Question about Seiko Clocks Melodies In Motion QXM135BRH Watch
Seiko clocks melodies in motion reset - Seiko Clocks Melodies In Motion QXM135BRH Watch
4 Suggested Answers
mcdevito75
  • 1970 Answers
SOURCE: I have a Melodies in Motion Seiko clock that is
mcdevito75 here, Sounds like 1 or both hands are hanging up on themselves or something on the face of your watch, look for a small watch repair shop in your area, or check here at fixya, bottom of page, click on repair service directory the watches.
Posted on Jul 03, 2010
gemineye61
  • 831 Answers
SOURCE: my seiko motion clock face opens and does not
Thank you for contacting FixYa
I am not as experienced in the clock side of Seiko, but I did find their website and it is filled with great recommendations for clock repair. I would highly recommend you contact Seiko on this.
Best regards. Here is a link to go to:
http://www.seikoclocks.com/#FAQ
Thanks for your rating too!! Jewel
Posted on Sep 02, 2010
oldgoldguy
  • 69 Answers
SOURCE: I need to know how
i had that clock hre. and all the insides are special from seiko, i would send it to them. the movement is encased in plastic and some lever rods attached to them . may be worth sending
Posted on Jun 17, 2011
SEIKO ALARM CLOCK SQ767W MANUAL i GOT TWO OF THEM AND THE INSTRUCTIONS ARE IN CHINESE
The normal clock/alarm functions of the Seiko SQ767W work worldwide, but because the feature that automatically sets the time via radio signal only works in Japan, Seiko only provides the manual in Japanese.
https://www.seiko-clock.co.jp/product-personal/digital/temperature/sq767w.html
https://www.seiko-clock.co.jp/product-personal/up_files/FSQ-125P.pdf
Here's an English version I made with the help of onlinedoctranslator.com (uses Google Translate). I made a couple of adjustments but it's still pretty rough due to the machine translation.
https://1drv.ms/b/s!AKpNuPb-kshMyTo
Mar 08, 2018 | Seiko Watches
Why is acid dripping out the bottom?
You may have to clean up again and next time install better quality alkaline batteries.
Aug 18, 2015 | Gift Warehouse Seiko Melodies in Motion...
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
My seiko motion clock face opens and does not close back all the time I have replaced the batteries but it still stays open
Sep 02, 2010 | Seiko Clocks Melodies In Motion QXM135BRH...
I have a Melodies in Motion Seiko clock that is about four years old. It still keeps great time. However the face movement sticks about half-way through it's movement. Any idea of how to repair the problem...
Jul 03, 2010 | Seiko Clocks Melodies In Motion QXM135BRH...
The glass front of my beatles clock broke.
you just go to a clock store and look for the same thing and just buy it.
Mar 08, 2010 | Seiko Clocks Melodies In Motion QXM135BRH...
The chronograph second hand now resets to the 5 O-Clock position?
I have found instructions that tell you how to reset the hands but there are several buttons on your watch and to avoid confusion you really need to see a diagram.
You can do this by going to the Seiko web site (seiko.com), click on "support", then "instruction booklets".
Scroll down the next page and you will see a list of the watches made by Seiko. Select yours and download.
Go to page 16.
Jan 23, 2010 | Watches
Reset timer after battery change in seiko sna285
If the stop watch hands are not in the "0" (12 o clock) Position, follow the prodedure below to set them to the 12 o Clock position
1, Pull the crown to secound position
2, Press Button "A" for 2 seconds.
3, Press Button "B" to Adjust the minute Hand to "0" Position
4, Press Button "A" for 2 secounds then press Button "B" to adjust secound hand to "0" Position
5, Press crown into normal position
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Aug 28, 2009 | Watches
How to change the hour
Anniversary clock hands can be adjusted directly moving the minute hand clockwise. Do not touch hour hand as this may cause hand disalignment. Carefully move minutes hand with your finger all the way around till you reach desired time.
Do not forget to rate, please.
Mar 09, 2009 | Seiko Clocks Melodies In Motion QXM135BRH...
Seiko Clocks Melodies In Motion QXM135BRH Watch Logo
35 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
