Question about ASUS W90Vp-X2 (90NQXA3931CB8KQL450Y) PC Notebook
Asus w90 screen disassembly
There are several screws located at the base (bottom edge) of the screen housing that can't be accessed, I want to know if anyone knows the proper way to remove these screws in order to replace the laptop screen. this model does not have a screen bezel. Any reference to similar models with screen bezels do not address how to remove the hidden screws I'm referring to. Any help would be appreciated. Thank You
  • Joe Smith Feb 12, 2012
    When the laptop screen is closed, look at the base of the screen housing were the hinges are located and you will see the hidden screws I'm referring to.
SOURCE: disassembling ASUS Degatto Laptop
Thanks Steel Breeze!! I did exact as you suggested and it was easy. I used a Dremmal tool to cut a squre holes. You can actaully see part of the battery (CR2032) through one of the existing holes.
Posted on Jul 14, 2007
Geekman
  • 32281 Answers
SOURCE: trouble seperating top cover from base/mobo / asus f3s notebook
Have you removed the keyboard, sometimes there is a screw under the keyboard that holds the top and bottom of the case together.
Most laptops have clips/indents that clips top and bottom half of the case together. Start on one side, preferrably at an opening where the CD/DVD drive is located and gently apply pressure to separate the case along that edge. Once you free a catch/clip start working along that edge and continuing around to each side of the case.
Posted on Mar 26, 2009
  • 5 Answers
SOURCE: problem with ASUS A3H
ask in the same page in asus drivers, the asus enginers to help you
Posted on Jun 15, 2009
SOURCE: Need parts for broken X83V - anyone know of source
I also found this site http://estore.asus.com/shop/category.asp?catid=627
they seem to have most of the parts but the cord doesnt look the same. They said they could ID it if we sent a pic of it to asusnbtsd@gmail.com, please call me for the case number first as this is necessary to find my case. Thanks
Posted on Jul 14, 2009
byteguy
  • 2229 Answers
SOURCE: Asus notebook K501J Model. A blue wall at bottom
Try this:
Place your cursor at the top of the wide blue band. See if the cursor arrow changes to a 2-sided arrow. If if does, hold down the left button and move the cursor down until the screen is again normal.
Basically what you have done is to take part of the window and increase the size of the bar. This actually should be the taskbar, but it's way too large.
Posted on Oct 30, 2009
How do I change the lcd/vga cable on asus v550ca laptop
A flickering screen indicates a backlit problem. I would personally change out the screen but if you want to do a complete diagnostics and take the long way in which you'll learn a lot.
Tools needed:
Dollar store jewelers screw driver set.
Soft cloth towel
To replace the screen only:
On the screen there's little screw covers on the corners of the screen, removing these sticky little covers will give you access to the screws that hold the screen cover on. Once removed get a guitar pick or even a finger nail and go gently around the screen. Once the screen cover is off you will see the screws that hold the lcd in place and screws that secure the hinges.
Locate and remove the screws that secure the lcd to aluminum side rails. Use the soft cloth towel to protect the screen from getting scratched during removal. Lower the screen towards the keyboard and lay it down on the keyboard.
On the back of the screen you will see a ribbon cable attached to the back of the lcd screen. GENTLY pull down the ribbon cable lock on both sides of the ribbon cable.
The only thing left connected to the screen is the backlight cable, GENTLY pull this plug out taking note of what color wire is on the top and bottom.
Reverse this instruction and happy computing
For COMPLETE laptop dis-assembly follow this link:
Follow this link for complete disassembly instructions with pictures for your laptop. You may want to skip to when the screen gets disassembled.
http://www.insidemylaptop.com/how-to-disassemble-asus-v550ca-db71t/
-Mark
Nov 21, 2014 | ASUS Computers & Internet
Disassemble Miele fascia panel and control
There' s three reasons I can think of for removing a facia plate.
1- replacing a damaged original
2- accessing the control module
3-changing the language
On older models you may have to unplug the unit and remove the top to access screws that hold the facia housing. Then remove the housing to access the facia.
On newer models the screws were placed under the facia so the techs' don't have to remove the top.
Use a plastic paint scraper thin enough to get in between the facia and the housing. Pick a spot along the top or bottom and push straight into the gap. You can only go in about 1 mm until you stop. While still holding pressure inward pry the tool's back end away from the facia - up if your in the top edge or down if your in the bottom edge, until you access the inner step of the housing. Once your tool slips past the step, slide the tool left or right to find the locking tabs and pop them open. The facia will bend a bit. Watch that you don't drop it or it may scratch. The first is the hardest so be vigilant.
