Question about Philips Senseo HD-7810 Coffee Maker
Senseo machine has started producing very weak coffee
I have had my machine a few months, and only use it from time to time. At first it worked perfectly but the last couple of times the coffee has been extremely weak, both in taste and colour. I have tried flushing the machine out with water again, and cleaned all parts thoroughly. It seems very hit and miss - sometimes on the 3rd or 4th attempt you get a perfect cup! I thought it was faulty pods at first, but it can't be that.
  • 1 more comment
  • karl622 Oct 24, 2008
    Well we have a senseo machine that will only ever produce gnats ****!! It's truly the most useless coffee ever! Its like weak brown pondwater!!
    We've tried everything we can think of short of running the coffee through twice... please help.. I need caffeine!
  • nanohum Jan 21, 2009
    I have noticed the same thing - sometimes it works fine, other times it looks like the water is bypassing the pod. Could it be something to do with the seal?
  • densar Feb 04, 2009
    Have since tried flushing the system out before using and this seems to work. The problem occurs if you don't use the machine regularly, but as long as you flush through with water before using it seems to be OK. Thanks.
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Posted on Mar 18, 2009
    Problem Solver:
  • 17 Answers
Try descaling the machine first, build up may be causing problems. its in the direction book on the senseo site.
If that doesn't work
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Posted on Feb 03, 2009
My Phillips Senseo only produces a small amount of water why?.
Hi Have you tried to clean and de-scale it, limescale can really play havoc with these sort of devices. If you still have the instruction book give it a read and follow instructions for de-scaleing. Also there is a cleaning cycle on some of the models which just flushes the senseo through to clear it out again it is in the book but if I remember rightly you fill up the resoviour then turn it on and put a large bowl under the spout and press both the one and two cup buttons at once. But I would do a descale phillips say it should be done about every 3 months this should also clean out any other muck that has built up, they also say to clean out the pod holder including the little hole. The Phillips website has help if you have lost the booklet.
May 22, 2012 | Philips Senseo HD-7810 Coffee Maker
Dear Madam, dear Sir, I tried four times to descale my coffee machine with Philips Senseo Descaler; nevertheless, the "calc" lamp is still on. What else can I make? With cordial...
Hi. Sounds like a sencor is faulting. Try unplugging it from the power for a few minutes, then start it back up. If you dont have water coming out the your boiler maybe blocked. Id need more information to suggest anything else. Dazza REPAIRER
Sep 24, 2011 | Philips Senseo HD-7810 Coffee Maker
My senseo coffeemaker has stopped pumping hot water through the coffee pods. What do I do to fix it?
When was the last time you clean it with vinegar? Run vinegar through it and you will see hard water scales that were built on the heater. Coffee makers should be clean out every month then with 2 rinse cycles after that.
Jan 24, 2010 | Philips Senseo HD-7810 Coffee Maker
My senseo machine doesn't seem to produce the crema layers even though i've followed all the instruction
You may find that the plastic disc on the bottom of the pod holder is not sealing (there is an O ring) ,if the amount of coffee dispensed is more than usual that will be the problem,just buy a new pod holder.
Oct 06, 2009 | Philips Senseo HD-7810 Coffee Maker
Senseo HD7832 Calc Cleanup
This model of Senseo suggest cleaning once every 3 months, preferably 4 to 6 times a year.
I suggest to download the user manual from Philips for your model and to follow the procedure described.
Jun 12, 2009 | Philips Senseo HD7832 Coffee Maker
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
One coffee cup button switch not wotking properly after 6 months
Jan 24, 2009 | Philips Senseo HD-7810 Coffee Maker
Decreased output from Senseo
I'm thinking it needs to be "Descaled" Heres info from Senseo.com:
Does my Senseo® appliance need to be descaled? Yes. Descaling is an important element in Senseo maintenance. It should be done at least once every three months, up to six times a year!
Keeping your Senseo free of scale will:
  • Ensure you have maximum cup volume
  • Ensure you have maximum coffee temperature
  • Make your Senseo produce less sound while brewing
  • Prevent your Senseo from malfunctioning
  • Prolong your Senseo's life.
The descaling process takes about one hour and should not be interrupted. Only a descaling agent based on citric acid can be used safely in the Senseo. Other agents, including vinegar, may damage your appliance or not remove the scale entirely. If the procedure is not performed correctly, scale residue may remain in the machine. This causes scale to build up more quickly and may cause permanent and irreparable damage to the machine.
For the right procedure to descale your type of Senseo, see attached document.
(links to attachment at the bottom of this page:
http://www.senseo.com/senseous/Templates/NonAuthenticated/FAQs.aspx?NRMODE=Published&NRORIGINALURL=%2fen%2fSenseoUS%2fServiceAndSupport%2fCoffeeMachineQA%2f&NRNODEGUID=%7b5584237E-F754-477A-BDFE-52A5DC85D35C%7d&NRCACHEHINT=NoModifyGuest#a23
Nov 09, 2008 | Philips Senseo HD-7810 Coffee Maker
Amount of coffee produced
you clean the filter with what vinegar you need to use descaler descaler melt calcium vinegar vinegar remove calcium in pieces that might block the machine use descaler 1 part descaler 1 part water put solution in the water tank start the machine after a few second turn it of wait 10 to 15 minute after repeat untill empty rinse very good 2 or 3 full rinse that stuff is corosif thanks for using fixya pierre
Feb 09, 2008 | Philips Senseo HD-7810 Coffee Maker
Senseo coffee maker
Having dismantled and inspected several of this "strange machines" my conclusion is the following:
There is an oscillating-piston pump inside with in- and outlet valve.
It is energized by a microprocessor controlled circuit for a working time depending on the button selected (1 or 2 cups). The pressure and flow are nearly constant for a perfect working pump.
The pod holder restricts the thruput by its central hole. (E.g. you get now an extra pod-holder with a very small hole for expresso type)
So if you don't get enough coffee it may be that
1) the duty-cycle (timing) of the pump has changed.(not often occurring) no repair, you have to undergo electronic and programming work
2) the pump lost efficiency (cylinder of the pump clogged, piston not working with complete stroke, spring force fadening or just one of the 2 valves leaking) ca be "repaired" after dismantling machine ,extracting pump and taking it apart, success not garanteed - grinding valves is already time spending
so my principle before starting this work is to run the machine without the coffee pod to check the water output, use a new holder with clean central hole, if this works it will be nr.
3) the central hole of the holder is clogged, may be not by limestone, but dried coffee extract (grease) clean with needle or even better with micro-drill
Aug 10, 2007 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo HD-7810 Coffee Maker Logo
2,480 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
