Question about Philips SA5125/37 MP3 Player
Corrupted My sa5125/37 says its corrupted everytime i turn it on.It says repair but wen its finished repairing it restarts and still says its corrupted.Please can someone tell me how to fix it>
  • kdizzle13 Nov 09, 2008
    my Philips SA5125/37 MP3 Player is corrupted
  • 8,596 Answers
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be gooOd to go again.
-Tha Mp3 Doctor
Posted on Dec 12, 2008
Startup repair
once the repair starts click cancel or finish the repair and it should restart
Jan 09, 2013 | Microsoft Windows Vista Ultimate Edition
Gateway laptop ml6732 has a startup repair screen and won't boot
Please re install OS .
Please specify what exactly went wrong when u used setup cd to re install
Jan 05, 2013 | Gateway ML6732 Notebook
My compaq presario keeps restarting itself from when i turn it on. it never makes it past the windows xp logo. a blue screen flashes really fast and then the computer restarts itself. Then the same thing...
hi this sounds like you might have a corrupt boot system file, normally the way i have solved this is to re-install windows as a repair ( not a full install ) what i mean is start system up with windows disc in, when prompted go for install, when it gets to a page that says something like, do you want to run repair or clean install run repair, it will seem like it is installing but all its doing is repairing the corrupt file system, when it is finished your system will be as you had it before, apart from my documents, that cleans that out...hope this helps
May 10, 2010 | Compaq Presario 2100 and 2500 ,NX 9000...
My phone is frozzen
It happens when the process is manfuctioned or corrupted. I advise to do a factory reset. To do so, turn off the phone, holdon the home button and press the power button. It will go to recovery console, now select "Wipe to factory setting", once finished, turn off the phone and restart. It should take care of the issue.
Thanks and regards,
Anil.B.R
May 08, 2010 | T-Mobile G1 Android HTC Google Smartphone...
Y it freezes wen in safe mode before starting windows??? it takes forever to load for windows to come on. It freezed and does not wanna start wen in the configuration nore eaither and wen in the safe more...
your windows has been corrupted so you can solve your problem by repair install your windows....insert your bootable isntaller in the cd room...boot should be oin cdrom....when the cd finishes inializing and told you to install press enter...it search for your previous operating system...when it recognize press R or repair install..do not choose the fresh copy install it should be a repair install procedure...after installing it it will come to normal your o.s now...hope this would help.
Oct 19, 2009 | Acer Aspire 3000 Notebook
Plastation 3 hard disk's file is corrupted.....
nike362
If you are getting the corrupted drive message and the built in PS3 options are not fixing the drive then you will have to pull the drive and format it externally with a computer. The link below will help you do this.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jul 06, 2008 | Sony Playstation 3 (PS3) Console
Songs go into a scattered order.
It is possible that the memory or settings have been corrupted. Install and run the Philips Device Manager from the product CD.
Select the restore / repair option and follow the on-screen prompts.
This will re-install the firmware and format the player.
When the process has finished, restart the player. It will initiallize and then shut down again. Switch on again and you'll get an "updating" message. The player will now be empty. This should also cure the alphabetical list problem.
Feb 15, 2008 | Philips GOGEAR SA6045 MP3 Player
My computer kept on restaeting
there is a problem in your operating system a corrupted file, you need to repair by running your winxp cd click repair after rebooting and running with your cd. in dos prompt, type CHKDSK. there is another option in repairing this thru winxp cd instead of format you may clicl repair
Dec 19, 2007 | ASUS P4P800 SE (890552603657) Motherboard
K700i keeps restarting
While transferring data from from another phone via blue tooth it would have got corrupted.I suggest you go back to the factory settings in your phone and press Restore Factory Settings.If this does not work you will have to take it to the phone shop and get it formatted which will solve your problem.
Dec 16, 2007 | Sony Ericsson K700i Cellular Phone
Philips SA5125/37 MP3 Player Logo
65 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
