Question about Keurig Elite B40 Coffee Maker
Keurig says auto off set....need to turn it on
After unplugging..... I plugged it back in and it will not turn on...in small font it says auto off set.
    New Friend:
It's just off. Flick the switch on the back.
Posted on May 04, 2016
  • Andrew Cruz
    Andrew Cruz Mar 13, 2018
    I made an account just to vote and comment on this post. You're a lifesaver. It took over 20 minutes of trying to get myself a cup of coffee at a friends house! Thanks dude.
  • 1,511 Answers
LIne surge blew circuit board LED, retrun for replacenet.
Posted on Feb 07, 2014
3 Suggested Answers
SOURCE: keurig lights flashing
Just had this happen to me and ended up talking to Customer Service. Apparently, it's a bad thing to unplug them (sm. computer inside) Tho it didn't work for mine, here's their advice. With the handle down, hold down the smallest cup size and the power switch at the same time...release and immediately push the sm. size button 3 times rapidly....if that doesn't work, hold down both cup sizes and the power switch....if that doesn't work, get a new Keurig
Posted on Jan 27, 2011
billvaltman
Holding down the Auto Off and the both cup sizes worked for me as well. I rcrvcd my answer from Bryan above in the comments section
Posted on Dec 29, 2012
How to make a keurig 2.0 stop flashing and set the time
on the upper right corner is a icon tap it it'll open a set up program. touch clock.. set the time. touch save.
if that doesn't work unplug for 20 seconds and plug back in and try above again.
Hope this helps
Dec 26, 2017 | Keurig Coffee Makers & Espresso Machines
All my lights are flashing and they don't want to stop mashene is not working
1. Press the auto off and small cup at the same time. Then Immediately release and re-press the small cup three times.
When it works the only light showing will be the descale light.
2. Press the small cup button then auto off button then release small cup and then auto off, when this works the lights on will be the power button light and the descale light.
ALL OF THE ABOVE DURING THE PROCEDURE MUST BEEN DONE FAST OR RAPIDLY.
3. When both of the above lights are on,(power and descale), unplug for about 3 to 5 seconds... and plug back in. The brewer should come to life and work normally.
Below is the address and Phone number to Keurig warranty service.
Keurig, Incorporated
101 Edgewater Drive
Wakefield, MA 01880
1-866-901-BREW (2739)
Nov 12, 2014 | Keurig B40 Single Cup Home Brewing System...
What does brewing time off mean
You can try the reset for the B60. I do bot understand your original What does brewing time off mean??...
1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
Jul 02, 2014 | Keurig B60 Coffee Maker
Cannot reset auto settings on Keurig coffee maker
Hold Button 6-10 Seconds it will turn off.
Apr 15, 2013 | Keurig B60 Coffee Maker
How to reset keurig b40
1. There is some confusion over models. I've seen "B40" models and instructions with only one size cup button, both labeled B40. I own one stamped "B40" on the bottom, and it has two buttons -- small and large. FWIW, small = 8 oz, large = 10 oz.
2. These reset instructions from another site seemed to do something
What to Do If Your Keurig Won Brew Cup Barista
So.. this is what I did that worked for mine: 1) Hold down Auto-Off and LARGE cup at same time. (all lights should hold steady ON) 2) press SMALL cup while still holding Auto-Off and LARGE cup 3) Release all three, press LARGE cup again.. all lights should go off. 4) Unplug for about 5 - 10 second, plug back in. SHOULD WORK!
3. On *_my_* B40, remove the K-cup, close the door, fill the reservoir. Unplug and replug the B40. All lights should be off.
Pressing "Auto Off" and "Large Cup" together will turn on 3 lights (Heating, Add Water, Power) for about 3 seconds. Doesn't matter how long the buttons are pressed or what order they are released.
I tried lots of add-on combinations: e.g. press button x, press x multiple times, press x while lights are still on, press x after lights are off, press buttons x and y together, press x then y, press x and/or y while still holding Auto and Large, release Auto but not Large and press x, etc.
Nothing gave any confirmation that a reset was accepted. All lights always turned off after 3 seconds. Maybe Reset is only 1 step, i.e. Auto+Large together?
Jan 04, 2013 | Keurig Elite B40 Coffee Maker
Coffee maker keeps saying not ready, has water, is plugged in and on, auto timer is off, have unplugged and plugged back in, any suggestions? Thanks!!
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Aug 21, 2011 | Keurig B60 Coffee Maker
Our Keurig B60 displays "NOT READY Auto off set" and does nothing. What can we do to bring it back to life?
Press the off/on switch and poof on the machine and then check. If that is not helping then try this procedure as follows:--- 1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen .) You should see a time 6:09 on your screen.
--------- If this instructions also not helping then try this, instead of holding the medium cup while pushing and releasing menu .you simutaneously push and release medium cup and menu and then medium cup and small cup and then check out. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Aug 28, 2010 | Keurig B100 Coffee Maker
My Keurig B60 does not run at all. The screen comes on and says: Not Ready and also says auto off set. The cup lights do not flash. I cannot get the menu to come on. Unplugging it and plugging it in...
Not sure if this will help, but I had the same problem over Xmas. This was posted 8 Jan, and I cut/pasted it here. Sounds complicated, but it's not. Just print it off instead of trying to remember it! I'd be interested to see if you had the same 'codes' as I, and if your machine had hot water when it ran... I have not done anything since that post...
Patient: Keurig B60
Symptom: "Not ready" light is on. Reservoir is filled and needles are clean, so problem is not user related.
Internet search yeilded some hope for another Keurig machine. While turned off, simultaneously press and release the small and med button, then menu three times. You get into a programming/diagostics menu. As you scroll (via the menu button) mine says Ready 602, Brew 265, Autooff 099, Set 007, Set/set 099, Descale 099, and Menu 000.
While at 000, press the med button but do not release. Press and release menu and immediately press small, then let go of small and med together. Pump runs and water is circulating, but is cold. Not sure if it should be cold (just a test routine, etc) or whether the heater is blown or something more troublesome.
Anyone have any ideas/experience with this information (I have no problem in ripping the machine apart if I have to. It can't be that complicated!).
Jan 31, 2010 | Keurig B60 Coffee Maker
Reset Procedure?
I have a B60 and it does not have the "NOT READY" problem when I did the "priming" process. So I brought this B70 during Christmas this year, I had the exact "NOT READY" problem during the "priming" process like most of the people here. They sure DO have some engeineering/quality control issue here. No water was coming out and it looked like the pump had some kind of problem in getting water from the tank when the "priming" process was taken place. Instead of waiting a technican to call me back on Monday, I decided to ask my friend Google. It appeared there are a lot of people have the same problem and only ONE of the postings offered a solution and it WORKS!!! Here is the link and the extracted method in showing you how to reset the B70 so that you can retry the "priming" process. PS: You may have to try MANY times for the step #3 as described. http://www.all-about-coffee-makers.com/my-experince-of-keurig-b66-coffee-maker.html Fixed Not Ready Mode by: Anonymous Bummed - I talked to Keurig this morning (Dec 27, 2008). There are 4 steps to fix this: 1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen. 2. Press "menu" once. Your LCD screen should say Brew 0:00. 3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly. 4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
GOOD LUCK :o)
Posted by: Harry at December 28, 2008 10:05 AM
Jan 10, 2009 | Keurig B60 Coffee Maker
Keurig lights flashing
Nov 30, 2008 | Keurig B100 Coffee Maker
Keurig Elite B40 Coffee Maker Logo
13,204 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
