Question about Whirlpool Refrigerators
The hinge on the door of my integrated refridgerator, bottom left has broken, where can i find a replacement, i am told that the unit is now obsolete although the door displays a promotion for 10year parts (bought late 1998) Model: ARG992 K/G/R – GB Classe: SN EN 153
    Genius:
  • 1,122 Answers
You can try sears .com click on parts put your model number in and see if they have it ,or repair clinic .com-mike
Posted on Oct 24, 2008
Does anyone know how to replace the hinge DA61-04866A on a Samsung french door vertical panel
unclip the plastic cover off your door hinge and unscrew the screws on your door make sure you leave the top screw in just a bit so you can take it out with your fingers before you drop the door ok same for both sides
Jan 22, 2015 | Samsung RF263AERS - 26 cu. ft. French Door...
Good Afternoon! I've got an old sandwich top two-door with a broken hinge on the left door. The name-plate reads "Superior Products" but it obviously a Bev-Air manufactured unit. Currently, True is making...
Hello there:- on all the Hinges they 've a MFG name and a Number. if you can look at it on the back side of the broken hinge . Then you can get it from any refrigeration co. or any appliance co. too. try that . Hope this can help. God Bless.
Oct 08, 2010 | Beverage-Air Refrigerators
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Jun 25, 2009 | Dometic Refrigerators
Broken hinge
Take the scanner lid off by squeezing the plastic hinges inserted into the back of the cabinet.
Take the top hinge of the cartridge door off with the 2 tork screws holding it, using a small screw driver.
Go to a hardware store & pick up a pair of cabinet hinges no more than 2". (You need to buy a pair because they do not come separate)
Place the new cabinet hinge on the back to the right of the bottom hinge of the base cabinet. Mark holes, drill one top, in the door, & 1 bottom cabinet, pilot holes. Check alignment & insert screws.
Tighten the bottom screws. Leave a little slack in the top screws as they have to be a little off set to close completely. You will only need to open this Cartridge door to change cartriges, so, no sweat.
My cost was under $5 for a pair of brass hinges, & my time, about an hour, taking my time.
It's too bad HP won't supply their offset hinges. They are inexpensive & easy to replace.
I've had my unit for exactly 4 years now, so this fix is a lot cheaper than buying a new one. Besides, I have ink already purchased that does not fit new printers.....go figure....
Aloha.
May 31, 2008 | HP Officejet 6310 All-In-One InkJet...
Refridgerator door
a lot of the sub-zero doors are good and heavy duty, but the plastic shim under the hinge wears and can drag when you go to close door, usually a simply repair to find a washer for the door hinge.
May 16, 2008 | Sub-Zero 700TCLH Bottom Freezer...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Oven door does not close
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Jan 06, 2008 | Jenn-Air JJW8230D Electric Double Oven
Refrigerators Logo
89 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
