Question about Dehumidifiers
Has anyone got a manual for my challenge ram 710 dehumidifier
I am not sure i am using it right as it leaks from a pipe underneath. who are the manufacturer
2 Suggested Answers
SOURCE: Hi... I have a challenge ram 710 dehumidifier, the
I also had exactly the same problem with my RAM170 Dehumidifier, it's a very common problem with them. The good news is, assuming the motor winding has not burnt out, then problems with the fan motor can easily be corrected. It's now over two years ago that I carried out the following procedure with the motor in my RAM 170 and it has continued to function with no further problems. Firstly take a photograph or make a drawing of the motor assemble, then fully dismantle it. Thoroughly clean all the black (gungy) mess off the spindle and bearings, WD40 is good for this. Next apply a small amount of light grade oil (it must be thin oil) such as Singer Sewing Machine oil (about 60 pence for a small can) to the spindle and bearings, then fully reassemble. When assembled the motor should spin freely.
Posted on Nov 21, 2010
I have just bought a secondhand challenge 414/0038 and I cant find where you empty the water when using dehumidifier?? As you can guess I didn`t get any instructions with it
There is a rubber bung on the bottom of the back of the unit. You remove this bung and water will drain out.
However you should read the manual because most of the humidity is supposed to come out of the exhaust with the hot air. I'm not sure how this works but it's in the manual
Please find the manual you need here:
http://www.stator.me.uk/414-0021.pdf
This covers 414/0038 and 414/0021 Air Conditioning units by Challenge
May 24, 2015 | Dehumidifiers
Why is it not collecting water in container?what can i do? do i need the manual?
oohn ive seen this before in some units especally on ones that are in heavy use (lots of water to remove) the drain hole inside unit drain gets stopped up with black mold (wet enviroment it grows quite well) unplug unit and some minor dissasembly of the outter case and it soon becomes obvious what the problem be , i have been somewhat sucessfull with a mild laundry bleach in a trigger sprayer to kill mold and use a pencil to poke open drain holes
I'LL bet thats your problem
Oct 20, 2014 | Dehumidifiers
I just came home to my DeLonghi (DEN500P) leaking on my basement floor. The bucket will not fit flush because the clear drainage tube has detached. I use the manual emptying method. I have the manual,...
there should be a pump somewhere near the pan, the pickup for the pump must go into the drain pan somewhere if you can find the pump, the nipple the hose attches to is close by please rate
Aug 01, 2011 | DeLonghi DE500P Dehumidifier
A very old, extremely heavy dehumidifier sat in my mother's basement for decades. I decided to dispose of it, but I was unaware of the freon inside it. In order to extricate the dehumidifier I had no...
Yep the ref is all gone, The EPA says that the oil is hazardous, actually its just mineral oil the at one time had ref. R-22 in with it.
Jul 03, 2011 | Dehumidifiers
Hi... I have a challenge ram 710 dehumidifier, the fan has stopped working but there is power to it, when i took it out it is all greasy and black like all the lube has seeped out... does anyone know where...
Feb 15, 2010 | Dehumidifiers
Dehumidifier (challenge 12ltr) gives off a smell a nasty when running.
Clean the filters and the coil. Use a mild bleach solution if there is mold present.
Oct 03, 2009 | Dehumidifiers
Delonghi dehumidifier cf05m does not collect any water, why?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Aug 18, 2009 | DeLonghi DH100P Dehumidifier
To connect a drain pipe
Find where the leak is coming from. Is it coming from the connection where the tube goes into the dehumidifier or where the garden hose screws on? If it is where the garden hose screws on make sure it is screwed on all the way. If it is you may just need to replace the rubber washer in the garden hose.
Jul 25, 2008 | LG LD65EL Dehumidifier
Dehumidifiers Logo
450 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
