Question about Samsung Travel Adapter Power adapter
How to repair travel adapter
Samsung travel adapter model:eta3u30ibe
Where can I get a wireless LAN adapter for my TV, model number:32D5900?
The WIS9ABGN should work... they're about $170 on amazon.com... the Fenvi n600 should also work. That's only about $50 on amazon - Smart Tv Wireless Adapter for Samsung Tv Instead of Wis09abgn Wis12abgnx - either of those plug into one of the USB ports
You could also use a wireless media adapter like the Linksys WUMC710 - Linksys Wireless AC Universal Media Connector WUMC710 (~$35) - wireless media adapters like that plug into the ethernet port instead of the USB port, and 'look' to the TV just like a hard-wired ethernet connection.
You could also go with a set of Powerline adapters... one connects to the TV's ethernet port, and the other connects to a network switch (e.g. the 4 LAN ports on the typical home router), then they talk to each other at 5GHz to 20GHz through the copper wiring in your home (at those frequencies the signal travels mostly on the outside of the wire, due to "skin effect").
A 'starter set' of those will also cost you about $35.
example - TP LINK TL PA4010KIT AV500 Nano Powerline Adapter Starter Kit up to 500Mbps
Apr 04, 2015 | Computers & Internet
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
I have a lead from my tv usb, to the samsung tablet, but i dont know how to get it to connect
Step 1 Connect one end of an HDMI cable to the Samsung Galaxy Tab HDTV adapter.
Step 2 Connect the other end of the HDMI cable to a free HDMI port on your television.
Step 3 Connect your Galaxy Tab's travel charger to the other end of the HDTV adapter. Plug the travel charger into a power source, such as an electrical outlet or a computer's USB port.
Step 4 Plug the HDTV adapter connector into the Galaxy Tab's "Power/Accessory Interface" port. The port is on the bottom of the device.
Step 5 Turn on the TV. If your TV has multiple HDMI ports, use the remote control to switch to the correct one. Press the "Source" or "Input" button on the remote to switch ports. When you're using the correct port, the TV will instantly display whatever is on the Tab's screen.
Feb 05, 2015 | Samsung Galaxy Tab 2 7in. WiFi Tablet, 8GB
Howw do you make a Samsung bd-F5700 blue ray player operate on a 240 volt power supply
You'll need to bring the voltage down to 110-120 volt. Travel converters do this cheap and effective. The player only uses 12 Watt according to the manual. You could use an old 3 prong extension cord to cut of the connector to connect to your power supply. Get the converter below and plug it into the adapter, who then will fit in the extension cord.
25361686-pcx3svhkvlazjixsdsr3jt1v-2-0.jpg New 220V to 110V Step Down Voltage Converter 50W Travel Power Transformer 25361686-pcx3svhkvlazjixsdsr3jt1v-2-3.jpg Generic Round Europe to USA Plug Adapter
Jan 09, 2015 | Samsung Televison & Video
Where can I get a travel adapter / charger for my Digimax A7
The A7 can work with standard AA batteries so you could just pack several extra sets.
Without knowing what country you're in and what country you're traveling to, I can't give you any specific recommendations, but a local electronics or office-supply store should have a selection of adapters to fit the plug of your charger into foreign power outlets. I found one at a nearby Radio Shack for my upcoming overseas trip.
Sep 07, 2014 | Samsung Digimax A7 Digital Camera
I am going to be traveling to southeast Asia. Am I correct in assuming that I should not use a transformer to convert from one voltage to another? If this is indeed correct, could you give me some idea of...
Get yourself a portable Travel Adapter and Power Convertor. The best one we have found in made by BESTEK 200W Travel Adapter & Power Converter, Model # MRJ201GU. Got mine on Ebay for less than $20.
Oct 13, 2013 | Nikon COOLPIX S6000 Digital Camera
Where can i buy cheap travel adapters?
Take a look at Walmart. They have various plug adapter sets at good prices;
http://www.walmart.com/ip/Sima-SIP-3-Sima-International-Travel-Adapter-Plug-Set/10575435
Jan 17, 2013 | Luggage & Travel
When i plug in my samsung smartphone i600 to charge. the charger is not charging my phone but when i plug in the data cable to my labtop its charging my phone
Hi - I have exactly the same problem on a i607 that I just purchased from NewEgg and apparently packed by PDA Giant.
The adapter shipped with my Blackjack is a Samsung "Travel Adapter" part number: ATADM10JBE
which appears to be for blackjack  www.buy.com/retail/product.asp?sku=206563611&listingid=28744535
What have you found out?
Thanks
-Dave
Oct 26, 2009 | Samsung Blackjack SGH-I607 Smartphone
Cannot print from Lap top using usb adapter to cannon printer.
It sounds that your problem might be on the USB to paralel adapter. Do you have another printer ti try it with ? Check the configuration for this adapter.
Good luck
Nov 18, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Samsung Travel Adapter Power adapter Logo
868 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
