SOURCE: IBM ThinkPad R40 Intel Centrino Upgrade to Intel Core 2 Duo?
No, your motherboard does not support the Core 2 Duo family.
SOURCE: i have intel dg35ec motherboard & intel p4 2.4
This is a laptop?? If those specs are correct then the laptop will run pinnacle studio 12 ultimate beautifully without any modifications.
SOURCE: Which is better laptop deal?
Hi !!
Ofcourse 2.4 ghz is better than 2.1 ghz but its not a very big difference if price difference is more than 100$ than go for first one else second one is good and the most important thing i want to mention is that it all depends upon your needs you havent mention for what purpose you are going to purchase. But both are enough for gaming, daily use and for techie as well.
Hope that helps
Thanks
SOURCE: How do I remove forgotten BIOS password?
1) You can reset BIOS to default settings by pressing <Alt><F>
2) I am not sure about the laptops, but in the Dell Desktops usually there is a reset jumper on the motherboard which is seated on 2pins out of 3, you just need to remove that jumper turn on the pc once and the turn on the pc again by reseating the jumper to its original place. You can try this with your laptop, I guess the jumper should be somewhere close to the CMOS battery.
3) Remove the battery and keep it away for atleast 30 mins. and replace it again.
NOTE: make sure while following step (3) and (4) the system should be completely turned off. Unplug the AC adapter, remove the battery and hold the power button for atleast 8 - 10 seconds.
let me know the output
