Question about Smeg FME24X Microwave Oven
Need to remove this fitted SMEG FME24X Microwave
Hi all,
I am writing this thread with a hope that I will be getting some favorable response.
The issue is, my Smeg Microwave FME24X has stopped working for the last couple of weeks. I guess its because the fuse has poped up. When I called some local engineers they were asking me to remove it from the fitting to take it to them. (Because I am the only person in my home, its not possible for me to get an appointment on Weekdays).
Can somebody please help me out with some diagrams or manuals to remove this Microwave from the fitted furniture.
Many thanks in advance..
  • haristha Oct 24, 2008
    Thanks for the quick reply. As you said this has been mounted into a recess and surrounded like a picture frame.
    I found some screws are very deep inside the recess and it has been obstructed by the grille/frame.
    If you have any pics or any illustration, can you please forward it to me.
    Thanks
  • William Miller
    William Miller May 11, 2010
    Your owner's manual / IFU can be downloaded here.
    You will need the free Acrobat Reader to view or print it in case you don't have it already.
    Since this is a counter top microwave, as opposed to an over the range model, I would suspect that it is mounted into a recess or opening, and that there is a metal frame / grille either at the at the top and bottom, or surrounding it like a picture frame.
    If this is the case, one would remove the screws in that grille / frame to remove it. Then one can slide the oven out of the opening it is in.
    Does that seem to be your situation?
  • Smeg Master
  • 9,086 Answers
Sorry I do not, but you might try contacting Smeg here: Smeg Service spares
Good luck.
Posted on Oct 24, 2008
Thanks
My smeg microwave will not heat the food ...... possible causes
If everything else is working but it won't heat the food, the causes are the magnetron "common failure" or the high voltage capacitor and diode can be a factor, the three work together to heat the food. Depending on the nature of repair it can be close to the cost of a new microwave oven.
Feb 27, 2011 | Smeg FME24X Microwave Oven
How do i get into globe compartment to change globe on a convection microwave
The cover has to come off the microwave to access the bulb. There are several screws around the back and sides. Remove these and the cover should lift off, revealing the bulb. For your own safety, make sure that the microwave has been unplugged from the outlet for several hours before attempting this repair.
Feb 25, 2011 | Smeg FME24X Microwave Oven
Need intruction to operate microwave
I am writing to ask how to set the clock on the FME24X 900 Microwave Oven
Just need to know how to set it and where can I get an operating manual from
Area we live in is Windsor
Nov 14, 2010 | Smeg FME24X Microwave Oven
Fme24x not heating and burning smell with loud noise
Those are classic symptoms of a bad magnetron tube, the microwave source. It is possible to replace the part, but usually not worth it. The magnetron is expensive and you should let a professional do the repair. There are lethal voltages under the cover and the chance of microwave leakage if the repairs aren't done correctly. Between the part cost and labor charge, it's usually not much more expensive (sometimes even less!) to buy a new oven.
Oct 31, 2010 | Smeg FME24X Microwave Oven
I have a Smeg FME24X 900 Watts Microwave Oven, and has stopped working, no power but occasionaly the display lights for a fraction of a second, any ideas? Have tried replacing fuse in plug but still only...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 08, 2010 | Smeg FME24X Microwave Oven
I have recently been given a Smeg microwave, product No, SA987CX, but I have no instruction manual and would like to know where I can find one.
I have looked and I can't find one either. You can mail Smeg in the UK at support@smeg-service.co.uk They may be able to point you in the right direction.
Mar 01, 2009 | Smeg FME24X Microwave Oven
Replacing the door catch
If you're talking about a hook-like device that sticks out of the door and goes into a hole in the chassis of the microwave (or any other internal part of the door for that matter) you'll have to take the door apart. Brands and models vary, but some use screws which are obvious, and others use hidden hooks similar to the ones in the drawing I've added to this post. If you can post or e-mail photos of the area where the part goes, we may be able to translate our experience with other brands to yours.
Jan 30, 2007 | Smeg FME24X Microwave Oven
Smeg FME24X Microwave Oven Logo
522 people viewed this question
Top Smeg Microwave Ovens Experts
William Miller
William Miller
jason
Are you a Smeg Microwave Oven Expert? Answer questions, earn points and help others
