Question about Microsoft Windows Vista Ultimate Edition
Windows aero glass
Cant get Aero glass happening on Vista ultimate.... 845gv-m3 motherboard, has 2g ram 2.4gh pentium processor, nvidia mx 4000 128mb graphics card....
  • findads Oct 28, 2008
    Nvidia GPU didnt have correct 3D capabilities. Got Nvidia GeForce 6700 256Mb card and all good.
    Problem Solver:
  • 5 Answers
GO TO WINDOWS 1ST FOR UPDATES, DOWNLOAD INSTRUCTIONS, REQUIRES YOU TO UNINSTALL, REBOOT, REINSTALL FROM REBOOT. PRINT DIRECTIONS FOR APPLICATION OR IF YOU HAVE ACCESS TO ANOTHER COMPUTER ITS EVEN BETTER.
Posted on Oct 24, 2008
FOXCONN MOTHERBOARD UYD761904374 PC661M04 MX 6L Will NVIDIA GeForce 9300 GE graphic card work with Foxconn motherboard UYD761904374 PC661M04 MX 6L. Please help me. I want to install windows 7 and use...
System Ram doesn't count for Gpu ram so 2 gig Ram and 2 gig Gpu will be fine .. check also Psu some Gpu are hungry for power Mine is Gtx770 8 pin + 8pin at 240watts.. hence 750 watt Flower power Psu...
Jul 01, 2017 | ASUS Computers & Internet
I have a 20 inch lg lcd monitor..I am using a pentium 4 processor with 101 intel motherboard..I installed windows 7 ultimate but I cant find a display driver from lg for this. I cant experience AERO...
In order to experience Windows Aero effects you generally need to have a minimum windows experience base score of at least 3.0. To determine your score go to your start menu - control panel - system and maintenance - performance information and tools.
In this screen you will see your score for a number of different components of your computer. One of these is graphics, which is the score for running windows aero. This score generally needs to be at least a 3.0 to get all the functionality of Aero running smoothly on your computer. The only thing you can try to do is update your graphics drivers to see if this can increase your rating. This can sometimes be done through windows update. The LG driver unfortunately will not be able to help you in this regard as it is only a driver for the display, not the graphics capabilities of your computer.
The only option would be to look into getting a new video card. With a new one you should be able to experience Aero effects again.
Sep 08, 2011 | Computers & Internet
Not supported aero in windows
The name 'AERO' is the name for the "fancy" software in Windows, e.g., semi-transparent Windows.
If you have the "Starter" or "Basic" version of Windows, AERO is not available.
If you have a "low-end" video-card, AERO is disabled, because the video-card lacks the necessary capability to support AERO.
Jun 23, 2011 | Intel Pentium Dual Core E2140 / 1.6 GHz...
I am using ASUS P5VDC-MX Motherboad with window 7 operating system and drivers are not install properly. window 7 transition effects are also deactivate. why ?
To ensure your system works properly, you will need to locate the drivers for your specific hardware. Your motherboard will have its own drivers, in addition to any expansion cards you have installed, such as a graphics card. Your motherboard drivers can be located at ASUS's website:
http://www.asus.com/product.aspx?P_ID=Wv3U3hfa7ZbODqSr&content=download
If you have not installed an expansion graphics card, and are using the one on your motherboard, this should fix the Windows 7 "transition effects." I believe what you are referring to is the Aero theme. If you are using an expansion graphics card, you will need to get the drivers from the appropriate manufacturer (generally NVIDIA or ATI). If the effects still are not working after you install the appropriate drivers for your system, you can right click the desktop, and click Personalize. This should bring you to a screen where you can choose an Aero theme.
Also of final note, the Aero effects are not available under Windows 7 Starter, so make sure you are using Home Premium, Professional, or Ultimate Edition.
Please let me know if you need any additional help with this. Thanks!
Aug 11, 2010 | ASUS P5VDC-MX Motherboard
The Aero feature is not working
http://support.asus.com/download/download.aspx?model=K8S-MX&SLanguage=en-us
follow this link and download ur driver and check it
Mar 01, 2010 | ASUS K8S-MX Motherboard
Is it possible to run vista aero on EliteGroup km400-m2?
Vista Aero is dependent on your Graphics hardware, not on your motherboard. The onboard VIA/S3G is not going to be capable of running Aero, but you do have an AGP 8x port that you could buy a card for. Try picking up an ATI 48xx series card if you plan on doing some gaming. If you just want to run Aero, however, just about any card nVidia 76xx series, 86xx, 96xx, or any ATI 26xx, 36xx, or 46xx series card will do.
Oct 19, 2009 | EliteGroup KM400-M2 Motherboard
Graphics
1) enter bios
2)make changes in shared graphics to 128 mb
3) increase the size of page sys file allocate more ram to page.sys file by going into rt click my computer/properties/ performance/
4 u can change your windows system to 64 bit.
Sep 19, 2009 | Intel D945GCCR Motherboard
Bad resolution and aero glass theme not working
Sounds like you have Intel Ingregrated Video with less than 1 GB system ram.
The answer is the system does not have the hardware to Run Vist Aero Mode, and apparently has minimal ability to run Vista at all.
You may be able to get a better video driver than the default at Support.dell.com.
More than likely, you are looking at putting Windows XP back on the system
Apr 12, 2009 | Computers & Internet
How can I overclock 845gv-m3 motherboard?
according to ecs this is a 478 / fsb 500 ht mobo and cannot be overclocked (now most can be with a bios flash but be carfull the speed you get my not be worth it I find most only get 2-300 mghz & you chance ruining a good mobo).
Oct 24, 2008 | Computers & Internet
ENABLE VISTA AERO
What graphics card does your laptop have? It needs a dx9 one for the aero effects to work.
Jan 15, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
78 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
