Question about Samsung DV448AGE Gas Dryer
Drum will not spin
I can select everything, but when I push the start button, nothing happens. The timer still counts down and there is a faint clicking everyso often
    New Friend:
While most Samsung dryer component failures will generate a trouble message on the display, a failure of the hi-limit thermal protector won't. If the hi-limit thermal protector has opened, it directly interrupts power to the drum motor. As a result, you can start a cycle using the buttons, the 'brain' will turn on the relays controlling the motor ( the faint clicking sound ) and run the cycle timer, but the motor can't actually run. And without drum rotation being sensed, the burner won't turn on either.
Solution is to replace the hi-limit thermal cutout, which is located on the 'nose' of the blower assembly next to the dryer temperature control thermistor ( which is slightly larger than the hi-limit thermal cutout ).
Also note that the usual cause of a hi-limit thermal cutout failure ( or a thermistor failure ) is ducts restricted by lint ... both the burner exhaust duct as well as the blower intake duct. Both should be disassembled and thoroughly cleaned while you have the dryer apart.
Posted on Jul 29, 2013
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Panel powers up, no codes, but the drum will not
Hello Jim,
I'm glad I was able to help you. Hopefully you can return the help regarding my assitance on the chat session for your dryer.
For some reason your accepting my solution has not been recorded although you rated the help as 4 thumbs up...my account shows the solution was rejected.
Perhaps you can log in again and amend the error, as much as I like to help with the chat sessions, it is based on customers honoring the system and us experts providing help on the premise of getting paid.
Thank you.
Regards,
Macmarkus :)
Posted on Jul 11, 2011
Testimonial: "Very fast and professional help. Had a handle on the problem right away & gave me the solution. Sent me to a site to view how to fix it! Great!"
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Apr 13, 2015 | Sharp R530EWT Countertop Microwave Oven...
Samsung dryer will not spin.
you must check the timer might not have contact in the terminal although it was starting to count. then you check if their is a voltage that is coming from the motor, and check weather the starting capacitor has resistance or worn out.
Aug 16, 2012 | Dryers
Our whirlpools dryer is heating but when i push the start button nothing happens. the light comes on when opening the door and timer counts down.
The drive belt has broken. Copy the model and serial numbers and go to an appliance parts store for a replacement. You will have to pop the top off by inserting a putty knife in the front corners to release the clips, and depending on how you dryer was built, remove the front or the back panel. Slip the new belt over the drum, move the belt tensioner to the side, then loop the end over the motor pulley.
Sep 11, 2011 | Dryers
My Frigidaire Affinity electric dryer will not start. Its only just over 2 years old. the timer counts down but the drum will not turn nor is there any heat. I've tried jumping the dryer but it still will...
Listen, when you push the start button to hear a low hum, if you do hear this it maybe that your belt is broken. This is an involved job but can be done if you are handy.
Jan 22, 2011 | Frigidaire AEQ6000ES Electric Dryer
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Instruction for first alert et321 timer
Here is how it works. The push button repeats itself in following sequence (must plug in).
F 1 2 3 4 5 6 7 8 9 A d 1. 2. 3. 4. 5. 6. 7. 8. 9.
F: timer is off.
1 2 3 4 5 6 7 8 9: from dusk to dawn count down number of hours repeated every day. That's most useful to control outdoor lightings.
A: from dusk to dawn count down number of hours which is randomly selected by this timer. Which is usually for indoor use to turn lights on and off for number of hours. The randomly selected hours is a security feature so that lights on (on from dust, but off randomly) time shows no pattern to outsiders.
d: just on from dusk and off at dawn. It is also used to control outside lights but just a little wasteful in my opinion.
1. 2. 3. 4. 5. 6. 7. 8. 9.: meaning count down number of hours starts from the time when the button is pushed so that you can have a countdown timer at any time.
Dec 13, 2009 | First Alert Hardware & Accessories
Everything seems to work fine until you hit the start button than nothing happens except the timer starts counting down
If everything appears to be working normally, as you say the timer counts down, the light comes on, turntable rotates etc. then the problem will be linked to the magnetron not operating & not heating the food. This could be just a thermal fuse device which may have gone faulty but if it is a magnetron fault then the cost of getting this replaced can be expensive & it might be more economical to buy a new microwave. I would advise taking it to a local repair centre, one which gives free estimates to get a quote on a price.
Jul 27, 2009 | GE Microwave Ovens
Whirlpool dryer has power, but drum won't spin
More likely does have a belt. Get me the model number and I will see if I can help you on this problem, Thanks, Sea Breeze
Mar 21, 2009 | Whirlpool GEW9250 Electric Dryer
Samsung DV448AGE Gas Dryer Logo
265 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
