Question about Dirt Devil Breeze Bagless VacuumVacuum
Dirt devel breeze bagless vacuum is vibrating and is much louder than usual.
I just changed the belt after it broke. the belt broke due to the beater roller locking up, so I worked on the beater roller to make sure it spins freely before installing the new belt. I'm guessing this is coming from the motor which might be the bearings causing the noise and vibration.
  • 126 Answers
SOURCE: Dirt Devil Featherlite not picking up
It sounds like you have a blockage somewhere. The brush roll will still gather material, but if the suction is insufficient, it will spit it back out eventually. Take the bag out and check at the connection for blockage. When you are sure it's clear, put in a new bag and turn the machine on. The bag should inflate rapidly. If it does not, check elswhere for blockage.
Posted on Jan 20, 2008
reddevil6
  • 1673 Answers
SOURCE: Vacuum motor shaft too hot
Check the brush roll ends, will they turn easily or is one frozen. If so, you need to replace the brush roll. If the motor turns on, it and the belt are trying to turn the brush roll and can't. Also check the ends where the brush roll sits in and make sure it hasn't overheated and melted., If it did you will have to replave the base.
Posted on Mar 11, 2008
reddevil6
  • 1673 Answers
SOURCE: Dirt Devil Breeze-Bagless Vacuum
You probably have a clog either in the hose , wands, or the dirt inlet by the brush roll.
Posted on Mar 13, 2008
galati2k
  • 281 Answers
SOURCE: Dirt Devil Jaguar Bagless Upright Burning Smell
take the belt off again you will see burnt rubber from the old belt stuck to the motor shaft.you can take a fine piece of emery cloth and clean the shaft down to its polished finish.always good to do this after each belt.check the brush roller and see if there are any signsd of plastic melted.make sure it turns freely if not the brush roller might be siezing uo on youhave you cleaned the hepa filter?does it smell like wires burning or rubber.with it unlugged take it apart to the motor and take a fine iece of emery cloth and go over the motor armature .then try it again.you can take all the filters out and run it without the filters.that will help you narrow it down.please leave feedback
Posted on May 05, 2009
  • 11 Answers
SOURCE: How do I change the bag on a dirt devil model 103?
On the open end of the bag that slips onto the vacume, there is a cloth "tab" sticking up from the band. Take hold of this tab and lift up while easily pulling back until you see the band about half way off the vacume. Now, you can take hold of the band and pull the bag the rest of the way off. You will notice that there is a "rib" in the middle of the band on the side that faces the vacume. That rib fits into the groove where the band goes on the vacume. When you install the bag put the band on this groove and work the band on around the housing. You can center the "tab" anywhere, just place it where you can get to it easy. The other parts you need are on the internet, I found them all including that rubber plug called the "attachment port" plug. The p/n for the replacement part is 3-201744-601. The original p/n is 3-501744-601 but you'll be better looking for the replacement part number. Good luck!
Posted on Mar 08, 2010
I was running my vac when it caught the fringe on a throw. I turned it off and carefully pulled it out but now I don't have any suction and it's not cleaning the carpet.
Don't know the model too well but the beater bar is what goes when that happens(the brush that goes around right there on the intake of the sweeper) it has a belt that makes it turn and you probably broke the belt or burnt it up or it came off so it is the belt that is the problem. That will give you those symptoms because the beater bar (rotating brush) is what lifts the dirt up so it can be sucked in.
Mar 28, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
What makes a bissell vac 3130 throw out dirt instead of sucking it up? i just changed the belt that was broken.
Does your vac require you to twist the belt and fit it onto a shank on the impeller? If so twisting the wrong way will make your beater bar roll the wrong way and that will make it throw dirt out the front.
Mar 12, 2011 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Hi, The belt of our Dirt devil bagless vaccum broke and we got new belt and replaced it. Even after replacing the belt, the brush is not rotating. Any suggestions please ?
