Dvd drive my dvd drive of laptop cannot detect dvd to burn
  • Computers & ... Master
  • 27,725 Answers
Make sure that the cd rom is getting enough power test all leads that are attached to the cd/dvd drive and make sure they have a secure dust free connections or just replace them they might be bad/faulty
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question / exclamation mark ? ! or a red X right click to update driver or select properties general troubleshoot
if your computer came with a motherboard disc the sound drivers could be on it
you might have to physically unplug the leads for this dvd rom restart your computer then plug them back in this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Feb 13, 2012
2 Suggested Answers
Chinthakaj
  • 416 Answers
SOURCE: dvd drive not detected
If you have some experience in opening up the PC. remove the main cover & unplug the power connector & the Data Cable from the DVD Drive. ( the conputer power has to be switched off) Replug back the cables as it were & start the PC.
It should detect by now
Posted on May 08, 2010
Describe how you insert a dvd into a laptop
Hi Eunice, just want to clarify, for lenovo notebook if it doesn't have DVD drive you can use external DVD drive to access DVD CD. DVD external drive is just plug and play device once attached in your USB port, it will automatically detected and once detected you can use it already. Just install Burner application to burn some files if your DVD is capable of burning CD.
Jun 22, 2011 | Lenovo 3000 Y410 (59012354) PC Notebook
Cd drive cannot burn cd
Does the external DVD-writer work when connected to some other computer?
Jul 16, 2009 | HP 530 Notebook
CD/DVD Burning drive not detected
pls take alook at page 5-16 on this document:
h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Apr 17, 2009 | HP Compaq Presario V2000 Notebook
My cdrw burner is not functioning
Pull and replace the optical media device
This may not be the easiest chore you ever have as with Dell, their proprietary techniques are often called for in the absence of a technician who knows these techniques.
Service at Dell facilities if available or preferred.
Mar 30, 2009 | Dell CDRW/DVD COMBO DRIVE INSPIRON 1100...
EMPTY DVDS ARE NOT DETECTED BUT SOME SOFTWARE DVDS DETECTED.
This seems like a hardware problem you are experiencing. I would suggest using them dvd cleaning acessories and if not, replace the drive.
Feb 22, 2009 | Acer Aspire 5100 Notebook
Drive Can't Burn DVDs
Depends on your burning software and drivers installed for it. I have seen windows not detect some DVD burners correctly.
Apr 21, 2008 | Compaq Presario V2410US Notebook
HP CD-RW DVD RW COMBO
I HAVE AN HP LAPTOPmag-glass_10x10.gif WITH CD-RW AND DVD RW ON IT BUT WHEN I TRY TO BURN EITHER OF THE TWO IT SAYS DRIVE NOT DETECTED. HOW CAN I MAKE SURE IT IS INSTALLED PROPERLY
Apr 01, 2008 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
Help with burning off my home made dvd on my laptop Acer Aspire 5610z
TRY CLEANING WITH LENS CLEANER ELSE THE PROBLEM MAY BE ALIGNMENT NEEDS TO BE DONE AT SERVICE CENTER (RECOMMENDED /OPINION) ELSE CHANGE DVD ROM
Mar 07, 2008 | Acer Aspire 5610 Notebook
Will not burn any dvds
Try upgrading the firmware.
2.) Try the drive on another computer to see if it works.
3.) if it does you might need to Format and Reinstall on your computer.
but it does sound as if the problem is with your drive rather than your pc if you got warrenty i'd suggest you take it back if not then try it on anoter computer to ensure its the drive before getting a new one
Oct 16, 2007 | Pioneer DVR-S111B DVD RW Dual Layer Burner
DVD-RW drive not detected in my laptop by SOME software
I am asuming your using XP, this happened to me a few years ago, i searched google and found a forum that had instructions on editing a registry key to fix the problem but i wasn't able to see the drives in the device manager at all, so check that first and make sure they are there and try reinstalling the device drivers,using windows update or manually search for newest version of the drivers, if all that fails try reinstalling the applications your having issues with, if that fails you can try getting another application to replace the ones that aren't working, try alcohol 120% or Nero, those are about the best out especially a120 however it would require a purchase.
Apr 12, 2007 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Open Questions:
Cloud Backup For Small Business 'Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jun 19, 2018 | Quantum Computers & Internet
Computers & Internet Logo
David Payne
David Payne
