Question about Toshiba Satellite A135-S4527 Notebook
Problem with recovery of the system (Windows XP)
Hi
I have problem when I am trying to recover my system (Windows XP) but when Recovery Console appeared and when I press "R". I have a different error message which reads
'Setup did not find any hard disk drives installed, Make sure any hard disk drives are powered on and are properly connected to your computer, and any disk-related hardware configuration is correct. This may involve running a manufacturer -supplied ..............or setup program
Setup can not continue
To quit Setup press F3'
Please can you let me know how I can recover my system without reformatting my hard drive.
I need to retrieve my data from my hard drive.
Dont know that it will help but my BIOS is PhoenixBios.
Thank you for your help
    Genius:
  • Toshiba Master
  • 1,250 Answers
Check the status of harddisk on bios, whether detecting it or not if detecting then also check the hdd status, change its native status
Posted on Oct 24, 2008
No arranca windows por el problema de windows root\system32 \hal.dll.
Hi! Welcome to www.fixya.com.
You need to get an Windows Operating system XP
Option 1:
Boot from your CD and follow the directions to start Recovery Console. Then:
Attrib -H -R -S C:\Boot.ini DEL C:\Boot.ini BootCfg /Rebuild Fixboot
Option 2:
Boot from your CD and follow the directions below to start Recovery Console.
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD. When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console. When prompted, type the Administrator password. (if you didn't create one try pressing enter).
At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
Most likely you will need to expand the file from the CD. The command would be expand d:\i386\hal.dl_ c:\windows\system32\hal.dll. Substitute d: for the drive letter of your CD. Once you have expanded the file type "exit" to exit the Recovery Console and restart the computer.
TIP: Recovering Windows XP using the Recovery Console
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | MSI Wind U100-030US Laptop
How can i made recovery of my window xp
I think you are concerned about creating a recovery console for windows xp, so that if windows fail you can have a chance to use it and recover the winndows.
You can install the Recovery Console on your computer to make it available in case that you cannot restart Windows. You can then select the Recovery Console option from the list of available operating systems during startup. To install the Recovery Console, you must be logged on as an administrator.
To install the Recovery Console, follow these steps:
  1. Insert the Windows XP CD into the CD drive.
  2. Click Start, and then click Run.
  3. In the Open box, type d:\i386\winnt32.exe /cmdcons where d is the drive letter for the CD drive. For Microsoft Windows XP Professional x64 Edition, type d:\amd64\winnt32.exe /cmdcons where d is the drive letter for the CD drive.
  4. A Windows Setup Dialog Box appears. The Windows Setup Dialog Box describes the Recovery Console option. To confirm the installation, click Yes.
  5. Restart the computer. The next time that you start your computer, "Microsoft Windows Recovery Console" appears on the startup menu.
May 30, 2011 | Computers & Internet
When i open my laptop, then boot, it goes to this windows 98 startup menu which has following options: reboot to windows xp, recover windows xp w/ full hd, recover xp w/ 2 partitions, and recover xp w/ 1...
first, recover your files. You will need to use something like this data recovery program.
http://www.asoftech.com/adr/
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Apr 03, 2011 | ASUS W7J Notebook
HP dv6000 turion processor. machine starts and all blue lights appear. dvd briefly lights and then machine turns off and then turns itself back on and repeats the process.
Preforming a system recovery to return the computer to its original condition may be necessary if the operating system is damaged, or the hard drive is corrupted, or the computer is infected by a virus.
___Also look this> HP expanded the battery pack recall on May 19, 2010. Click here to validate your battery. Performing a system recovery removes all software and files saved to the hard drive, reinstalls the original operating system, and then configures the settings for the default programs. Since the merger of Compaq and HP, several different recovery tools and processes Names for these tools include: Recovery Solution, Recovery Manager, F11, Recovery Disc, Driver and Application Recovery Disc, Roxio BackOntrack, Microsoft Backup & Restore. have been provided for recovering notebook PCs to their original operating condition. To help you select the correct recovery process, the table below identifies the different models, the time frame when they were produced and sold, plus the originally configured operating systems. Click on the name of the document in the right column for detailed information. Choose the Correct Recovery Process for Your Notebook Notebook description Recovery procedure information HP and Compaq Notebook PCs and Mini PCs shipped with a Windows 7 operating system. Recover Windows 7 Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Windows 7 instead of an HP solution. Recover Windows 7 Operating System Using Microsoft Windows Backup and Restore Presario, Pavilion, and HP Compaq Business PCs shipped with a Windows Vista operating system. Recover Windows Vista Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Vista instead of an HP solution. Recover Windows Vista Operating System Using Microsoft Windows Backup and Restore HP and Compaq Mini with Windows XP using the HP solution. Recover Windows XP Operating System On Mini Notebook Using HP Recovery HP and Compaq Mini with Windows XP using the Roxio recovery feature instead of the HP solution. Recover Windows XP Operating System Using Roxio BackOn Track HP and Compaq Mini with Mobile Internet Environment (MIE ). Recover Windows MIE Operating System On Mini Notebook Using HP Recovery Presario, Pavilion, and HP Compaq Business PCs manufactured and sold in 2006 or later . Recover Windows XP Operating System Using HP Recovery (2006 or Later)
Presario and Pavilion PCs manufactured from 2001 and 2005 . Recover Windows XP Operating System Using XP Operating System Discs (2001 to 2005)
And
Recover Applications Using Drivers and Applications Recovery Disc (2001 to 2005) Pavilion PCs with Windows Media Center edition of XP manufactured from 2001 to 2005 . Recover Windows XP Media Center Edition Operating System on HP Pavilion PCs Using HP Recovery (2001 to 2005) Compaq Presario PCs supplied with a Compaq Recovery CD and manufactured from 2001 to 2005 . Recover Windows XP Operating System on Compaq Presario PCs Using HP Recovery (2001 to 2005) Omnibook and certain Pavilion PCs manufactured pre-2001 . Recover Windows XP Operating System and Applications on HP Omnibook and Pavilion models Using HP Recovery (Pre 2001)
Nov 13, 2010 | HP Pavilion dv6000z Notebook
How do I format my laptop using the recovery disk???
hi there, here's the step by step procedure for reformatting.
