Question about Viking Professional VGSC367-4G Stainless Steel Gas Range
Viking professional dual fuel noisy fan
Noisy fan
3 Suggested Answers
  • 23 Answers
SOURCE: Viking dual-fuel range ignition problem
You may have wet it somehow. There are two fixes. Leave them on for 20 minutes on high to let the ignitors dry out. If they dry and stop clicking you have solved it. If not then contact Viking 888-845-4641 and purchase a 6 point spark module. You can try to replace this yourself. With the power OFF. Remove the wires one by one placing them on the new module and then attaching it to the wall. (this is if ur spark module is located under the burners.) If it is in the rear of the unit and u can pull out your range yourself without hurting yourself then you do the same thing. Good luck. If none helps you you may need to replace all 6 burner bases or ignotrs. Also easy. Good luck.
Posted on Sep 18, 2009
heatman101
  • 43501 Answers
SOURCE: Viking Oven Not Working After Self-Cleaning
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Apr 15, 2010
How do i make my convection fan turn off when i open the oven door
It sounds like there should be a switch on the door and it is malfunctioning. I would contact the manufacturer as it should be covered under warranty if it is malfunctioning. Especially for a $10,000 oven.
Dec 03, 2014 | Thermador Ovens
Viking model vdsc4874gss small oven works fine large oven element on bottom only gets hot in cleaniong mode, fan comes on when dial is turned to convection but no heat power is on light works
One thing that you can check is make sure that you have 220 volts at the plug. Leave the unit unplugged and check continuity on the burners. You should have continuity on the burners.
Oct 18, 2010 | Viking 48" 6 Burner, Grill Professional...
Considering buying Viking VDSC4856Q for only 2450.00. Does it require 220 hook-up? Should I buy it? What is your opinion?
no, its 110V if you are thinking of buying the one you listed...its gas and a great range, its just out of my league with the price they ask for them.
Oct 14, 2010 | Viking 48" 6 Burner, Grill Professional...
Where can I locate the model number on my viking range? (48")
Mine was located to the left of the top burners. Remove the grates covering the burners, remove the 'spill' pans, lift up the surface that held the spill pans and then on the LHS you should see a plate with your units details.
Jan 20, 2010 | Viking 48" 6 Burner, Griddle Professional...
Viking dual fuel range wiring
You will need a neutral, ground and 2 wires carrying 120V each
Dec 27, 2008 | Viking 48" 6 Burner, Grill Professional...
Viking Professional VGSC367-4G Stainless Steel  Gas Range Logo
24 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
