Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
A buzzing noise
I just installed 3 f2548/240 baseboard heaters and on the end away from the control there is a buzzing noise and it is rather loud in the Quiet room. Wonder why and if there is a type of thing to put in line to quiet it down. My e-mail: miller.c.e@worldnet.att.net thankyou
    Scholar:
  • 68 Answers
Why do you say put in line to stop the buzzing? What is it that tells you the wire is creating the buzz?
It could be anything from a loose sheet metal part, rivet, fan, transformer, loose connection, or just the way it was built, although a loud buzz sounds like a problem waiting to happen to me.
No there is nothing to put in line to make it quit buzzing, I need to know all the information about the device, voltage, amps, brand, and then tell me how it is wired including number of wires, size of wires, voltage, how it is wired to what colors, how far from breaker, what breaker and size, and anything else that seemed unusual to you during install if anything.
Write me back here or allexperts.com or wbwill@sbcglobal.net.
Posted on Nov 15, 2008
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 06, 2012 | Rheem Water Heaters
Installing hot water baseboard heater
IF THEY COME WITH THE COVERS SET THEM AGAINST THE WALL WHERE TO BE INSTALLED, THERE ARE MOUNTING BRAKETS INSIDE THE WALL PLATE AND THE PIPE SHOULD SIT ON THE BRACKETS,, APROX 3-4 INCHES OFF FLOOR,
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
Buzzing plenum heater
is the fan relay going bad it is located normally inside control box behind panel where wiring enters unit
Jan 04, 2009 | Heating & Cooling
Fahrenheat baseboard heater
no this is normal for this type of heater during its run time,I hope this makes you feek a little better!
Oct 24, 2008 | Fahrenheat Built-In Baseboard Thermostat...
Can't find replacement parts
Hi google intertherm furnace parts they sell parts on line you may find what you need on there
Oct 22, 2008 | Fahrenheat Electric Convector Baseboard...
Smell
the heat may be affecting the unit's paint. normally the oil used in manufacturing burns off the first time the unit is used. maybe the proximity of the element to the case is too close.
Dec 19, 2007 | Fahrenheat Electric Convector Baseboard...
2000 watt baseboard heater is making loud clicking noise
Most base board heaters installation instructions say to attach to the wall with screws which are slack ( not fully tightened) in order to allow the heater case to expand and contract otherwise you get a clicking noise
Nov 17, 2007 | Heating & Cooling
Loud humming
If this is an electric resistance heater then there is no power supply or transformer. I had a baseboard heater that would hum loudly and I found there's a wire that runs along the bottom to connect the far end of the heat element to the electrical wiring at the supply end. This wire becomes magnetized from the current flowing through it and vibrates in the channel it runs through. I was able to open this channel and squirt a bit of silicone caulk in to keep the wire from vibrating and the hum is gone.
Dec 19, 2006 | Honeywell HZ514 Baseboard Heater
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
652 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