1. insert the recovery disk first to your cd rom
2. restart pc and keep on tapping the F12 key
3. once you are prompted for boot options select your cd/dvd rom drive
your computer will now boot up from your cd rom and will initialize the setup.
Apr 21, 2010 | Acer Aspire 4720 Notebook
My 2 year old stepped on{or dropped } my Dell xps m140 and cracked the screen. I thought I would replace it myself..Before I do, I hooked up an external monitor to see if it still operates properly, well...
This error is also cause by the hard drive storage of your pc notebook, if you know how to locate the hard drive you just have to remove it for a while and then put it back, some loose connection of the hard drive cause the problem, if you find it still not working, you need to repair the system startup of Windown XP it is corrupted that's why it wont start.
Before attempting to check the physical parts of your notebook, try first to check and recover the Windows startup system.
In windows startup repair you can use the Windows Recovery Console.
Source: http://support.microsoft.com/kb/314058
Here's the step to start in Recovery Console:
  1. Insert the Windows XP CD into your CD drive and restart your computer. If you are prompted, select any options required to start (boot) from the CD.
  2. When the text-based part of Setup begins, follow the prompts. Select the repair or recover option by pressing R.
  3. If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
  4. When you are prompted, type the Administrator password.
  5. At the command prompt, type Recovery Console commands, and then you can refer to the commands that are listed in the "Available commands within Windows Recovery Console" section.
  6. At any time, you can type Help for a list of available commands.
  7. At any time, you can type Help commandname for help on a specific command. For example, you can type help attrib to display the help on the attributes command.
  8. At any time, you can exit Windows Recovery Console by typing Exit at the command line.
After you start the Windows Recovery Console, you receive the following message:
Microsoft Windows(R) Recovery Console
The Recovery Console provides system repair and recovery functionality.
1: C:\WINDOWS
Which Windows Installation would you like to log on to ?
(To cancel, press ENTER)
Enter the number for the appropriate Windows installation. In this example, you would press 1. Then, Windows prompts you to enter the Administrator account password.
Note If you use an incorrect password three times, the Windows Recovery Console closes. Also, if the Security Accounts Manager (SAM) database is missing or damaged, you cannot use the Windows Recovery Console because you cannot be authenticated correctly. After you enter your password and the Windows Recovery Console starts, type Exit to restart the computer.
Use the fixboot command to repair the startup boot of your notebook.
Feb 01, 2010 | Dell Inspiron XPS M140 Notebook
To create a recovery partition in harddisk
Unfortunately the Recovery partition could not be reacreated manually. But you can recover it by using the Y410 Recovery Disc but that means reinstalling everything and youll end up with windows vista again. You can reinstall XP but do not delete the partition that usually has 10-15GB of space because that is the hidden partition for the recovery. You can call 18774536686. If your computer is out of warranty, it would only cost you 59$ for the recovery disc
Jan 21, 2010 | Lenovo 3000 Y410 Laptop
My pc wont load into windows, blue screen says image kernel32 checksum
this problem could be fixed with the recovery console:
- insert the Windows XP installation cd and boot from it. - Select "Recovery Console" when prompt - type the following command:
Bootcfg/rebuild
The second (longer) option is to recover you XP installation
cheers
Jul 09, 2009 | Microsoft Windows XP Professional SP3 Full...
Won't go past window xp logo
You will need to launch Windows XP Recovery Console..here are your to options you have to perform this to correct your boot issue..
Option 1: If you have already installed the Recovery Console loadTOCNode(2, 'moreinformation'); If you have already installed the Recovery Console, you can select it during your usual Windows Startup. To run the Recovery Console:
  1. During Startup, select Recovery Console from the startup options menu.
  2. If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
  3. When you are prompted, type the Administrator password.
  4. At the command prompt, type Recovery Console commands, and then you can refer to the commands that are listed in the "Available commands within Windows Recovery Console" section.
  5. At any time, you can type Help for a list of available commands.
  6. At any time, you can type Help commandname for help on a specific command.For example, you can type help attrib to display the help on the attributes command.
  7. At any time, you can exit Windows Recovery Console by typing Exit at the command line.
uparrow.gifBack to the top Option 2: Starting the Windows Recovery Console from the Windows XP CD-ROM loadTOCNode(2, 'moreinformation'); If you have not preinstalled the Windows Recovery Console, you can start the computer and use the Recovery Console directly from your original Windows XP installation disc. If your computer is already in Windows and you want to add the Windows Recovery Console as a startup option, go to the next section "Adding the Windows Recovery Console as a startup option."
May 21, 2009 | Acer Aspire 3000 Notebook
Windows xp reboot at the start up again and again
plz try to boot in safe mode, if the problem persists than you have to repair or reload the operating sysytem
Jun 24, 2008 | Microsoft Windows XP Professional
Toshiba Satellite A135-S4527 Notebook Logo
128 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
