Question about GE 46GW945 46" Rear Projection Television
Beep My GE 46GW945 was on and suddenly the picture went out and the TV started beeping. Slow and steady. I took off the back panel looking for a reset but did not see one. It sounds like the beep is comming from one of the cards. Pls help.
    President:
  • 3,130 Answers
There are no cards inside this set its stand up printed circut boards as this is not a computer.. the cards are not replaceable as they are fixed to componet level.. if your not a experienced tech Do not attemt to repair or tinker with this set as you can be seriously killed!@ Call a pro to assist you with this repair as there are no user replaceable parts inside this set. good Luck
Posted on Aug 10, 2006
Works but no beeps - how to fix?
Yes look at panel on one of buttons you should see *beep hold in till you hear it beep .
Oct 22, 2015 | Washing Machines
New gateway dx4840 lga1156 core i3 and I get a steady beep sound. not a beep code. even with everything disconnected
I had that happen before when my RAM went bad. I think I shorted it out by not having it clicked in all the way, I don't remember. Maybe try swapping some RAM out one at a time and see what happens. Make sure the RAM is also in its right spots (like if you have 4 slots there is one in slot 1 and not in slot 3) I hope this helps.
Feb 04, 2014 | Foxconn 45CMX socket LGA775 motherboard...
Why does my GE 46GW945 46 in.TV turn on and then right back off?
this is weak power distribution throughout the unit. you wil need to test the power supply board for blown capacitors and resistors as well. replace this vital board if you notice any swollen or disscolored componets.
May 23, 2009 | GE 46GW945 46" Rear Projection Television
Oven comes on for no reason followed by the start beep
yes you can kill the power and lock out the box with a pad lock for safety. the panel is attached by screws usually on the bottom of panel. lower and seperate the control panel ribbon from the erc (electronic range control). without removing any other components leave ribbon loose and replace panel. turn power back on. if the beeping does not recur, the control panel probably has a stuck key. if it does resume the erc is faulty
May 17, 2009 | GE JKP20 Electric Single Oven
Sound but no picture
The first thing to check is the connections to your source. They can easily become loose and/or corroded over time.
Feb 25, 2009 | GE 46GW945 46" Rear Projection Television
No sound. Picture is perfect.
if you have any technical knowledge then you need to change the jungle Ic.
Dec 26, 2007 | GE 46GW945 46" Rear Projection Television
GE 46GW945
Bad IHVT ( flyback transformer ) average repair cost 400.00.
Do you want part # ?----------Please give complete service #
off the back of set........T.
Oct 13, 2007 | GE 46GW945 46" Rear Projection Television
HAS SOUND,NO PICTURE?
YOU'VE LOST VERTCAL DEFLECTION---THIS COULD BE SOME PARTS IN THE VERTICAL SECTION BAD,,LOST A VOLTAGE GOING TO THE CIRCUIT OR WORST CASE ----FLUID FROM THE PICTURE TUBES HAVE LEAKED ON THE CIR BOARDS CAUSING THIS PROBLEM---NEED TECH FOR THIS ONE!!!!!!!!!!!
Sep 15, 2007 | GE 46GW945 46" Rear Projection Television
Have sound but no picture
YOU HAVE A BAD CONVERGENCE IC ON THE CONVERGENCE CIRCUIT BOARD-THIS PART CAN BE REPLACED ,SAVING SOME MONEY,,COULD ALSO BE A LOOSE CONNECTION ON THE IC...PROBABLLY NEED TECH ON THIS ONE --COST 'BOUT 100.00 TO 125.00!
Aug 04, 2007 | GE 46GW945 46" Rear Projection Television
Televison & Video Logo
89 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