Did you check to see that the beater brush, the brush that the belt drives, is free of debris and moves freely? When they bind up they can cause the belt to break. Remove the beater brush just as you do when changing the belt and clean as best you can. There are retainer clips at each end of the brush, add some WD40 between the clips and the beater brush and turn by hand to free it up. Reassemble making sure the belt is on in the proper manner so that the brush will turn in the correct direction. If you find this solution helpful, I would appreciate a Thumbs Up from you!
Thank you. Paul
Oct 06, 2010 | Dirt Devil Featherlite Bagless Vacuum...
All of a sudden the hose isn't sucking. There is nothing in there that I can see. Is there a way to take apart the connection between the hose and machine?
This URL would be a good place to start looking:
http://media.dyson.com/downloads/us/floorcare/manuals/dc17_opmanual_usa.pdf
Pay special attention to the belt that drives the beater brush and the beater brush itself. You need to make sure the belt has not broken and that the beater brush has not frozen up due to dirt and debris. If you need to change the belt it would also be a good idea to remove the beater brush and clean it as well.
Please feel free to contact me if you have questions, my assistance is at no charge.
Paul
Sep 18, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
The belt keeps breaking. Like it's burning through.
Sounds like the beater brush the belt is supposed to turn has frozen up due to debris. Remove the brush and clean all debris. At the ends of the brush will be two fasteners that hold the brush in place, be sure all debris is cleaned from these and add a small amount of WD40 where the beater brush fits into these two small holders. Turn the beater brush around these holders by hand to be sure it moves freely. Reassemble with new belt.
Sep 17, 2010 | Dirt Devil Breeze Canister M082550 Bagless...
My vacum will not pick up dirt and it is smoking a little from the bottom.
siunds like the beater bar has seized take bottom off and check belt and brush
Nov 14, 2009 | Dirt Devil Breeze Bagless VacuumVacuum
Vacuum won't pick up any dirt - there's no roller marks when vacuuming carpet. Roller does turn and filters are clean.
When you turn the roller, you should feel some resistance from the belt. Remove the base blate that surrounds the beater bar. Check the belt. Take care in removing the beater bar, so you can get it back in the same way it comes out. Clean the beater bar while you have the bottom open. If you remove the beater bar to replace the belt, take the time to inspect the cavity behind the beater bar where the vacuum picks up. That is where vacuums usually stop up. Reassemble the vacuum. If necessary, slip the belt over the motor shaft and then slide the roller undre the belt. Install the beater bar back in the sockets and replace the base plate.
Best regards,
--W/D--
Aug 12, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
HOW DO YOU CHANGE THE BELT ON A DIRT DEVIL VISION VACUUM CLEANER?
With the vacuum unplugged, turn the machine beater bar side up. Locate the clips or screws that hold the plate over the beater bar and remove the plate. The beater bar sits in sockets just inside. Be careful in removing it; take your time and note how it comes out...this will make reassembly easier. Clean the debris while you have tha bar off and remove any debris thet you see in the vacuum hose area behind the bar....The new belt slips over the motor shaft behind the beater bar (further up in the cavity behind the b/b), then you slip it back onto the beater bar as you place the bar back nto the sockets. Test your work by revolving the bar a bit to make sure that everything is back in place. Replace the plate.
Regards,
--W/D--
Jul 12, 2009 | Dirt Devil M088910 Swivel Glide Vision...
The Belt on my Dirt Devil broke...so I purchased another belt and as soon as i put it on and started to vacuum it also broke, i noticed that the metal piece the belt goes on was extremely hot and was...
It may be that the beater brush is bound up . This will cause slipping, of the belt. Take out the brush and clean out the bushing . Hair gets wound up in side. once you have it cleand out. Put a few drops of cooking oil in side the bushing on both ends. This will make a big diffrents on how it spins. Good luck DFD
Apr 24, 2009 | Dirt Devil& Breeze Vision Canister Vacuum...
Dirt Devil Breeze Bagless VacuumVacuum Logo
24 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