If you bought a new Miele Facia panel you should call their customer service support team. That's what they are for. They will be glad to guide you by telephone.
If your just curious to see what's underneath don't bother, unless you like looking at mounting screws for the plastic housing.
Nov 07, 2014 | Washing Machines
IH252 inc monitor bottom half darker than top.
Thin screen LCD monitor brightness controls operate several fluorescent lamps called "backlights" that are positioned behind the LCD display. Typically, they're located around the edges of the screen - sometimes just at the top and bottom, and other times at the left and right edges and others still at all 4 edges.
Fluorescent "backlight" lamp, inverter & connection wiring.
The lamps are miniature versions of those sold in stores. They require a support circuitry called an inverter that convert & boosts the level of DC to AC voltage performing the functions of a ballast in a traditional fluorescent fixture.
The reason a part of your screen remains dark is because one or more of the components in the picture above has failed and will not allow the lamp to shine. Replacement lamps and inverters aren't expensive - but requires patience and the ability to disassemble / assemble the monitor (which is usually harder to do than it appears) and solder. They are available various lengths and color temperatures (you must get a lamp that is identical or it will be noticed). If this is a new monitor - you ought to return it for replacement. If used, consider the cost of purchasing a replacement (new or used) vs. repair.
I hope this helps & good luck!
Jul 29, 2013 | Computers & Internet
Asus x202e repair manual
From what I see the laptop just came out January 2013.
I don't see instructions in the User Manual about how to replace/upgrade the Harddrive, or Ram Memory.
What I do see is the Base Cover comes off to access the above.
Remove AC adapter (Charger), and Battery, turn laptop bottom side up.
Remove all screws going around the outside bottom of the Base Cover, and the one in the middle.
http://techreport.com/gallery/24150/asus-vivobook-x202e-notebook-reviewed/62790/big_bottom
http://techreport.com/gallery/24150/asus-vivobook-x202e-notebook-reviewed/62794/big_guts
At least that's the way it looks to me.
It is covered under a warranty for a year, from what I read.
Why disassemble? Add more Ram Memory?
Replace broken touchscreen? No parts available yet IMHO.
Post additional questions in a Comment.
Regards,
joecoolvette
http://dlcdnet.asus.com/pub/ASUS/nb/X202E/E7620_eManual_S200E.pdf
Feb 21, 2013 | ASUS VivoBook X202E-CT009H Touch Laptop, 1...
I replace the screen on my gateaway mt 6916 and cant install the video controler driver
Instructions
Prepare the laptop for disassembly. Shut down the laptop completely, then wait a few minutes before removing the battery and unplugging the AC adapter. Turn the laptop over and lay it down on a flat surface so that the battery area is facing away from you and the hard drive is located at the bottom left corner.
Remove the hard drive cover. Remove the two screws located on the left side of the hard drive cover, then lift the cover to remove it completely from the unit.
Remove the memory cover. Unscrew the eight screws holding the memory board in place; this cover is located above the Gateway product sticker.
Disconnect the Wi-Fi adaptor. Remove the Wi-Fi cover by unscrewing the single screw holding the Wi-Fi adapter in place; this is located directly above the hard drive. Remove the two cables connecting the wireless card to the adapter and snap the card out of the holder.
5
Remove the memory modules. Gateway computers typically have two memory modules located in the center of the motherboard; lift these out gently with your fingers and set them aside.
6
Release the heat sink. Unscrew the four screws around the heat sink assembly; this unit is located to the left of the ventilation fan and is surrounded by a copper base. Carefully lift the heat sink and the cooling fan off the unit and unplug the cable attaching it.
7
Remove the CD/DVD drive. Unscrew the small screw located to the left of the CD/DVD drive, then push the drive out to remove it from the laptop completely.
8
Remove all screws around the base of the laptop. You will now be left with a total of 18 screws located around the edge of the base of the laptop, and in between the stickers and hardware components in the center. Remove all of these carefully and set aside in a safe place.
9
Prepare the cover for removal. Turn the laptop up on its edge so that the back of the laptop is facing you; you will see two screws on the hinges of the computer. Unscrew these and set them aside.
10
Remove the hinge cover. Open the laptop so that the screen is laying flat; use the flathead screwdriver to pry open the hinge cover and pull it off gently with your fingers.
