Question about Pioneer SD-P50A5-K 50" Rear Projection Television
No power had my rear projection tv and my dvd player hooked up to directv within weeks both went out is that a coincidence? anyway both have no power. i cannot turn on either manually or with the remote; i am not to concerned about the dvd player that can easily be replaced; i am however concerned about the tv although its more then 10 years old i still would like to see it working again. can anyone out there help me fix it.
  • frederick mcintosh Aug 11, 2006
    What do think is the problem?
    Or better yet can anyone out there tell me what the problem might be?
    Problem Solver:
  • 13 Answers
Bothers me that both went out at once. are they both pluged into power strip do any lights come on is power strip reset tripped doc
Posted on Aug 11, 2006
    President:
  • 3,130 Answers
Not unless your a tech and have some solid state elctronics experience.. These are sofisticated electronic circuits and a TV set is no place for a handi person or a do it your selfer to be tinkering with. theres several devices and equipment you need as there are no tubes to replace inside these sets except the picture tubes and you cant take those down to the drug store and test those tubes on the free tube tester,.. your gonna need to callout a trainde tech to assist you with this repair . good Luck
Posted on Aug 10, 2006
  • Larry  Dillon
    Larry Dillon Aug 11, 2006
    Most likly dryed up capacitors in the power regulator circuit is causing the set not to work properly. Common problem Also horizontal output shorts if regulator goes to high. So there may be an underlying problem if the hot is shorted.
My sound just went out
If this set has the Guide Plug logo printed on the front of the cabinet, unplug it from power and power it back.
If that does not help look in the menu for SAP which is secondary audio program, that will mute sound on some channels and may be your problem.
What do you have hooked to the set and how?
By the way if you hook a DVD player to the rear jacks on the set and go to that input and have good sound the problem is not in sound circuit.
Dec 06, 2012 | GE 46GW945 46" Rear Projection Television
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
I have a WS-65711 Mitsubishi rear projection the power went out last nite and now it wont turn on and the yellow light just keep flashing and when i reset it the light just keeps flashing
you need to buy a new tv when your power went out it was fine when it came back on it surged and fried components in the tv same thing happend to me but i lost my computer vcr tv dvd player and monotor
Jul 04, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No pic blue screen but we have sound
hi moma. the problem is that you need a new lamp for your tv...mind just went out a week ago and that is what i had to do go to a tv repair man tell them what kind of tv make sure you have model and serial no. plus lamp type,,, you will find that on the side or back of you tv on the left hand side as you are looking at the screen... hope this helps.
Jun 02, 2009 | Apex Digital GB5108 51" Rear Projection...
Lightening struck nearby and the tv went out. Now
Obviously the tv took the hit but the dvd player was spared. check and replace the fuse in the tv if it's open. If this does not fix it then get an est and file a claim with you homeowners insurance.
Apr 25, 2009 | Hitachi 50GX49B 50" Rear Projection...
I just had directv hooked up, I have a dvr receiver, I was told I did not have enough hook ups on the back of my tv, so therefore, I went and bought a switch or combiner. Now, how do I need to run the...
Newer directv hd receivers must connect to the av input (yellow,red, white) connections on the back/front/side of your tv. If your tv only has one of these av inputs then you will need an RF modulator for your dvd player. You will connect the (yellow,red, white) connections from the dvd player to the rf modulator and then connect the tv out on the rf modulator to the tv rf jack ( the silver threaded barrel on the back of the tv) Tune your tv to channel 3 to watch a dvd and then back to the av input channel for the directv receiver.
Apr 14, 2009 | Directv D11 DTV Receiver
Rear speakers
Well,i will be the judge of that.Please tell me how do you have your system hook up?Be details...ex. TV connected to receiver with HDMI cable..DVD player connected to receiver...
What component that you are having trouble with the rear speakers?EX. dvd player?Directv box?Both?
solutiondoct
Nov 16, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
Hook up dvd
Found this on http://www.satelliteguys.us/directv-forum/118015-hooking-up-dvd-player.html,
The Directv box should have at least two sets of out puts. You did not say what receiver you have and if the dvd is a player only of a recorder so its hard to say how to connect it.
If you have a dvd player only then take the output from the dvd player and connect it to you tv's second input, HDMI or component or what ever is a match between the two unites.
If you have a DVD-Recorder that you want to record programs from the directv receiver then take the second output from the receiver and connect it to the input on the DVD-Recorder and connect the output as above.
Hope this helps.
Sep 19, 2008 | Memorex MVD2042 DVD Player
Split screen question
Only if you have 1 Ant input, if you have ant 1 & 2 then you don't need a vcr for split screen.
Feb 29, 2008 | Panasonic PT-47WX49 47" Rear Projection...
No Picture, Menu screens or anything video - Sound still working!
Yes... Look for F851 and replace it with a slow blow 3.15A fuse per Toshiba. Bill
Jul 01, 2007 | Toshiba 43AX60 43" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
