Question about SanDisk Sansa e260 MP3 Player
My Sansa e260 is freezing after few minutes of work
Every now and then my player is totally freezing. I can't even turn it off. I need to wait until the battery is empty, reconnect it to the computer and start all over again
Sometimes holding the power button for about 30 seconds will make it reset itself. Then you can push the power button again to turn it on. It works for me so you might as well give it a try.
Posted on Oct 31, 2008
My sand disk sansa mp4 keeps on freezing on the music play all the time and the computer cannot read it
How to Reset a Sansa Clip
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.)
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
Have a nice day....
Feb 19, 2011 | SanDisk Sansa e260 MP3 Player
Sansa e260 wont turn on indefinately.
did you try the lock on, rec button and the on button as you plugged it into the usb?
May 12, 2009 | SanDisk Sansa e260 MP3 Player
Problem with sansa e260
It is because the e260 is not in MSC mode (where it looks to the computer like a hard disk).
Try this, this will temporarily set your e260 into MSC mode. Then download and install the firmware as per instructions (or use the Sansa Updater software also available on the Sansa site). This will then let you see a menu item to switch to MSC mode.
MSC mode instructions:
  1. Turn on the e200 v2
  2. Put the device in Hold (move Hold button until orange is showing)
  3. Press and hold the Left Button
  4. Plug the 30 pin connector into the device (be sure the USB is plugged into the computer)
  5. Wait for the e200 drive(s) to show up
  6. Follow instructions below and drag files to the e200 drive
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=10357
Sep 06, 2008 | SanDisk Sansa e260 MP3 Player
Battery is too low. System shut down
Have you tried removing and replacing your battery? What about the connections and cord, are they damaged at all?
Jul 27, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e 260
try to wait for it to be fully charged.... then unplug ur sansa from ur computer if it works already... because as i know some sansa are like that... if its recharging it'll totally turned off or locked....
Feb 28, 2008 | SanDisk Sansa e260 MP3 Player
Freezing
try turning it off, just push the power button down until it shuts off, then leave it off for a couple of hours. if that doesn't work, call geeksquad, i guess......
Jan 09, 2008 | SanDisk Sansa e260 MP3 Player
Sansa E260 refresh data problem
Try following the directions found here.
Jan 07, 2008 | SanDisk Sansa e250 MP3 Player
How to reset my mp3 player
Mine has froze a few times also, Remove the four screws on back cover and take out battery. wait just a little while and replace.... works for me ! Wish they would have put a reset button somewhere on player ( hummmm to easy..................
Nov 30, 2007 | SanDisk Sansa e260 MP3 Player
My sansa e260 stopped working after unsuccessful formatting
I have guys, I just spoke with the Sansa representative. Even if you have Windows Vista, you do not need a drive for e260 given that Vista carries that drivers for it. If you have tried the steps above, but you Sansa still did not format successfully after using the recoverty tool. This is what you do:
Set you Sansa e260 in recovery mode
- set it to hold
- hold rec
- connect to computer while you are holding rec
- device should be now in recovrey mode
- go to my computer
- go to the folder 16B format
- you will see a text file
- don't worry about
- add a new folder and name Sansa.fmt
- wait up to 2 minutes
- message on your device should say formatting
- wait a few minutes for formatting to take place
- stop the device by removing it safely using windows Safely device removal tool on bottom right corner of your screen
- disconneting your Sansa and you should see a message upgrade finished, Sansa has been restored or something like that
- Power your Sansa on, and Bwala!!! your Sansa is back to normal.
Good luck
Dante
Nov 27, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
66 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