11
Remove the keyboard. Lift up the keyboard and reach behind it to release the cable. You will need to tug gently on the cable to unhook it from the motherboard.
12
Unhook the LCD screen from the notebook. Unplug the Wi-Fi antenna cables located on the right side of the motherboard directly under the screen, then unplug the video cable located directly under the hinge cover. Remove the pair of screws located to the left and right of the LCD screen and gently lift the LCD screen off the notebook's base unit.
13
Remove the system board. Turn the base unit over and unscrew the five screws securing the motherboard to the base. Two of these are located near the hinge cover, and two are located beneath and to the right of the hard drive unit. The fifth is located a few inches below the top right edge of the laptop.
14
Disconnect the motherboard. Lift the system board, then unhook the cable connecting it to the base unit.
Jan 10, 2013 | Gateway DX4200-09 PC Desktop
How to replace backlight on a ibm thinkpad t23
The backlight fault could be caused by a faulty inverter that supplies high voltage to the CCFL lamp OR the CCFL lamp could be faulty.
The inverter is located at the bottom of the LCD screen between the laptop's hinges behind the plastic bezel surrounding the screen,
The CCFL lamp is located on the bottom edge of the LCD screen behind a reflector that runs along the bottom edge of the LCD screen. The reflector is taped to the bottom edge of the screen.
To get access to the inverter, remove the plastic bezel.
To get access to the CCFL lamp, remove the screws that secures the hinges to the base, disconnect the video cable and inverter power leads from the motherboard.
Remove the plastic bezel, it may have double sided tape securing it to the LCD screen, BE CAREFUL you do not damage the glass on the LCD screen.
Remove the screws that fix the LCD to the lid.
Now you can get access to the reflector and CCFL lamp. Carefuly remove the tape as you will need it to fix the reflector back onto the LCD.
May 10, 2012 | IBM ThinkPad T23 Notebook
I have Whirlpool Duet Dryer that has a noise.
It is common for small items (such as coins) to get stuck inside the dryer drum baffles. You can easily remove them without disassembling the entire dryer. The screws that hold them in place are located on the outside of the dryer drum. In order to access, follow these steps:
1. Unplug the dryer.
2. Remove the top panel of the dryer by removing the three screws located in the back of the dryer holding the panel in place. Once the screws are removed, the top panel slides back, then lifts off.
Each drum baffle has two screws holding it in place. Remove the screws and the baffle will drop into the drum allowing you to easily check inside each one.
Another source of dryer noise is something caught in the blower fan housing. You will need to remove the lower toe panel directly below the dryer door to access. Follow these steps:
1. Open the dryer door and remove the lint screen (the blower fan cover will not come off with the lint screen in place).
2. Locate the screws that hold the toe panel in place along the bottom front edge of the panel. HINT: Propping the front feet of the dryer up can give you better access to reach the screws (a 2x4 works well for this). With the screws removed the toe panel will drop down, then come off.
3. Remove the screws that hold the blower fan cover in place.
Inspect the blower fan housing for any objects that may be vibrating against the fan blades.
If you still need further assistance, please let me know. I hope you find this helpful.
Sep 01, 2009 | Dryers
How do you access the belt tension pulley wheel on a Kenmore Elite HE4 dryer?
First, unplug the dryer. Live voltages are still present inside the unit even with the dryer turned off. Then, follow these steps:
1. Remove the lower panel under the door. The screws are located under the bottom edge. With the screws removed, the panel will drop down, then slide off.
2. Open the door and remove the lint screen. Close the door. (The reason for this is because you cannot remove the blower fan housing with the lint screen in place.)
3. Remove the blower fan housing. There should be three to four screws with a retaining clip on the bottom holding it in place. Loosen all the screws. With the screws removed, pull the housing towards you from the top first, while releasing the retaining clip. The whole unit should come out. NOTE: Some blower fan housings have a ground wire attached. Make sure you disconnect the wire if this is the case.
4. With the blower fan housing removed, you should have full access to the belt tension pulley on the right hand side next to the heating element.
Is there a reason why you need access to the belt tension pulley? If you need further assistance, please let me know. I hope this helps you.
Jun 21, 2009 | Dryers
Trouble seperating top cover from base/mobo / asus f3s notebook
Mar 26, 2009 | ASUS F3SC-B1 Notebook
ASUS W90Vp-X2 (90NQXA3931CB8KQL450Y) PC Notebook Logo
185 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
