MY DYNEX WEBCAM WON'T SHOW ON THE MONITOR, BLACK SCREEN
MY DYNEX WEBCAM WON'T SHOW, EVERY THING IS BLACK.
  • 3 more comments
  • Anonymous Dec 21, 2008
    tryed that didn't work for me...
  • Anonymous Jan 17, 2009
    my screen doesnt show but it tells me that i have sound and i can use its mic. PLEASE help this person &me by answering it!!!
  • Anonymous Mar 12, 2009
    dont work
  • Anonymous Apr 10, 2009
    my DYNEX webcam shows a black screen
  • Anonymous May 03, 2009
    i have vista and the camera is now in discontinued camera so i cannot find what im needing to get rid of my black screen.
The answer is posted by user Andreole on Amazon.com :The web is full of posts by irate purchasers of this little camera that simply couldn't get it to work. With good reason. The software that is shipped with the product is total junk. Fortunately what is available on-line is better. Here's how to solve the black screen problem on an XP. The key is not to allow the machine to install the driver for you. You must install the driver from the device manager in your system folder. The reality is that it is a nice little device ONCE you get it to work.
First, toss the software that came with the camera. Go to http://www.dynexproducts.com/pc-459-10-dynex-desktop-web-camera.aspx and download the software you actually need to run the device. (If you previously installed the software, it would be best to remove it before starting.) Download the new software, unzip it and you'll have a dynex folder containing an install file. With your camera NOT connected to your computer, install the software, including the WebCompanion2 program from ArcSoft (this will happen automatically after the Dynex software installs). Reboot if asked to do so. Hook up the camera. Abort any attempt by the computer to search for the needed driver itself. Go to your control panel and find your systems folder. In that folder, find the device manager under the hardware tab. Locate "imaging device" and locate the Dynex camera. Right click on it, then select "update driver". Again, don't let the computer find what you need. Opt to manually locate it and direct the computer to look to the dynex folder most likely on your desktop or found under Programs. Three drivers are found. Two certified and labeled "PC Cam", the other not certified and labeled "Dynex Cam". Select Dynex. That's it. Your camera should work.
Obviously, this is not the way these products should work. You should not have to go through so much grief just to install it.
Posted on Jan 21, 2009
I have a dynex web cam installed onto my pc hp pavilion computer, i did the cd thing and it ask me to restart so i did so now it.
My computer loads up but i get this option that says bass exe system error
object name not found what do i do
Posted on Jun 30, 2009
  • 849 Answers
Re-instll drivers
Posted on Oct 24, 2008
Dynex TV came on black and the buttons aren't working?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Dynex Televison & Video
How can i fix my hp 210-1041NR mini laptop black screen problem,
Time for a trial and error.
1.connect your laptop to a monitor or tv that has a VGA connection.Use a vga cable and connect it to your laptop then to your TV or monitor.If the screen shows display and works on your TV or Monitor ,Then its likely that your Laptop screen is faulty which can be replaced.If it does NOT SHOW on your monitor or TV then it means your GPU is faulty which then you will need to replace the motherboard on your laptop.
Sep 14, 2013 | HP Mini 210 210-1041nr Wp055ua 2gb 16010.1...
Dynex 32" 720p Flat-Panel LCD HDTV - Matte Black Logo Print Email Problem with Dynex 32" 720p Flat-Panel LCD HDTV - Matte Black I have a Dynex Bluray Player and when I connect it with AV Cab
If the item is under warranty return it asp. The problem is in the power supply, the cause is a open capacitor sometimes leaving a bulge at the top.
Apr 25, 2012 | Olympus Televison & Video
My Acer X193w. My monitor comes on and says cable not connected but when I connect the VGA cable the screen goes black even though it is still on.
VGA is an analog connection, so you should connect it to your monitor BEFORE starting up the PC. Otherwise it won't show anything
May 04, 2011 | Acer X193W LCD Monitor
DX-L22-10A quickly shows "please wait"
Contact DYNEX for assistance (Mexico) Be patient...(siesta time...) They will talk you thru a RESET !! (I hope...)
May 03, 2011 | Dynex DX-L22-10A 22 in. LCD TV
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 06, 2010 | ViewSonic VA1703wb Monitor
Does a dynex tv connected via vga to PC come up as a genaric monitor in windows display panel? Is this normal? or is there a way to make it identify it as a large screen tv for better resolution range?
If windows cannot identify the monitor that you have connected it will show up as a generic monitor. If you are able to find a driver for the monitor then windows will show that particular monitor instead. If Dynex has a website you can check there to see if they have a driver for your TV, or you can check under there support section to see if they suggest anything that might help.
Mar 02, 2010 | Dynex 19 in. LCD Flat-Panel HDTV
USB ports/Driver downloads with dynex 1.3 webcam
download the driver from this page where also you find some documentation that can help you
Sergio
http://www.dynexproducts.com/pc-692-10-dynex-13mp-web-cam.aspx
Jul 02, 2009 | Dynex DX-WC100 Webcam
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
I can see myself on my side of the cam but anyone that i invite to view it sees a black screen.
dear check yahoo setting if you use yahoo.........it is helpful for you........
Apr 16, 2009 | Dynex DX-WC100 Webcam
Computers & Internet Logo
2,602 people viewed this question
David Payne
David Payne
