Question about Exercise & Fitness
Nordictrack Elliptical ramp motor only goes up
Ramp only goes up and will not stop running. I have tried calibrating but this didn't work. Magnetic switch seems to be working I checked for continuity. Any suggestions would be appreciated. Thanks in advance, Ron (586) 850-5435
    Top Expert:
  • 12,223 Answers
Dear Sir:
Some different things. 1)Not signal from the console 2) damaged cable or tight 3)the console itself has failed 4) motor control board failed by worn deck 5) the motor may in short. 6) potentiometer geared adjust and lubricate.7) fail or the gearing can slip, giving the console false information
8) Adjust the speed sensor see the diagram attached..9) RUN again the calibration software under the Hood of the motor for easy diagnose and troubleshooting. Any way attached my own block diagram for easy diagnose.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Nordictrack Elliptical ramp motor only goes up - 2_17_2012_12_03_41_am.gif2_17_2012_12_04_00_aNordictrack Elliptical ramp motor only goes up - 2_17_2012_12_04_10_am.gifg src=
Posted on Feb 17, 2012
Nordictrack cx 1055 There is No Resistance. It used to take several seconds to get resistance. But now the resistance is Zero. The Ramp raises and lowers just fine. Is there a video somewhere showi
Sounds like a small control board may have died, more specifically, a failed capacitor or such. Resistance is often achieved by pulsing an "eddy current" brake driven by a transistor, or draining a generator charge electrically, which are attached to a central crank, which stiffens the torque required to rotate and the user sees this as a increase in resistance :-) you can always contact jatinah electronics for further help.
Feb 02, 2015 | Nordic Track Nordictrack Cx1055 Elliptical...
How do I solve Error 42?
Precor Error Code 42 Error Code: 42 Manufacturer: Precor
Model: All Models
Error Description: Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40. Possible Reason:
  1. Bad or intermittent connection in the lift motor controller.
  2. The lift motor requires calibration.
  3. The lift motor potentiometer is bad.
  4. The lower PCA to upper PCA cable is bad.
  5. The lower PCA is bad.
  6. The upper PCA is bad.
Recommended Action:
  1. Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
  2. Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
  3. If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
  4. Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
  5. Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
  6. Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Lift Position Value Out of Range Precor Error 42
May 29, 2014 | Precor EFX 5.17i Elliptical Cross-Trainer...
I bought a second hand Proform 14.0 CE elliptical. The incline is stuck at about 20 degrees. The incline ramp moves slightly while trying to calibrate but remains about 20 degrees. The display shows that...
FOLLOW this steps and fix it. God bless you
Clean the heart rate monitoring pads if the console is not displaying your heart rate when you grip the pads. Use a damp cloth and a mild soap to clean the pads. Do not use alcohol or any other abrasive cleaners that may damage the equipment.
    • 2
Calibrate the ramp if the elliptical is not functioning properly. Press and hold the "Target Toning Workouts" button on the console until the calibration mode appears on the display. Press the "Target Toning Workouts" button once. The elliptical will display additional directions. Use the "One Step Power Ramp" increase and decrease buttons to raise and lower the ramp.
    • 3
Adjust the reed switch by removing the access cover, which sits over the wheel of the elliptical at the back of the machine. The access cover can be removed with a flat-head screwdriver. Unplug the machine. The reed switch provides information to the console for display. Rotate the pulley until the pulley magnet, which is under the belt, lines up with the reed switch. The reed switch has a wire running into it. Loosen the screw to the reed switch and adjust the distance closer or farther from the pulley magnet. Tighten the screw. Plug in the machine and rotate the pulley. If the console still is not displaying correctly, repeat adjusting the reed switch distance either closer or father from the pulley magnet.
