Good luck.
my jx85 when cutting grass with my jx85 the power to the blade dies if i lift it up the power will come back put it back into grass it dies again any ideas please
The steering is powered by the crank by a v-belt, so, this only works with the engine turned on. Check all the gas supply lines (and fuel pump) and the electrical power from the distributor.
