My ventless gas heater has an uneven flame with orange tips, the flame toward the outer edge is higher than the flame in the middle, and also,when I light the heater, it doesn't just give me a piolot light, it lights the row in back on low, flickers, and has an unstable flame and then you turn it to low, and it goes out until you turn the regulator knob a little higher, for more heat and it goes out completely, all except the piolot light
    Scholar:
  • 121 Answers
This sounds like your gas valve is weak. An orange flame has to much gas and not enough air mixture. Have you trie to ajust the air mixture. If it won't ajust then you will need to replace the valve.
I hope this helps.
Posted on Oct 24, 2008
Pilot light blows out while heater gets hot. Mr Heater 30000 butu ventless propane wall heater.
call a gas fitter for the repair
could be a freezing of the gas because of a blockage that is restricting gas flow
gas is not a diy repair
Dec 31, 2016 | Blue Flame Heating & Cooling
Orange flame on redstone ventless propane heater
if you got orange flame you got carbon monoxide. That heater needs the burners cleaned.
Jan 11, 2015 | Heating & Cooling
My blueflame gas heater won't stay lit
So we are talking about the same won't stay lit I will describe both ways. One is when you lift your fingers off the knob it goes out that instant which is probably the thermocouple needs replaced,look to make sure the tip of the thermocouple is in the flame of the pilot light first. The secound version of it is it goes out in a few minutes up to a few hours.The second version is most common.There is a part called a Thermocouple that is mounted next to the pilot light, it is around 3/16 of a inch diameter 1 to 2 inches long and should be mounted so the tip is in the flame of the pilot light. This is what tells the gas valve the pilot light is burning. If any dust ,cat hair ,dog fur what have you gets around the base of the hole the gas from this pilot light comes out of it will bend the gas, which move the flame so it does not hit the thermocouple like it should, this is below the flame so what ever is in there diverting the flame dose not burn up.A draft from a fan or door could do it also.I have used a procom ventless heater as my only heat for 7 years and have to blow it out twice a year. I bought a new thermocouple at the same time I bought the heater to have in the closet in case it went bad some night, it is still hanging there .Because it sucks air in from the bottom past the flame and out the top everything in the air gets burnt into a fine ash dust. So if you use compressed air to blow out your unit you might want to hold a wet towel up in front of it hoping a lot of that white powder dust will stick to it instead of flying around the room . My flame always looks so much better ,less orange and more blue after this .
Feb 10, 2014 | Procom Heating & Cooling
Runs an shuts off
Feb 09, 2014 | Procom ML300HGA Heater
Pilot light keeps going off jazz rocco gas fire
Feb 08, 2014 | Procom ML060HPA Heater
Orange flame
Not to be concerned. It is an indication that the burner is dirty. Try blowing it out with a blow dryer. If that doesn't do it, try brushing it with a medium stiff toothbrush. Brush it where the gas (flame) comes out. Then blow it out again.
Dec 15, 2013 | Blue Flame Heating & Cooling
What colour should your gas heater flame be
It should be blue. If it's got orange tips, it's burning dust, If it's got yellow flames or tips, it may need the air shutter adjusted, regulator pressure adjusted, the vent unblocked or just a real good cleaning. Douglas
Jun 05, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
The pilot light on my kozy world ventless wall heater goes out after it burns for a while. Even quicker when the blower kicks on.
weak pilot flame: should wrap around therocouple.
blue flame with yellow tip not yellow and lazy.
if flame good replace thermocouple
Oct 26, 2009 | The Companion Group Kozy World Portable...
Heating & Cooling Logo
221 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