    • 4
Adjust the drive belt if the pedals slip while in use. Unplug the elliptical. Lift the latch on the underside of the left pedal arm and slip it off. Use a screwdriver to remove the arm sleeve and pry open the disc panel. Loosen the pivot screw located on the left side. The belt tighten screw is below the pivot screw. Tighten the belt tightening screw until the belt is tight. Tighten the pivot screw. Replace the disc and arm to the elliptical
Oct 24, 2013 | Exercise & Fitness
Right side on E20 Elliptical keeps popping off track. Solutions??
follow this steps and fix it. God bless you
Plug it in. The first troubleshooting step is always the most obvious. Your elliptical machine needs to be plugged in for the console to work. Ensure that the plug is securely placed into a grounded outlet and that the outlet is receiving power. Check that the circuit breaker has not been tripped.
  • 2 Reposition your hands on the handles. If your machine's monitor is not showing your heart rate, first reposition your hands so that you are touching the metal contacts. If necessary, clean the handles with a soft cloth to remove sweat or lotion residue. Do not grip the handles too tightly or move your hands excessively.
  • Sponsored Links
  • 3
    Calibrate the ramp. If the ramp is not positioned correctly, it could need to be calibrated. Often this is done from the console. How you calibrate the ramp is dependent on the make and model of the machine. Refer to the owner's manual or customer service section of the manufacturer's website to find out how to reach the calibration settings on your specific machine. Many companies offer manuals in PDF format for download on their websites.
  • 4
    Adjust the drive belt. Again, your specific make and model of machine will determine how you do this. Usually, you'll need to unplug the machine and locate the drive belt area. This is often beneath the panel housing the wheel and pulley. You may need to find a release latch or use a screwdriver to remove this cover. Refer to the owner's manual for your model to make sure you do not damage your machine.
  • Read more: http://www.ehow.com/how_6737713_troubleshoot-elliptical-problems.html#ixzz2gWAdfrgF
    Oct 01, 2013 | Sole Fitness Sole E20 Elliptical
    E3 error on sole E95 elliptical
    The E95 incline motor is out of calibration. Recalibrate the incline by holding the UP INCLINE button and the START button simultaneously for 5 seconds. This will put the machine into incline calibration mode. Press ENTER to start the calibration and let it run. It will take a minute or two.
    Refer to page 25 (the last page) of the user manual, hidden right at the bottom.
    Sep 20, 2012 | Exercise & Fitness
    Nordictrack cx1055 vibration problems
    see the next steps: Lube and use the logically. God bless you
    Inspect the leveling feet on the rear stabilizer of the elliptical. Note if both sides are not flush to the floor. Unplug the machine if they are not flush to the floor.
  • Turn the leveling feet on one side or both with your hand until they are fully in contact with the floor so the machine will not make noise and tilt sideways during workouts
  • Plug in the machine. Use the machine as normal and listen for any noises. Clean and calibrate the ramp again if there is noise but the machine doesn't rock, and adjust the leveling feet again if the elliptical wavers.
  • Aug 05, 2012 | Exercise & Fitness
    NordicTrack CX 1055 Elliptical ramp pedal wheels
    Hi, You can find them easily on amazon, click here ant take a look: Amazon com Elliptical ramp pedal wheels. Wish you best of luck. Cheers
    Jun 22, 2012 | Exercise & Fitness
    I have an efx 546i and when I try to use the incline the panel states: No ramp, low battery
    The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
    Jan 03, 2010 | Precor EFX 546i Elliptical Version 4
    The ramp will not go up or down. It's states low battery (546i precor)
    Dec 29, 2009 | Precor EFX 546i Elliptical Version 4
    Power ramp does not work.
    Ignore everything above - most of the time this is an easy fix. Usually, it happens with a brand new console, or a machine that has reset itself.
    Hold down the incline up (on the console itself) button and the start button at the same time. Then follow the instructions on screen.
    It will run through an initial calibration, and once complete, the ramp will now work. Just did this with mine, and my ramp is now working perfectly.
    Mar 19, 2009 | Exercise & Fitness
    Exercise & Fitness Logo
    71 people viewed this question
    Top Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
