Question about Nespresso Aeroccino Automatic Milk Frother
Aeroccino not working - Nespresso Aeroccino Automatic Milk Frother
Nespresso Aeroccino 3 does not heat and froth
I got mine today exact same thing happens... only blue does not warm AT ALL
Aug 26, 2012 | Coffee Makers & Espresso Machines
Tip
Nespresso Aeroccino Automatic Milk Frother Instructional Video
Click on the link below for the user guide for the Nespresso Aeroccino Automatic Milk Frother - http://www1.nespresso.com/precom/accessories/demo/aeroccino/index.php?lang=en
on Apr 27, 2011 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino frother won't turn back on after we get some froth and still more milk in container.. takes a long time to be able to activate again.. using Almond milk could be the problem any suggeest
My Nespresso Aeroccino often would not heat or froth multiple times after one use. I called Nespresso, they have excellent customer service, and was told to rise the inside (careful not to get the outside button or electric elements wet) of the Aeroccino with cold water a few times and to retry. Works like a charm!
The customer service is the best I have encountered in a long while, give them a call, it will make your day they are so pleasant and helpful!
Feb 18, 2012 | Nespresso Aeroccino Automatic Milk Frother
The Nespresso Aeroccino is frothing, however, as soon the lit is lifted the froth has gone. I bought the Nespresso Aeroccino a year ago and until last week it was working well. I washed inside + lit with...
Have you changed the type of milk? Full fat is best but it should work with semi skimmed.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 27, 2011 | Nespresso Aeroccino Automatic Milk Frother
Nespresso aeroccino doesn't work after milk was overflowing. Is there some kind of security which can be resetted?
The company will tell you to turn upside down for 24 hours to reset. I did and this did not work, you may have gotten base wet, which can break machine. Try turning upside for aeroccino upside down for 24 hr. you do not need to do this to the base. They told me if this does not work, I need to buy a new one. I hope you have better luck.
Apr 12, 2010 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino deosn't make froth
Our aeroccino worked fine for 2 years and suddenly it didn't made foam anymore. We tried the "inverting trick" without much success. We contacted Nespresso and they suggested switching from regular fresh milk (we used 2%) to UHT milk (harder to find in US) and to use it cold and freshly opened. So we tried that and it works.
Hope this solution works for you too
Aug 08, 2009 | Nespresso Aeroccino Automatic Milk Frother
Frother not turning on though there is power to the base
just wanted to comment on the issue with the Aeroccino when it stops working. As has been mentioned, Nespresso stated in the past that perhaps moisture (water) had gotten into the bottom of the frother and that might have been the reason it had stoped working. This was not my problem---I was very diligent in preventing ANY moisture entering the unit. But Nespresso has finally acknowledged the real issue. This is Nespresso's partial reply to my query: "Another possible cause for the Aeroccino to not turn on is the result of the Aeroccino jug being stored on the Base. The base does not have an on/off switch; therefore it is drawing full power at all times when plugged-in. If the Aeroccino jug is stored on a plugged-in base it can short-circuit. Once this has occurred there is no troubleshooting that will alleviate the issue, and replacement is the only option." There you have it. Mine would turn on for a several seconds, and merely warm the milk, instead of frothing it. I guess it took us 9 months to short-circuit it. Luckily ours is still under warranty, so a replacement is being shipped. Good luck to all of you with the same problem...I hope you are still under warranty. For those of you with a working Aeroccino: Don't leave the base plugged-in when not using the unit.
Dec 09, 2008 | Nespresso Aeroccino Automatic Milk Frother
Nepresso aeroccino doesn't spin fast enough to froth the milk
The company will tell you to turn upside down for 24 hours to reset. I did this but it did not work. Try turning upside for aeroccino upside down for 24 hr. You do not need to do this to the base. They told me if this does not work, I need to buy a new one. I hope you have better luck. I am on my third one. you may be covered under warranty- call Nepresso soon..they cover them for about 1 year. Good luck
Nov 30, 2008 | Nespresso Aeroccino Automatic Milk Frother
Nespresso aeroccino
It would seem that I was not putting sufficient milk into the aeroccino. I amm putting more in now and monitoring the situation. So far ,so good!
Oct 02, 2008 | Nespresso Aeroccino Automatic Milk Frother
Nespresso Aeroccino Automatic Milk Frother Logo
694 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
