Question about Yamaha RX-V459 Receiver
How do i connect my desk top computer to the rx-v459
4 Suggested Answers
SOURCE: Vocals missing while playing with 2 speakers
Go to the amp "Basic Setup" and alter basic setup according to
- the size of the room (details in the manual)
- alter the no. of channels e.g. if you have only 2 front speakers, change the channels to 2.1 (.1 for the subwoof)
- Once the setup is changed, the amp pumps in sound according to the set up
All the best
Posted on Apr 29, 2008
  • 127 Answers
SOURCE: yAMAHA YDS-11 TO A RX-V459
Hi, as per yamaha site RX-V459 doesn't have the DOCK connector which is used by YDS-11 dock (or the bluetooth module). This is the only possibility to connect the YDS-11. YDS nor receiver don't have USB connector and they are not needed.
For example RX-V465 does have DOCK connector and supports YDS-11.
For your receiver, you can use only analog audio cable with your iPod.
Posted on Mar 02, 2010
dunnbiker
  • 8546 Answers
SOURCE: Can Yamaha RX-V459 setup as bi-wired?
No, why? It's more hype than actual improvement.
http://forums.audioholics.com/forums/archive/index.php/t-1223.html
Posted on Mar 14, 2011
Testimonial: "Thanks for your quick reply, Guru. :)"
What's difference between Sony str d615 an Yamaha rx v459
You should be able to download the user manuals on both of these units for free by just googling them and then compare the stats.
Larry
Aug 14, 2015 | Yamaha Audio Players & Recorders
Yamaha Theatre receiver turns off at high volume 'Check SP wires' checked speaker wires no problem found. Why is this happening?
there are usually 2 things that cause this, (1) a driver in your speaker is going bad or a output IC/transister is going bad. Being a tech I have seen devices that operate fine at low to moderate levels but would fail when driven hard.
Feb 27, 2014 | Audio Players & Recorders
Hello i have a yamaha RX-v459, and i have an HDTV, can i connect my cable box to the yamaha and the yamaha to the TV and get HD? the Yamaha does not say HDTV, does that matter, or will i still get HD?
Yes, the cable box should/could be treated as any other digital audio device. The video could also be run directly to the TV as it doesn't actually improve from being routed to/through the Yamaha, does it?
The labeling on a given input is irrelevant (except for "PHONO", which is literal and exclusively for a turntable).
May 17, 2011 | Yamaha RX-V459 Receiver
Yamaha Cinema DSP Natural Sound System AV Receiver #RX-V459 was installed in 2005. It has never worked correctly. It sets on an open entertainment center. It has space all around, 2"on top and...
Are you saying the unit dies in 30 seconds at home but it works fine at Radio Shack?
Maybe you need to assess your power sourcing or any other condition that's unique.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 02, 2011 | Philips HTS-6500/37 System
I getting noise in yamaha rx-459 please help.
I used to get noise as well. It turned out to be that one of the cables to the speakers was loose. Try tightening the cable connections to the Yamaha and to the speakers.
Mar 01, 2011 | Yamaha RX-V459 Receiver
Trying to hook up a wii game to the rear of the recevier need to know which jacks to use
Actually, most will work. AUX IN, LINE IN, or TUNER in will all accept the "line level" output of the Wii. Just pick one of those, start with the volume DOWN on the amp and fire it up. Slowly increase volume but if nothing is heard in the first 1/4 turn, you've probably got something hooked up wrong. Back it down again and try another input or check connections.
Dec 28, 2010 | Yamaha RX-V459 Receiver
YAMAHA YDS-11 TO A RX-V459
Dec 17, 2009 | Yamaha RX-V459 Receiver
All the best
Apr 25, 2008 | Yamaha RX-V459 Receiver
Yamaha RX-V459 Receiver Logo
47 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
