Question about Intel D102GGC2 Motherboard
Emachines W6409 won't start up.
Emachines W6409 powers up, fans run, HD spins, but no light on screen at all. Have tried new power supply, pci video card, and RAM, same results. There is a green led lit on the motherboard, and I can get beep codes if I start without RAM.
  • ron6962 Feb 13, 2012
    Thanks for the reply and the suggestions. I have tried them all, even to the point of removing the board from the case and unplugging all hardware not required to boot. Same results. I am curious if there are any tips to help point the problem to the motherboard "or" the processor. One of them has to be causing the problem, and I don't have access to a spare processor to test. Thanks.
  • Intel Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions, DE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin ide it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electrical power and data to travel through every working device its and have an end so any faulty leads will end up with a computer error
make sure your ram and cmos battery are securely seated with no dust in sockets
some motherboards cmos batteries are soldered in
hope this will help you
Posted on Feb 13, 2012
Gateway dx 4320 wont turn on
It could be a few things:
a faulty power switch - you say that you've changed the PSU, but did that include the switch?
it could also be a Faulty Motherboard or CPU. If either of them are fried, you won't see anything come on either.
I'd suggest checking the switch first because that's the cheapest and easiest to replace
Sep 14, 2012 | Gateway DX432019 PC Desktop
PC wont boot
Check your specs for this one on your Card (should be on the box or in your included documentation), but I believe your card is PCIE v2.1. If this is the case, your card won't work. Your mainboard is an older one, and you can tell by the black PCIE slot that it is only PCIE 1.0. NOTE: PCIE v2.0 cards will work with PCI v1.0 as long as they meet power requirements, etc. (yours should be fine) but there are no updates to fix this on your mainboard. Time to dig out your receipt and look over the return policy. Again, a PCI v2.0 should work OK, just not the v2.1 cards.
Please take a moment to leave feedback if I helped you out today.
Jan 27, 2012 | Sapphire RADEON HD 6750 1 GB DDR5...
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working
Could be your motherboard. Does anything come up on the screen at all when you boot up? Do you hear a beep at startup? Also check to make sure your hard drive is spinning just to be sure.
Dec 09, 2011 | E-Machines Computers & Internet
HP Pavilion a1230n had bad power supply I changed it out for a better one of the same make and model. Now when it turns on I can hear the hard drive spinning and the fans running but it beeps every few...
If the beeping is coming from the power supply, that typically means that you are pulling too much wattage. I would recommend trying a higher wattage power supply. The video card is one of the lowest things on the computer's list of things to keep running at all costs, because even if your video card flickers off, you won't lose data. Before getting another new power supply though, I would ensure that your video cables are properly plugged into your video card and your monitor. To be sure that they are snug simply screw them in so that they don't wiggle at all when you pull on them.
Jun 10, 2011 | HP Pavilion a1230n (EG134AA) PC Desktop
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
My computer won't start. Power supply (ttgi 450ss) has a blinking green light and the power supply fan starts when plugged in. Motherboard (asus m2npv-vm) has a green light illuminated between the pci...
See if you plugged in the 4 pin power connector on the motherboard besides the main power connection on the power supply (usually black colored and its a plastic 4 pin connector)
Try another power supply if all else fails. If new power supply does not work with this unit then its a motherboard which is blown and motherboard needs replacing.
Hope this helps
Mar 16, 2010 | TTGI SUPER FLOWER 450W quad fan switching...
When I turn it on, only the fans run. I cannot hear the hard drive run and the hard drive light on the bezel is solid yellow
look on bios to see if detects the hard drive ...if does not boot to windows...the hard disk has no reason to go on ....and the issues could be many ....check the Ram memory if do not appear anything on screen at all ...and just runs the coolers and clicks without boot at all...in this case its the Ram memory ...so check it ...get it out ..put it back ...and remove the bios battery to force it see them again .....if it is booting until the operating system should appear ...and after that nothing ...reinstall ...
Also .....if there is anything written on the screen ..read carefully ..usually it will say whats wrong ...and advise in same issues..like replace hdd ...or files missing ...or blue screen error from memory issues..
Nov 07, 2009 | E-Machines T6216 (827103077834) PC Desktop
Emachines t2899 will come on and fans run but screen is still blank
Actually, the monitor is fine. The problem is that the computer isn't booting. The power comes on and the fans spin, but the system board isn't starting. Try reseating the memory modules in their sockets and clearing the CMOS memory using the jumper on the system board. If the problem continues, try another power supply. Finally you may need to replace the system board.
May 13, 2009 | E-Machines T2899 PC Desktop
GIGABYTE GA-81K1100 wont boot
In short, new motherboard time. Something small & irreplaceable is dead.
Feb 18, 2009 | Gigabyte GA-8IK1100 Motherboard
Intel D102GGC2 Motherboard Logo
133 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
