Question about Toys
Leapster 2 stuck on warning screen
When powered up it just stays on the important message screen
Leapster explorer says memory full but it's not
1) Please run the LeapFrog Utility http://lfccontent.leapfrog.com/cs/utilities/LeapFrog_Connect_Utility.exe
2) Select "Clear LeapFrog Connect User Data"
3) Start the LeapFrog Connect application and wait until the message center indicates that all Leapster Explorer Updates have been downloaded.
4) Power on and plug in your Leapster Explorer.
Jul 01, 2012 | LeapFrog Leapster 2 Learning System
Touch screen will not respond. It's stuck on
Other sites suggest you power it off. Then hold down the '?' button when you power it back on. Then it says you can select the 'A' button. This is supposed to reformat the stylus.
Jul 17, 2010 | LeapFrog Leapster 2 Learning System
Leapster 2 powers up to warning screen and then powers off. Batteries are new and all contacts appear to be clean.
Connect it via USB to your PC/laptop. It'll connect to the Leapster website and appear to update firmware. Once it is finished, it will let you know to disconnect. After that it should work. I had the same problem and did this, and now it's working fine.
Jan 02, 2010 | LeapFrog Leapster 2 Learning System
We have a Leapster 2 less than 1 year old. It
We have the same problem and our leapster is only 2 days old.Do Touch Screen Calibration,it should help.I do it everytime for my son when he wants to play and it does help...But once u turn leapster off,u'll have to calibrate it again next time...
Just hold down hint button while turning on.When the Leapster menu screen appears,press the A button.Touch each of the crosshairs that appear with the stylus.restart unit. ..That what we do everytime.
Dec 03, 2009 | LeapFrog Leapster 2 Learning System
Pink Leapster2 beeps and wont go pass warning page
One suggestion; Place in a Wal-Mart bag , drive to the store and go to customer service and ask for a refund(if you have the receipt) or ask for an exchange. Wal-Mart is good on that. Good luck!
Jul 09, 2009 | LeapFrog Leapster 2 Learning System
Leapster 2 unit turns on, warning msg re. seizures and flashing lights stays for a few seconds then shuts off. Has new batteries. my daughter has the same problem with hers it turns on and brings up an...
We have 3 Leapsters. The old green model and 2 newer models. Our green one started doing that not long after having it. But it still works and if it shuts off, then we just turn it back on again. When I called up c/s for Leapster, they sort of make it difficult to return. And then I was not promised a new one, but it could be new or refurbished. I let it go. Now w/ the 2 new models, I believe this has happened. I've questioned if my kid's are accidentally hitting the power button. I have seen the green one power off before. I purchased the $10 plug in's. So worth it. No more batteries. And we haven't had any issues. So perhaps it is the batteries. Call up Leapster though and see what they have to say. Good luck! :)
May 26, 2009 | LeapFrog Leapster 2 Learning System
Leapster 2 will shut off right after the "important" screen
Are you using it with a game? Will it stay on if NO game cartridge is in & are U able to access & play Pre-installed games?
If so, it may be the cartridge is DIRTY. I discovered this with our Leapster 2. What works for us is getting a Q-TIP & RUBBING ALCOHOL, you want to saturate Q-tip with the rubbing alcohol & clean the CARTRIDGE (NOT the Hand held ).
You want to clean the computer chip @ the bottom by inserting Alcohol soaked Q-tip on each side of contact strip (the part that inserts into the hand held) & with the dry end of Q-tip go over it again, for more cleaning & to wipe up any EXCESS Alcohol. REPEAT this process until Q-TIP comes back CLEAN.
I was really surprised @ ALL the BLACK grime that came off cartridge.
I hope this helps.
Good Luck.
-The Johnson Family :-)
Apr 06, 2009 | LeapFrog Leapster 2 Learning System
The touch screen on my sons leapster doesnt work.
Buy another one from the same store and just swap them.
Feb 20, 2009 | LeapFrog LeapSter L-Max Console
Just called Leap Frog and apparently this is a common problem (defective screen). As long as it was purchased within a year they will replace it for free. They ask you when and where you bought it. (You have to pay to send the broken one back it was like $5). Hope this helps.
Feb 08, 2009 | LeapFrog Leapster Electronic Book:...
Our brand new leapster2 has
you could try this....
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Jan 21, 2009 | Leapster Learning System
Toys Logo
96 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
